Can QSMOTOR rotate forward in either direction
FbGFxVQhO6UHmBZQU   1 µW
Post by FbGFxVQhO6UHmBZQU » Jun 09 2021 7:31pm
hi. can QSMOTOR operate with drum brake on left side or right side?
Or in other words, can QSMOTOR 10in hub motor with drum brake have the wire on either side, and go forward at top speed regardless of which side the wires are on?
Or is the brake side always on the same side? Most design diagrams seems to show me the brake on the right side and wire on the left side.
j bjork   100 kW
Re: Can QSMOTOR rotate forward in either direction
Post by j bjork » Jun 10 2021 8:57am
It souldnt be a problem for the motor, but you better check if you can change direction on the brake arm.
