Muffylogan
- Joined
- Jun 23, 2021
- Messages
- 1
Hello,
I Have a Sevcon Gen 4 controller and a motenergy ME1115 PMAC motor that is constantly giving me DSP encoder faults.
Fault code: 0X52c1
Encoder input wire-off is detected.
Check encoder wiring.
The company I purchased the motor kit from says to just replace the encoder. I do this and it works ok for a few months (sometimes only a week) and then gives the same fault again. Well I’ve now replaced the encoder 6 or 7 times in the past 3 years and the controller once.
All wiring looks ok but today I noticed the voltage coming from the controller to the encoder reads at 3.1V instead of 5V. Can this value fluctuate? I don’t think the previous encoders would work if the value is always 3.1V.
The programmed parameter is set for 5V.
Anyone have any ideas as to why this keeps happening?
Thanks in advance
Nathan
Fault code: 0X52c1
Thanks in advance
Nathan
