The relationship between Amps (I) and Watts (W) is one of Current and Power. Each manufacturer will vary to some degree based upon the physical design of their products, and it is not always apples = apples.
From the
OP, what you may be reading is a motor matched with a controller. The motors can take a lot of current. Horsepower or wattage-rating depends on use, and is by no means fixed.
Torker is correct:
Motor Width and Radius are important factors in choosing the proper hub as much as the number of Turns/Windings. In that – both the Crystalyte 5X- series and the Nine Continent (9C) hubs are a good choice for MtBs. There are motors out there with gears and brushes too that are perfectly suited to particular applications.
Power-hungry:
However to be clear, Watts consumed is a function of Load or Work on or by the system. In other words, if I am traveling on a flat surface in good weather with no wind on a light bike, the motor will take a lot less current and power to push the bike, especially if I pedal aggressively. Conversely climbing a steep hill will pull a lot of current: Speed, wind, nasty road conditions, and inclines all suck power.
What I’m trying to say is don’t get stuck on the Wattage rating of a motor because they can do wondrous things with voltage, battery capacity, and the right controller. For instance the 9C motor
could be rated at 500W using 36V if I clamped the max current to < 14A which is
pretty pathetic for hill climbing, but
great for racing down level roads.
Thus, choosing the correct motor then becomes less about wattage and current because both the Crystalyte and 9C are similar fruit: Wattage is gated and constrained by your usage and associated equipment.
Environmental Conditions:
If you live in a hilly area then you want more power early for better climbing. I live near Seattle and the hills here are steep and long ~ therefore my current is easily going to be > 20A at 36V if I wish to sustain 20 mph.
If you live in a flat area then you can get by with less power and your battery reserves will last longer.
Decide:
- What is the top speed desired on a flat. Lower turns/windings = faster
- What is the amount of torque/power desired for starting or climbing. Higher turns/windings = stronger
- Voltage = Potential. Higher voltage ultimately translates into more power and faster speed, though also results in slightly less efficiency. Most folks run between 36 to 48V which is fine for typical applications; it’s a great place to start.
- Current demand is proportional to the load. A good set of batteries can make all the difference in the world. Buy cheap and that’s what you’ll have, and the choice of motor will factor less. A strong battery pack with good capacity is best for hill climbing and/or duration.
- Match the controller with the intended use: Flatlander can get by on 20A, but hill climbers will drink up to 40A depending on how aggressive they are. For the most part those motors can take it …and at that level of consumption, I can guarantee it will be > 1000W! :wink:
The
eBikes simulator is great for comparing apples to oranges to cherries; it is a good tool if you’re just starting out and making plans, though I wish it were a bit more customizable
Good Hunting!
KF
