Lagoethe
- Joined
- Nov 10, 2010
- Messages
- 89
Hello
I'm looking for a 600 (approx.) RPM HUB motor 1KW, likely fed by 48V.
I have difficulties to find such a motor. In fact the only one i find is the KELLY MOTOR here are my questions:
-Why is it so hard to find a 600RPM HUB motor?
Is it because hub motors were made for bicycle (so 25km/h) initially?
Then Why HUB scooters motors have a such less RPM ?
-I understood that if the voltage goes up, then the speed will go up too.
Can an approximation like this be made: 48V/100Rpm => 72V/x x=150Rpm ?
How can we know the limits of RPM of a motor (and its efficiency)?
Why not using a BOOST converter to increase the voltage and then the RPM ?
Thank you
Thank you
