Page 1 of 1
Quick question for Sabvoton experts
Posted: Jun 05 2021 7:28am
by ebike11
Hi guys
In the bluetooth app in the "Function" menu, there is a sections called:
"Boost/3 speed"
Push button 3 gear
Boost
Switch 3 gear
Hard Start
I dont use a 3 speed switch at all. Also on the controller wire harness, I just twisted the high speed wire with the black wire.
I never use low speed and I want full max power/speed on all my settings
Which of the above 4 should I use? or does it even matter since my high speed and black wires are physically twisted together?
Thanks!!
Re: Quick question for Sabvoton experts
Posted: Jun 08 2021 3:50pm
by ebike11
Would anyone know? Thx
Posted: Jun 09 2021 2:57am
by Audisport09
I'm not an expert and don't have the bluetooth app but use PC version. For max speed startup you want I select Boost start, which I'm guessing is the same as Hard start.
Posted: Jun 09 2021 8:02pm
by ebike11
Audisport09 wrote:
Jun 09 2021 2:57am
Thanks...there is Boost and Hard Start . very strange
Posted: Jun 10 2021 5:54pm
by Audisport09
ebike11 wrote:
Jun 09 2021 8:02pm
Audisport09 wrote:
Jun 09 2021 2:57am
It is, I reckon Hard start should be boost start:
Boost mode:
if boost mode is selected, when the pink wire connect to ground wire and disconnect
after about 1 second(use a button ). the controller will enter boost mode and limit dc current according to the” boost dc current “setting. it will quit the boost mode after 30 second automatically.
Boost start mode:
If booststart mode is selected, every time when the motor spin from zero speed, the
controller will limit the dc current according to the” boost dc current “setting. after about 3 second, it will limit dc current according to “dc limit current” automatically
Posted: Jun 10 2021 9:16pm
by ebike11
Audisport09 wrote:
Jun 10 2021 5:54pm
ebike11 wrote:
Jun 09 2021 8:02pm
Audisport09 wrote:
Jun 09 2021 2:57am
Boost mode:
Boost start mode:
Hi
So HARD START would be the best for full power all of the time??
