new motor to tinker with...
I happened to replace a 220V 3 ph smart motor and thought it was interesting enough to pass along. This has 3 magnets on the rotor and an 18 pole stator, a 4 inch long 1/2 inch diameter shaft with a D shape . It came off a 5 ton commercial air conditioner squirrel cage fan. These should be readily available form your buddy the HVAC guy since the computer is usually the part that goes out leaving the windings and rotor usable for "projects".
- Attachments
- IMG_0305.jpg (2.22 MiB) Viewed 160 times
- IMG_0304.jpg (2.35 MiB) Viewed 160 times
Re: new motor to tinker with...
Seems powerful, but also heavy!
- everythingisawave 100 mW
Very curious.. strange that it has only 3 magnets? If it has 6 teeth per phase I would expect more poles, at least an even numberthunder wrote: ↑Apr 05 2021 8:35pmI happened to replace a 220V 3 ph smart motor and thought it was interesting enough to pass along. This has 3 magnets on the rotor and an 18 pole stator, a 4 inch long 1/2 inch diameter shaft with a D shape . It came off a 5 ton commercial air conditioner squirrel cage fan. These should be readily available form your buddy the HVAC guy since the computer is usually the part that goes out leaving the windings and rotor usable for "projects".
- spinningmagnets 100 GW
A section of metal can be formed that has two magnets of opposite orientation embedded at either end of it, and I suspect that is what's happening here. Three segments with three pole-pairs / six magnets.
[/quote]
I have a friend that does a lot of HVAC work and will see if he has any of these laying around and check what inside them. I thought it was funny there was 3 magnets on the rotor and its functioning as a 3 phase motor(3 wires going to the stator). That said I understand the 3 phase stator creates an even number of magnetic poles, dependent on the way it's wound
[/quote]
- amberwolf 100 GW
- Location: Phoenix, AZ, USA, Earth, Sol, Local Bubble, Orion Arm, Milky Way, Local Group
- Contact:
Consider that it only has to run at one speed, and only handle one specific loading, so it probably doesnt' need a lot of magnets for anything like precise position sensing; it just has to be able to startup from a stop and reach a set speed within some short amount of time, then maintain that for however long (including permanently, for those that run their circulation fans continously with the "fan always on" switch on the thermostat).
Weight doesn't really matter for it either, in it's fixed mounting on the roof or a concrete pad, etc.
Also, cross linking these two threads since they're about the same basic motor:
viewtopic.php?f=30&t=96136
If you found this advice helpful, supporting contributions are accepted here.
"if it ain't broke, improve it till it is"----Dog-Hauler Cargo eTrike SB Cruiser----The HI-Lebowski: a Lebowski SMD brain running a zombified Honda IMA Inverter: a HOW-TO guide----Cargo eBike CrazyBike2----General Blog
