Biff
If you were looking to replace a ME0709 with a brushless equivalent, (same mounting / shaft / outside Diameter / RPM) would you rather:
A) select a motor with the same mass (around 16kg) that could deliver 3x the continuous power (around 24kW continuous 50kW for 2 minutes), and cost around $800
or B) was 2/3 the weight and delivered about the same amount of power (8kW continuous 16kW for 2 minutes) and cost around $450
-ryan
-ryan
