Easiest to convert alternators?
hallkbrdz
Edmond, OK USA
A video sparked my interest in converting an alternator into a PM 3-phase motor. My son-in-law had a Ford Freestar that I obtained the alternator from, but that Motorcraft part has been a PITA to disassemble. Separating the cases was near impossible, and I resorted to using the gear puller on the wide case, pulling the stator wires from the diode board in the process (sort of nice!). While the one in the video popped off easy with a screwdriver, I'm still fighting to get the rotor conduction ring off this one, and have ordered a small two-arm puller just for that.
Given that - what fairly modern alternators that I could find in fair numbers at say, LKQ, that are good candidates for easy disassembly and conversion to 1.5ish kW motors.
Cheers
I am using a Valeo 180A,
but a PM Rotor is an expensive modifications. Is it worth to spend that money.
Sensor System is mandator for a project that request high torque @ start.
Let me participate how you do it.
Have fun.
Bob
Gesendet von meinem CPH1911 mit Tapatalk
Nice.
Yes, I think a PM rotor is well worth it. The magnet is only about $40 plus shipping, and it saves the weight and complexity of an additional battery. This will be for karting (kid kart), so weight is important. I'll need to build at least 3 so they can race competitively in their own class.
It's all apart now - except for the core. This nut on the shaft is the last thing in the way, and it won't budge with a drift. Such fun. :D
The magnet I plan on getting is this one - although I will need to measure the shaft to be sure before ordering. This is the size the video I referenced used.
https://www.magnet4sale.com/n45-3od-x-3-4id-x-1-neodymium-rare-earth-ring-magnet/
If the shaft is magnetic, it will shunt a lot of the flux away from the teeth. You may need to make a new shaft from something non-magnetic.
[/quote]
If the shaft is magnetic, it will shunt a lot of the flux away from the teeth. You may need to make a new shaft from something non-magnetic.[/quote]
Hello
Interessant
Do you have evidence for this statement!
I think the magnet can be chosen after you took the clawpole Eddy Current Rotor apart.
This is still an expensive magnet.
And you need three of them for your family.
IF you are spending $55 for the magnet (shipped) and $25 for an used alternator and then $15 for a sensor system and you want 1.5kw,
Are you sure you are on the wright path. The PM Rotor is great but you have everything on the Rotor to create a nice magnet field.
I stepped away from that approach as long nobody is prooving that I can use cheap FE Magnet to make an Rotor.
Greeting
Bob
Hello
Interessant
[/quote]
Many years ago I built a PM rotor to use as a hydroelectric generator. I was using a large doughnut shaped ferrite magnet from a loudspeaker. With the original steel shaft, it was useless. Once I replaced the shaft with one made from stainless steel, it worked quite well. The flux will follow the path of least resistance. In the original alternator, there is an energized coil around the shaft, so the steel shaft helps in that case, but with a permanent magnet, the shaft "short circuits" the flux.
Hi Fechter but in this post the starter want to use an axial magnetized round magnet, and then an non magnetic shaft will not work well.
So we have to stay of the subject.
Greeting
Bob
spinningmagnets said:
There's a chance it may be left-handed threads. I don't know...
I tried both directions, but it was my mistake. While the other end looks (and felt) like it is welded, it is not. It was either going to break the gear puller of come apart, but with some hammering with the air tool on full reverse at 120 PSI, it finally let go. :)
I'll need to strip them down, get it milled, add the magnet, and add hall sensors. But it's a proven to work design so the only question is will it be a good fit for purpose compared to iffy Chinese motors in the power range. At least with this I know the windings are heavy enough to take abuse.
As Bob pointed out, this is not an issue due to the way the teeth influence the flux.
Thanks,
Bryan
The magnet portion is relatively straight forward. I just need to get some clamps and a plastic or wood sleeve to lower the magnet onto one of the rotors.
The hall sensors... not so much. I'll upload photos later today showing why, but in a nutshell - a 4+mm wide sensor doesn't fit in a < 3mm wide slot. 6G slots are closer than 3G slots.
As pictured on the bottom, the Ford 6G alternator I have slots are narrower (< 3mm) than the 3G slots (4+ mm) shown on top, so the hall sensors will not fit between the iron.
A suggestion was made to use a small grinding tool to remove some of the iron in the center and then epoxy the sensor there. So far that seems the most sensible solution.
That's definetely nice to see!
If you need any help feel free to ask, I've successfully converted to alternators into motors. Recently I fixed the first I've ever converted (the sensor setup was messed) and it's installed on a go kart (here is the video: https://youtu.be/93eG9ZT8RY8)
Also I made another one with a VESC, I took all the rotor and axle dimensions, machined a custom shaft and a 3d printed PETG rotor to hold 12 10x10x40mm magnets, and runs like a charm (full conversion video: https://youtu.be/IsX3zHV-hZs)
Regards.
Henry.
If it's not too late, before you purchase and install your N45 paperweight of doom, you may want to carefully listen to https://www.youtube.com/watch?v=vp44tW1VDGg starting at 5:00.
