12 kw rc motor
Jeremy Harris   10 GW
Re: 12 kw rc motor
Post by Jeremy Harris » Mar 22 2010 2:32pm
liveforphysics wrote:You're not going to find a sensorless controller to do it any justice.
There isn't a sensorless controller available that can even do the 1/3rd the size HXT motor any justice.
Get one of those motors to Jeremy or Burtie, and they can figure out a sensor position/solution for it, and then it can be used properly.
RC controllers are for toy motors in 10lbs toys. This is not a toy motor.
As far as the people asking about bigger phase leads, that would just require doing a higher KV wind. They just pair the phase wires up in delta and run them out of the case on RC motors, so the wire size is determined by the winding dimensions, which are of course determined by the number of winds.
I'm already working on a controller, Luke! I've been doing a lot of work recently on building a small, high current, controller. One thing I discovered, when looking through dozens of FET spec sheets, is that there are some surprises, as a big package isn't necessarily the best. Some may have spotted that getting heat out of the FET junction is the big issue that limits the current a single FET can handle. There's nothing much that can be done about the internal thermal resistance, and this tends to be similar for pretty much any package. The big packages offer the means to get heat out of the package more easily, but this can be done another way, I think.
I've found this FET:
IRFS3107-7ppbf.pdf
(315.02 KiB) Downloaded 332 times
Yes, it's a small, surface mount package. BUT, look at the ratings and then think about this as a mounting option:
What if the power rails and the phase connections were solid copper bars, connected to internal finned heatsinks?
What if the FETs were soldered directly to the copper bars, providing not only a good electrical connection, but also a near-zero thermal resistance (no insulators needed)?
What if the controller had a small internal fan to keep the "live" heatsinks cool?
I'm thinking of a 12 FET power "board" using these FETs, driven by a 6 FET controller board. I reckon such a controller would comfortably handle well over 200 amps. In fact, in might well do around 150 amps on just 6 FETs. The downside would be the 75V FET Vds limit, but as the motor is rated at 60V max this shouldn't be too big and issue.
Any thoughts?
Jeremy
bigmoose   100 MW
Re: 12 kw rc motor
Post by bigmoose » Mar 22 2010 7:04pm
Jeremy your idea is good! It is exactly the direction I was headed, and I was spec'ing the D2Pak 7Pin package also. As they say, "Carry on!" :wink:
I was looking at the 100 Volt version: IRFS4010.
An other facet I was thinking about was to remove all the spaghetti from the "power head" of the controller and run a serial link to a handlebar "data/control module" That way the PowerHead only get battery busses, 3 phases to motor, hall leads, and a 3 or 4 wire link to the DataControl module. All the rest of the spaghetti/connectors would then be right in the handlebar area.
"Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God..." all the best, Dave
jag   10 kW
Re: 12 kw rc motor
Post by jag » Mar 22 2010 9:00pm
I'd say solder thick and wide copper power bus to source and drain (ben the gate up a bit). Then a thin insulating sheet between the copper bars and a regular passive heatsink. Remember total thermal resistance of this insulating sheet = k/contact area. the contact area of the copper bars can be made arbitrary large, so the negative impact of an electrically insulating pad can be made much smaller than when it is attached directly to the FET. This is why newer CPU's have heat spreaders inside the package.
Even more compact: Design the controller PCB to match the slightly bent up gate pins, then attach power bar and heatsink assembly with small risers. A bit of a pain to manually solder the FETs this way, but I think I have managed more tedious ones...
12p3phPMDC   1 kW
Re: 12 kw rc motor
Post by 12p3phPMDC » Mar 22 2010 10:21pm
:mrgreen: THose 7 lead d2paks do look impressive. lots of good ideas here. :mrgreen:
Keystone electronics makes some great little phenolic standoffs with threads that you can use
to isolate a direct copper bonded assembly if you want to float it within the case.
I just got some samples to isolate the ground leg of the shunt from the heat sink.
"If you don't follow your dreams, you might as well be a vegetable." Burt Munro
The reasonable man adapts himself to the world;
the unreasonable one persists in trying to adapt the world to himself.
Therefore all progress depends on the unreasonable man.
-- George Bernard Shaw
swbluto   100 GW
Re: 12 kw rc motor
Post by swbluto » Mar 23 2010 12:54am
IRFS3107-7ppbf.pdf
Any thoughts?
Jeremy
If you can successfully mount/solder it to a large heatsink without killing the fet AND have a powerful fan providing airflow, I'd say you got yourself a winner. I use a CPU fan with heatsink on my ESC and it stays *amazingly* cooler when blowing air than when it isn't. (Like the difference between 10 degrees above ambient and 130 degrees.) The closer the air flow is to the fets, the better.
Jeremy Harris   10 GW
Re: 12 kw rc motor
Post by Jeremy Harris » Mar 23 2010 2:17am
I guess I could bolt the big copper bus bars to an external heatsink, using insulating pads, but I rather like the idea of internal fan cooling. I think this motor is probably going to need forced air cooling if it's run enclosed/semi enclosed on a bike, anyway. One option might be to build the controller into the motor mounting housing, fit a fan on the end of the motor and have a neat unit that houses the motor, controller and something like one of Matt's reduction drives.
This would make installation and wiring nice and easy and it would reduce the I²R losses on the controller to motor phase wires (which can be high, as the phase current peak can easily be two or three times the battery current). A module that just bolts in, with a drive shaft suitable for direct connection to a final drive on one side, a couple of hefty power feed wires, a three wire throttle connection and maybe an ebrake connection would make for an easy to use power unit. Using the motor as the means to turn the fan removes the potential unreliability of a separate cooling fan.
Whilst I can probably put together the controller and maybe prototype the drive module, if it works it might be just the sort of this for one of our budding parts producers to look at making. It'd be nice to have a CNC machined housing holding everything and looking cool as well.
Jeremy
Timma2500   1 kW
Re: 12 kw rc motor
Post by Timma2500 » Mar 23 2010 2:30am
AussieJester wrote:Wholly snapping duck shit i MUST have one of these beauties!!! Luke forgets about
160km/hr e-bike 200km/hr babeee! Lets see those frock motor boys catch this bad boy :twisted:
Who do I paypal?
^^Ditto
KiM
Yep that pretty much sums it up! Hmmm single speed, direct drive to back wheel with maybe around 3:1 - 5:1 reduction depending on voltage used.
Simple, neat, monstrous! :twisted:
Awsome find! Now to find a controller with big enough balls to run it lol :wink:
Sounds like work has began on that front :)
Paul :D
Norco Aline / carbon fibre frame mod / 12t Mac / 12fet / 23kg
markobetti   10 kW
Re: 12 kw rc motor
Post by markobetti » Mar 23 2010 5:08am
i will have sensored - same motor on 14 of april :)
12p3phPMDC   1 kW
Re: 12 kw rc motor
Post by 12p3phPMDC » Mar 23 2010 9:11am
Markobetti,
Fantastic!!
If you can request that all of the motors we want to be sensored for little to no cost extra, then that would
make it generic for everyone, because if you find a monster sensorless controller, you don't have to use the sensors anyway. :D
swbluto   100 GW
Re: 12 kw rc motor
Post by swbluto » Mar 23 2010 10:08am
12p3phPMDC wrote: If you can request that all of the motors we want to be sensored for little to no cost extra, then that would
Yep yep. I'd gladly pay more for the option to use hall sensors, if I wished. If I didn't want to use hall sensors, sensorless is pretty straightforward and is a small price to pay for the majority who want sensors.
salty9   1 kW
Re: 12 kw rc motor
Post by salty9 » Mar 23 2010 11:23am
Jeremy Harris wrote:I guess I could bolt the big copper bus bars to an external heatsink, using insulating pads, but I rather like the idea of internal fan cooling. I think this motor is probably going to need forced air cooling if it's run enclosed/semi enclosed on a bike, anyway. One option might be to build the controller into the motor mounting housing, fit a fan on the end of the motor and have a neat unit that houses the motor, controller and something like one of Matt's reduction drives.
Thanks Jeremy,
You've made me redesign my planned controller for my altermotor.
RWP   1 kW
Re: 12 kw rc motor
Post by RWP » Mar 24 2010 1:57am
Thanks guys - this is great!!! :D
I'm in for 2 if they are sensored, and I can wait although I would love to fondle one of these monsters yesterday :twisted:
Thanks again,
Roy
AussieJester   100 GW
Re: 12 kw rc motor
Post by AussieJester » Mar 24 2010 3:04am
As i said page back im in for one myself would prefer sensored but am cash strapped due to current spending on RC crusier project by when do we need the $$$ paypaled in please ? I can't get $$$ for ~4 weeks im afraid?!?! Alternatively... if any of your financially wellz off fellas could spring for a spare for me i would reimburse you the cost plus freight and extra 50 bucks for your efforts? Lemme knowz either way please as i would VERY much like one of these for my next custom build...
KiM
HAL9000v2.0   10 kW
Re: 12 kw rc motor
Post by HAL9000v2.0 » Mar 24 2010 3:42am
Kim, don't worry, I'll save one for you.
I will even make some lightening holes for you :)
liveforphysics   100 GW
Re: 12 kw rc motor
Post by liveforphysics » Mar 24 2010 4:16am
Kim, I'm planning on getting 3-4 of them. I will gladly paypal for 1 extra for you bro.
AussieJester   100 GW
Re: 12 kw rc motor
Post by AussieJester » Mar 24 2010 4:50am
haha cheers Hal and LFP appreciate the offers, ill see when the 'due date' is
for payment if the money is need in a week...well im screwed... so will hit you fellas up,
I guess if your in for 3-4 already Luke and happy to grab an extra i already have your paypal details
and can deposit funds each pay till i have it covered if that's cool? Shall speak with you when i have
all the payment date details anywayz...Thanks again Hal and Luke for your offers :-)
KiM
p.s Hal get back to the workshop i wants updates on that L337 MTB frame damnit!!
markobetti   10 kW
Re: 12 kw rc motor
Post by markobetti » Mar 24 2010 6:02am
kim dont worry, the date is not like we stated before,since things went in different direction . Hal said it would be the best to make some things differently . So he improved design of the motor in one day.Anyways , the motor will be sensord with Hals cooling system . For everybody sending me pm , please wait a little. The motor will be a state of art, but we need to get new samples and test them.
AussieJester   100 GW
Re: 12 kw rc motor
Post by AussieJester » Mar 24 2010 7:05am
Cheers mate...well i can put money away for it in ~4 weeks so please put me down for a certainty for one sensored motor :-)
KiM
cell_man   100 kW
Re: 12 kw rc motor
Post by cell_man » Mar 24 2010 10:05am
I'd be interested in 1 or 2 of these motors. Shipping straight to Shanghai. Let us know what's the deal with these and I'll get the funds sorted.
Visit http://www.EM3ev.com/ for our Ebike Kits and in-house battery packs. Online Shipping quotes to most popular destinations, with automated PayPal checkout.
Browse the site or drop us a line via the contact page: http://em3ev.com/store/index.php?route= ... on/contact
veloman   1 GW
1 GW
Re: 12 kw rc motor
Post by veloman » Mar 24 2010 2:00pm
That is an absolute beast. I've love to see a video of someone's complete bike with this on it. Have fun rigging the whole system together to withstand 15hp. And how long will your batteries last? :lol:
Mush! Mush you electrons! Push harder!
amberwolf   100 GW
Re: 12 kw rc motor
Post by amberwolf » Mar 24 2010 4:38pm
The problem is going to be fitting a large enough gauge extension cord onto the trailer-mounted cable reel. :P
If you found this advice helpful, supporting contributions are accepted here.
Beginning of a New Life
Give a listen to my music!
(More here, including experimental).
tritonwow   100 W
Re: 12 kw rc motor
Post by tritonwow » Mar 27 2010 2:51am
I'm in for two of these motors
TidalForce S-750 with Bafang SWXH rear hub
Diamondback Insight 700c "Roadrunner" in the making
1967 eNorton in the making
Potentially 2001 Triumph eDaytona in the making
'95 Triumph Daytona 1200 ICE
johnws6   100 mW
Re: 12 kw rc motor
Post by johnws6 » Mar 27 2010 6:33pm
I'll take 1, maybe 2.
tritonwow   100 W
Re: 12 kw rc motor
Post by tritonwow » Apr 02 2010 9:03pm
What's the story morning glory?
Anything new?
Re: 12 kw rc motor
Post by liveforphysics » Apr 02 2010 10:07pm
I'm putting together some CAD sketches of coupling together 12 of these motors along the belly-pan of a lotus 7 kit to make an EV.
If I can mount the battery similarly low, I could make the lowest center of gravity lotus 7 kit in the world, and perhaps even the best handling lotus 7 in the world. Perhaps 350hp burst, 150hp continous, maybe 1,200-1,500lbs with driver.
