casainho
- Joined
- Feb 14, 2011
- Messages
- 6,044
Project page: https://github.com/EBiCS/EV_Motor_Controller_Customizable_Electronics
The target for this EV motor controller is to power small EVs like EBikes or EScooters like Xiaomi M365.
Main objectives:
- Possible to add custom electronics: for reusing this motor controller on different devices, customize it for the specifics of each project.
- Easy to build and repair: build at home DIY. Use popular components. Repair if needed or unsolder the components to reuse on another projects.
Characteristics:
- Header for custom electronics board: other board can be connected, like a perforated board with some simple electronics for instance to add CAN communications, 2x UARTS: full duplex or half duplex; specific circuit for EBikes torque sensors; SPI or I2C for cheap popular OLED displays; add a Bluetooth module; add NRF52 board with EBike ANT+ LEV wireless standard, etc.
- Easy to build and repair as DIY: no fine pitch components as like a STM32 microcontroller - uses DC-DC modules as also the Bluepill STM32 board. The resistors and capacitors are 0805. The ICs are SOIC8 and SOIC14. This means it can be easily soldered at home.
- Popular components: Uses the popular Bluepill STM32F103 board, meaning it is easy to develop firmware for it. Uses popular components common found on EBikes chinese motor controllers.
Current state
As of 31.12.2021,
- the schematic was discussed between Andrii and Casainho. Andrii already did a similar motor controller and is confident on this schematic.
- the PCB was designed by Andrii
- the PCB was ordered and next steps are to build and test the motor controller, using this OpenSource firmware: https://github.com/Koxx3/SmartESC_STM32_v3
Schematic:
PCB:
Main objectives:
Characteristics:
Current state
As of 31.12.2021,
Schematic:
PCB:
