Got a free AC motor, it is strong enough for EV conversion?
bigchief   100 mW
Post by bigchief » Mar 19 2011 12:38am
Hey guys, I've been into EV's ever since I got my electric bike working about a year ago, thanks in no small part to all of you. Since then I've been dreaming of an electric car conversion. Now, seemingly out of nowhere, my boss asked me to toss out an old motor in the basement of our building. I took a look at it, and surprise! It's actually a huge, powerful looking AC motor. At the same time, my brother offered me a decent donor that he was planning to scrap (Nissan Maxima). Seems like this is a sign to follow my dreams and take the plunge.
Anyways, would anyone here be able to look at these pics of the motor/faceplate and explain to me what I have on my hands? Is this thing powerful enough to run an average car? What would you suppose a top speed would be assuming I get good batteries/controller? Any general advice on making use of this? Thanks in advance for the help!
Faceplate
The whole thing
fizzit   10 kW
Re: Got a free AC motor, it is strong enough for EV conversi
Post by fizzit » Mar 19 2011 12:45am
Well you would need a huge inverter... and a 230v battery pack (I think)... and you would only get 15HP out of it, if the nameplate reading is correct. That's barely enough to run a small car.
-Colin
bigchief   100 mW
Post by bigchief » Mar 19 2011 12:57am
Some Googling seems to suggest that this is a discontinued "Belt Drive Condenser" from 1989, whatever that means. Could 15 Horsepower take a very light car (like a Geo Metro) to highway speeds? Or would this be more of an "around town" thing if it works? Is this a three phase AC?
fizzit   10 kW
Post by fizzit » Mar 19 2011 1:09am
I'm pretty sure that 3PH on the label means that it is indeed 3-phase AC. I don't know about highway speeds, but I would guess that it could take a small car around town. Methods put a 4HP motor in his VW beetle. If you ran it over it's rated HP and installed some forced air cooling, it would go even faster!
-Colin
tostino   10 kW
Post by tostino » Mar 19 2011 11:26am
That motor is just not at all wound ideally for a car... At 230v its only spinning 1700 rpm... That's an issue. If you over volted it, and geared it down, that would work fine. But over volting something that's already at that high of a voltage is kinda hard.
Harold in CR   1 MW
Post by Harold in CR » Mar 19 2011 12:03pm
I would take it and sell it. Whatever you get will be more than you have now. Then, get a better suited motor.
Thanks to Justin, the forum is open source and NON-commercialized.
fechter   100 GW
Post by fechter » Mar 19 2011 1:57pm
The HP and rpm numbers only apply at 60Hz. If you use a VFD inverter, you can get a lot more out of it.
Sometimes you can find used VFD inverters on eBay. It would probably take a little modification to make one run off a battery, but probably not too hard.
Harold in CR   1 MW
Post by Harold in CR » Mar 19 2011 3:23pm
Go to http://www.diyelectriccar.com.
There is a running thread about those AC motors and controllers. Might have to look around a little to find the thread.
dbaker   100 kW
Post by dbaker » Mar 19 2011 3:54pm
You would need to get a 230V VFD rated for at least 15HP that can be fed DC. VFDs take 3 phase AC and convert it to DC then use an inverter to convert the DC back to AC at a variable frequency to vary the speed of the motor. There are plenty of people who have done this. Here is an example: http://www.evalbum.com/1687
When I looked into it several years ago I realized I could not afford a suitable lithium battery pack. For a 230 volt 3 phase AC motor you will need a 530 volt DC pack!
fizzit   10 kW
Post by fizzit » Mar 19 2011 5:30pm
I wouldn't think that a pack of that voltage wouldn't be that much more expensive if you had the same WH as a similar, lower-voltage pack, but it would be a bitch to balance and charge!
-Colin
fechter   100 GW
Post by fechter » Mar 19 2011 11:28pm
The guys running AC induction motors on motorcycles use a motor that's been re-wound for lower voltage. With the right winding, you could then use a Curtis or Sevcon controller at a reasonable (under 100v) voltage.
I don't know how much work it would be to rewind a motor like that, but there are places that specialize in that.
Here's the Curtis website: http://www.curtisinstruments.com/index. ... ontrollers
Sevcon: http://www.sevcon.com/pages/gen4.html
voicecoils   10 MW
Post by voicecoils » Mar 20 2011 1:00am
Don't forget that the nameplate rating is often for continuous industrial use.
You might be able to get 5-10x the nameplate power out of the motor for short periods with some temperature monitoring and those periods of higher power can be extended with forced air cooling or even liquid cooling. It's worth also remembering that if you're generating lots of heat, you're wasting power.
REdiculous   10 kW
Post by REdiculous » Apr 05 2011 11:22am
The plate says 15HP but if you do the math it's 12HP (230v*39a=8970w=12.0289HP). :)
