olaf-lampe
Hi,
I'm building my own watercooled 12 FET infineon controller. The cooling bar has no connection to the housing.
Q:
Can I use the aluminium bar to feed the highside FETs with positive voltage? ( Drain is also connected to the backplate of the FET as u know )
I would only put Kapton tape between the lowside FETs and the cooling bar.
I expect lower losses and a better cooling . Also the pcb will like it when only 'half' of the current heats up the traces.
What do you think?
-Olaf
Q:
What do you think?
-Olaf
