Mihai_F
- Joined
- Oct 11, 2021
- Messages
- 127
Hy guys, i will move here the discussion about my 20Kw motor and 300A esc. This is been a project for my past 6 years, it's been a huge learning curve. Before i started this project my experience with electronics was with power audio circuits, analog stuff, and nothing digital.
I will start first with the electronic speed controller because that took most of the time to learn and develop.
So i begun with a BLDC monolithic driver chip, the MC33035, and i made the circuit with wires, it took me a month to get it running and be able top spin a small BLDC sensored motor, it looked like this:
It was capable of about 12w ,24v at 0.5A, then i learned what MOSFET stands for: Magically Obliterated, Smoke and Fire Emitting Transistor, i was amazed how much smoke can make a TO220 packge , inductance was my friend (bundle of wires), but at that time i was blissfully unaware of it. Then i learned a few things and moved the project to PCB, i was so impressed about my first toner transfer technique PCB, but from electrical stand point was crap, again i did not know that, this is how it looked,
This was the first year and it was capable of about 48w ,24v at 2A, before it wood magically let the smoke out of the FET-s, at that level i learned about that thing called "ringing"... .Then i learned a lot more things, i added a few functionalities like safestart, rpm, voltage, current and tep readout, all made on 4 digit 7 segment display, it was a lot of work, and it looked like this, (the big motor was made at this point) ,
This was the second year it was capable of about 120w , 36v at 3.3A, o about that time i realized i need to move up a bit and enter the AVR microcontroller world, i knew nothing about them, and all i knew about C programming language was that there was some things called "if" and "else"... , then another year of huge learning curve and another variant of the controller came witch was way easier to customize and change things, hence programmable microcontroller, it looked like this
This was in the third year became V1.0 it is capable about 2.5kw 20S(84v) 30A (current sensor limited),IRFP4468 FET-s , it has BMS and a lot of functionalities including 128x64 GLCD with menu where a lot of parameters can be customized, then the learning curve was the most steep making the ESC to work up to 16kw, then i learned what inductance can really do, and what miller plateou, reverse transfer capacitance, stray inductance, and a lot of goodies that give a lot of headakes.... , then came next variantwitch looked like this
This was in the fifth year, v1.2 witch worked up to 16Kw at 20S (84V), IRFP4468 FET-s (6/plase), PCB-s made by me. It was the first and last time i tested the motor by holding the table just myself... :lol: :lol: , it was exiting seeing my work succeed, but kinda scary because i could barely hold the table, the prop was pulling 78kgf
https://www.youtube.com/watch?v=NTU_feiQHvM&t=4s
This was how later tests were made, the motor was strapped by the car, no more worries about flying with the table
This was in the 6-th year the flight testing.
The motor was made by scaling up a smaller motor, (was still 20pp and 30 teeth but only 10kw), i did calculations for the winding, i drew it in 2D cad, went to a machine shop and told them what parts i need, the stator laminations were laser cut (unfortunatly 0,5mm thick), then a full day of winding. It was not even by far such complex to make as the ESC.
It's mass is 7.7kg, 216mm OD, 40mm stator hight, 40x10x5 N45 magnets, 6mohm and 10uH per phase, delta terminated, 3 halls and 1 temp sensors. It can do 16Kw continuous and 22Kw max (1 min) at 20 deg C ambient, being air cooled ambient temp affects max power.
And here are some photos of the system.
And in the present the 7-th year V1.3 (IRF150P220 FET-s) gives headakes as mention in my other post (300A ESC help...). The change (FET-s) was made in order to go with 22s battery.
It looks like this, with PCB-s made by specialized company, power board has 1mm thick water jet cut busbars.
This is just a short story, the hole experience has waaaaaay more detalis and waaaay more headakes.
There is a lots of room for improvement, this is very low tech, and to some may be even foolish, i know, up to this point it was the best i could do, but will see what future shows up.
