Greentime controllers
ian.mich   10 kW
Post by ian.mich » Jun 17 2012 4:18pm
ian.mich   10 kW
Re: Greentime controllers
Post by ian.mich » Jun 17 2012 5:40pm
and no i'm not a spammer
boppinbob   1 kW
Post by boppinbob » Jun 17 2012 5:52pm
I hate to sound skeptical but something that sounds too good to be true usually is.
Project bike-Genesis v2100, Crystalyte HS 3540 with 72v40A controller and four 5s8Ah zippy lipos in series.
ian.mich   10 kW
Post by ian.mich » Jun 17 2012 5:58pm
neptronix   100 GW
Post by neptronix » Jun 17 2012 6:12pm
There are multiple threads about these controllers already.
http://endless-sphere.com/forums/viewto ... =greentime
Start reading and find out why everyone is not using them :)
ian.mich   10 kW
Post by ian.mich » Jun 17 2012 7:44pm
neptronix wrote:There are multiple threads about these controllers already.
In that thread is everyone is praising the controllers, with the few people complaining about lack of programmability and lower quality assembly, which are pains that are alleviated by the fact that you can have leo customize it for any specs, and spending 10 mins soldering.
neptronix   100 GW
Post by neptronix » Jun 17 2012 7:51pm
What if you decide to use it on a different motor? or change the LVC? or that the 3 speed switch is set incorrectly? do you buy another?
The construction looks awfully poor. If that is a problem, we will find out in time.
If you are particular about having a system that runs perfectly, and want to tune your controller until it does, non-programmability is going to be a problem.
I for one, would be willing to look past the construction issues if these were programmable, being that they are at such a low cost.
ian.mich   10 kW
Post by ian.mich » Jun 17 2012 8:07pm
neptronix wrote:What if you decide to use it on a different motor? or change the LVC? or that the 3 speed switch is set incorrectly? do you buy another?
Meh, leo's a good guy and they are indestructible. They do need their connectors repleced though. LVC is unnecessary but can be set via a simple resistor change, you can buy a voltage panel on ebay for $8, and the controllers are set up properly, 3 speed switch hasn't been a problem. Never recieved a dud and are always set up properly.
ian.mich   10 kW
Post by ian.mich » Jun 18 2012 6:25pm
Greentime is legitimately the best ebike parts supplier in china
SamTexas   100 MW
Post by SamTexas » Jun 18 2012 6:37pm
ian.mich wrote:http://www.aliexpress.com/fm-store/3138 ... -s-EV.html
Why aren't people emptying Greentime's inventory, they offer completely custom controllers at any voltage or current, choice of 4410s, 4110s, 4115s, regen, EABS, cruise, and best of all: sensor and sensorless support. They do all this for rock bottom prices. Why aren't these on every ebike? This "48V 1000W" controller does 100V 45A, and all the features I outlined for $45 with shipping. The crystalyte controllers that cost an arm and a leg don't have the same features as this.
That sounds really good. I just looked at the link but could not find the following supports: sensor and sensorless, 100V. Where do you find that info?
48V 1000W 45Amax BLDC motor controller
Feature:
1)Rated voltage: DC48V
2)Rated power: 1000W
3)Max current: 45Amax
4)Under-voltage protection: DC40-41.5V
5)Current limited: 45A±0.5A
6)Efficiency: ≥83%
7)Consumption: <1.5W
8)Controller category: Brushless direct current
9)Applicable model: electric bicycle,electric scooter,electric vehicle
Function:
1)Super low noise when start up
2)Speed limited/3-Speed
3)Under-voltage protection
4)Over-current protection
5)Cruising Control
6)Water proof
7)E-ABS/Hign Level Brake
8)Regen braking (recharging)
DAND214   1 GW
1 GW
Location: About 1200 miles south of Chicago, in sunny/rainny Port Richey, Florida!
Post by DAND214 » Jun 18 2012 6:39pm
Price for the controller is fair but the shipping is insane.
No break on quanity controllers as the shipping is the same for each item. It's not the cost of the controller they are making money on it's the shipping!
Buy one and shipping is $30 buy 10 and it's $300.00 I never buy 1 from China as you never know if the first one is any good so always order extra. Not here shipping breaks don't apply. $43.00 buy 1 or 10.
Yeah the price is fair but the wait is too long if you need another.
No Thanks.
Dan
SamTexas   100 MW
Post by SamTexas » Jun 18 2012 6:44pm
DAND214 wrote: Buy one and shipping is $30
What? It says $14.56 for shipping 1 unit to the US.
Price:
US $31.00 / piece
Bulk Price:
US $29.14 / piece (5 pieces or more)
Quantity:
piece
Shipping Cost:
US $14.56toUnited States Via China Post Air Mail
Processing Time:
Ships out within 1 days
Total Price:
US $45.56
ian.mich   10 kW
Post by ian.mich » Jun 18 2012 8:58pm
Feature:
6)Efficiency: ≥83%
Function:
5)Cruising Control
6)Water proof
I contacted Leo, and he said they had 100V capacitors, 4410 mosfets, and worked with or without hall sensors. he recomended not to go over 96v but they're fine for 24s lipo.
SamTexas   100 MW
Post by SamTexas » Jun 18 2012 10:05pm
Thanks. So have you tried it in sensorless mode?
XLR8   100 W
Post by XLR8 » Jun 18 2012 10:24pm
Has anyone enabled regen or EABS on one of Leo's controllers? I have the cruise and 3 speed features working but I haven't had any luck with EABS. These controllers are good value for money. I purchased a 60 volt 1500 watt controller for $42 delivered to the door, Australia. The motor runs just noticeably warm and the controller has no obvious heating at all on a normal ride around the streets with small hills.
Gordo   100 kW
Post by Gordo » Jun 18 2012 10:34pm
DAND214 wrote:Price for the controller is fair but the shipping is insane.
No Thanks.
Dan
Bang for the buck can't be beat. HK Post will put them in any city in NA in 5 days. Sometimes takes another 5 to get to your door. IIRC shipping on 5 was $34.
X-treme 3KW Scooter...OFF ROAD ONLY....Giant 1KW 48V 24" Hubmotor....E-Apex 1KW 48V 26" Hubmotor, built 2012-05-26
Thanks Justin, for saving ES. May Grin Tech grow and prosper.
ian.mich   10 kW
Post by ian.mich » Jun 19 2012 8:45am
XLR8 wrote:Has anyone enabled regen or EABS on one of Leo's controllers? I have the cruise and 3 speed features working but I haven't had any luck with EABS. These controllers are good value for money. I purchased a 60 volt 1500 watt controller for $42 delivered to the door, Australia. The motor runs just noticeably warm and the controller has no obvious heating at all on a normal ride around the streets with small hills.
apparently you merely apply a voltage to the single yellow wire, which i believe can be achieved with a switch between the single purple wire (brake lever) have not tried yet but i am getting a shipment of another 5 today, along with a 36 fet 4410s (i know i know, should go for 41s but there's no point when all it will use is 100A, the 44s have proven their use) so i'll get down to some real testing.
HypnoToad   100 W
Post by HypnoToad » Jun 19 2012 10:18am
ian.mich wrote:but they are real. i have next to me a 100v 45a controller that has regen, cruise, EABS, sensor and sensorless, and an X8M06 microprocessor. $43US including shipping (got it during a sale a few weeks ago)
How long did it take to arrive?
I'm after a 48v controller, and what are the benefits of these 4110 FETs in a 48v setup?
Thanks
ian.mich   10 kW
Post by ian.mich » Jun 19 2012 10:33am
Thanks
not sure, probably around 3 weeks, they're 4410 not 4110. 4110 are the mexican fets that everyones is looking for and they will use them for these controllers if you ask, but they use 4410 from stock and it's all you really need for almost any ebike (4410 are the chinese ripoff of the 4110). unless you are doing some serious biking (crystalyte 5400 series or hubzilla) you don't need 4110s, 4410s take 100v and with 15 of them 45A is nothing. I highly recomend contact leo on skype (leo840522) and not through aliexpress. he can set you up with a custom controller with any LVC and ask for all the features customized to your specs
Cruising Control
E-ABS/High Level Brake
Jeremy Harris   10 GW
Post by Jeremy Harris » Jun 19 2012 11:17am
ian.mich wrote: not sure, probably around 3 weeks, they're 4410 not 4110. 4110 are the mexican fets that everyones is looking for and they will use them for these controllers if you ask, but they use 4410 from stock and it's all you really need for almost any ebike (4410 are the chinese ripoff of the 4110). unless you are doing some serious biking (crystalyte 5400 series or hubzilla) you don't need 4110s, 4410s take 100v and with 15 of them 45A is nothing. I highly recomend contact leo on skype (leo840522) and not through aliexpress. he can set you up with a custom controller with any LVC and ask for all the features customized to your specs
Cruising Control
The IRFB4410 is a different FET from the IRFB4110 and is not "a chinese ripoff of the 4110". Both are IR parts (see : http://www.irf.com/product-info/datashe ... fs4410.pdf and http://www.irf.com/product-info/datashe ... 110pbf.pdf and compare the specs), both are widely counterfeited in China. More often than not the counterfeit parts are way off spec. Note the IR rated Rdson for the IRFB4410, 10 mohms!!! You can bet that the Chinese copies will be higher than that. Even if they aren't, then good IR manufactured IRFB4410s will have around 2.2 times the losses that an IRFB4110 would have, meaning they'll run around 2.2 times hotter and reach the thermal conductivity limit to the case much quicker, meaning a higher risk of failure.
ian.mich   10 kW
Post by ian.mich » Jun 19 2012 11:54am
Cruising Control
Fair enough, but these have been certified genuine 4410s by a local EE and other sources, and it's cranking 45A through 15 of them, i doubt there would be any problems
Jeremy Harris   10 GW
Post by Jeremy Harris » Jun 19 2012 12:03pm
There are still a very poor FET, even if genuine IR parts, with a high Rdson and so high losses and consequent risk of failure from over heating. An IRFB4110 has an Rdson of 4.5 mohm max, compared to the IRFB4410 figure of 10 mohm. That means, in simple terms, that one IRFB4110 = more than two IRFB4410s in parallel. In even simpler terms it means a 15 FET controller fitted with IRFB4410s is no better than a 6 FET controller fitted with IRFB4110s in terms of current handling capability (in fact it'd be worse than the 6 FET, as the 15 FET controller would have a higher total gate charge so would have slower switching times and hence greater switching losses, too).
liveforphysics   100 GW
Post by liveforphysics » Jun 19 2012 12:28pm
I would rather have a 6-fet made with 3077's for that voltage range of controller than a 15-fet made from 4410's, which you need twice as many of to equal a 4110.
ian.mich   10 kW
Post by ian.mich » Jun 19 2012 12:31pm
Still, it's $45 and you can get 4110s if you need. this controller handles 24s lipo no problem
Jeremy Harris   10 GW
Post by Jeremy Harris » Jun 19 2012 12:49pm
liveforphysics wrote:I would rather have a 6-fet made with 3077's for that voltage range of controller than a 15-fet made from 4410's, which you need twice as many of to equal a 4110.
Pretty much an unbeatable combination for a small controller at this spec point, in my view. Bare board 6 FETs from Keywin are ~ $20 each, add in 6 IRFB3077s at around $25 and you have a 65V + capable controller at 50 A + with very low losses.
