Starting a new thread for this motor.
Here are pics
http://mrbill.homeip.net/albums/tm48/index.html
Mine is the same but it has slots for vents not holes
4-5 pounds
http://mrbill.homeip.net/albums/tm48/efficiency_curves/tm48_efficiency.pdf
I'm not sure how accurate his dyno is and he is measuring full system efficiency (controller, mechanical losses, etc)
not exactly sure it is the same motor
the shaft on my motor is not turned down and the shaft is only just long enough to get a thin sprocket on
my motor is 2900rpm at 48v
phase resistance of around .25 Ohms
The transmag site appears to have just gone down
http://www.transmag.com but you can see it up on internet archive
The magnets are screwed on which is nice for high rpm application
here is the wiring code I got
A - black - ground
B - red - +5V
C - green - hall A
D - yellow - hall B
E - brown - hall C
F - blue - Ov temp signal (digital, 0 or 5v, can remember)
Here are pics
4-5 pounds
A - black - ground
B - red - +5V
C - green - hall A
D - yellow - hall B
E - brown - hall C
