The big Lebowski controller
Lebowski   1 GW
1 GW
Post by Lebowski » Aug 13 2012 8:00am
The finished controller. Unfortunately it does not have the impressive wiring spaghetti we're used to, two battery wires, three motor wires and (the thin wires) gnd, 5V and 2 throttle inputs.
6 FET 4568's, force cooled by blower
Wire stress relief
The cooler started out as a bunch of aluminium tubes
Surfaces are polished agains each other with 'jif', add plenty of lube
The idea is that air is forces through the tube and has lots of contact area with the hot aluminium
The duct between the blower and cooler is 4 flat pieces of 0.6 mm thick copper soldered together
Finished cooler
For the power line I used some 4x4 mm solid copper bar (it pays to have a good metal shop nearby :-)
The high/low side interconnect is made of the same copper bar, holes are drilled for 1.8mm thick copper wire to connect the FETs
Brand new FET, first order of business is to amputate all its legs....
I decided to move the gate resistors from the PCB to the 'legs'
Gate / source wires between drivers and FETs are twisted for low inductance and for low mutual inductance (not to catch any spikes from motor currents)
My setup
The main tools I used. These are the same that I build my entire motor with, you don't need a lot of expensive tools to build cool stuff !
Kingfish   10 GW
Re: Teaser
Post by Kingfish » Aug 13 2012 10:00am
Beauty!
Does it come in Black? Need a whisper fan?
Lead time? :twisted:
<snicker> KF
* My 2WD Garden Wall
* Kinaye MotorSports
* Epics: Going to California: 2011 8)
Philistine   1 MW
Re: Teaser
Post by Philistine » Aug 13 2012 10:05am
Is it a device for measuring the physical weight of verbs and concepts?
If so, how much and when can I get one?
EDIT: I don't care about colour, but mine needs a splash guard.
Lebowski   1 GW
1 GW
Re: Teaser
Post by Lebowski » Aug 13 2012 10:23am
Philistine wrote:Is it a device for measuring the physical weight of verbs and concepts?
hahahahaha :mrgreen: good one ! :D
I'll post more pictures tomorrow when I have the time
Ypedal   100 GW
Re: Teaser
Post by Ypedal » Aug 13 2012 10:32am
electronic panty remover ?
ES site status page:
The fingers   100 GW
Re: Teaser
Post by The fingers » Aug 13 2012 2:56pm
Looks bullet proof. :)
Black Schwinn High Sierra
Blue Schwinn Cruiser 5
Blue Schwinn High Plains
Black Fiore Cruzer 5: Amped Warp Drive 26" Front DD/SLA kit
http://ghostbikes.org/
http://www.rideofsilence.org/main.php
Hebrews 9:27
Lebowski   1 GW
1 GW
Re: The big Lebowski controller
Post by Lebowski » Aug 14 2012 2:00am
Finally added lots of pictures to the first post :mrgreen:
VoKuS   100 W
Post by VoKuS » Aug 14 2012 2:13am
Looks powerful!
Is this going to be for sale?
'The Hyena Industries GoPro A Team' ! :)
hjns   100 kW
Post by hjns » Aug 14 2012 2:27am
To me it looks just like a big noisy paperweight..... :twisted:
Bas, you really should get it patented!
Henk
All men dream: but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible. T.E. Lawrence
neptronix   100 GW
Post by neptronix » Aug 14 2012 4:16am
Very cool :]
Philistine   1 MW
Post by Philistine » Aug 14 2012 6:45am
Mr Dude (Sir),
Can you throw on some funky Bass riffs and funky wa wa guitair on in the background, put on a Barry White voice (I can do that part in my head if you like), and give some more details on specs and what kind of power it can take, and is it avaialable for sale in the future?
Easy for you to make the comments about tools, I couldn't make anything look that tight and nice even if it did nothing functionally. I can make zip ties look like they were attached without care.
Lebowski   1 GW
1 GW
Post by Lebowski » Aug 14 2012 7:41am
To be honest I got no clue about how much power it can take. It uses 150V FETs and has 150A current
sensors (150A amplitude, not RMS). But long before 150A the FETs will burn out due to insufficient
cooling, it'll be a case of slowly upping the amps and see how hot it gets. Member 'hjns' has kindly
offered me to try it out on his Cromotor equipped bike, with 20s lipo (maybe 30s). I'm expecting this
to be a test until it blows up (be easy to fix though as I designed and built it).
I don't plan to sell controllers like this as it took me more than a month of hobbytime to build, there's
lots of work in the cooling hardware and box. The intention is to sell PCB's and the main IC's so people
can colder the PCB's themselves and build whatever box / cooling system they want. Also, mine is outfitted
with 150V FET's, you can just as easely (with the same PCB etc) use 100V FETs with a lower on-resistance
to tune it more towards whatever motor you have.
hjns   100 kW
Post by hjns » Aug 14 2012 7:46am
what about 35S (147V HOC) ? :mrgreen: :mrgreen: :mrgreen:
Henk
Philistine   1 MW
Post by Philistine » Aug 14 2012 8:07am
Respect, I was kind of fantasising in asking if it would be for sale. The way you did the Fets looks so convenient to me, even a monkey like me could solder in replacements when set up like that. Congrats on designing and building it.
salty9   1 kW
Post by salty9 » Aug 14 2012 9:34am
Had you considered using a coiled aluminum sheet for the interior of your heat sink? You should be able to get a larger surface area and decreased mass.
John in CR   100 GW
Post by John in CR » Aug 14 2012 11:07am
Beautiful! I feel the need to now call you Sir Lebowski unless you prefer simply Mister Lebowski. With a board and a shopping list is it realistic for a caveman solder slinger to pull it off, or can I just take a box of stuff and the schematic to a local electronics repair shop for assembly? Yes, things actually get fixed here instead of dropped at the curb for recycling, so a pro solder slinger is easy to find.
I can only imagine how well and how efficient 2 of these would drive my 6 phase motors, because I know yours doesn't have this confounding jerk of a start I still suffer with.
John
TylerDurden   100 GW
Post by TylerDurden » Aug 14 2012 11:41am
Dude! :mrgreen:
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
Kingfish   10 GW
Post by Kingfish » Aug 14 2012 12:02pm
No man, he is The Dude! Nothing less will do.
Or perhaps...
The Dude wrote:Let me explain something to you. Um, I am not "Mr. Lebowski". You're Mr. Lebowski. I'm the Dude. So that's what you call me. You know, that or, uh, His Dudeness, or uh, Duder, or El Duderino if you're not into the whole brevity thing.
So freakin' awesome! What else can it do aside from going forward fast? :twisted:
Cheers! KF
Njay   10 kW
Post by Njay » Aug 14 2012 12:46pm
What a fantastic work Lebowski :)! You sure are an inspiring dude :)
John in CR   100 GW
Post by John in CR » Aug 14 2012 12:58pm
I stand corrected, The Dude :mrgreen:
cal3thousand   1.21 GW
1.21 GW
Post by cal3thousand » Aug 14 2012 2:13pm
The dude abides!
Woah, that is one beautiful thing. Especially after looking at the internals of my crappy chinese knock off controller and the build quality. Those copper bars are solid! Love it.
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
circuit   100 kW
Post by circuit » Aug 16 2012 2:03am
Why are there 3 current sensors instead of 2?
The controller looks OK as a testing platform, but I just can't see a product any time soon. I really want to, but can't.
smart and Tiny BMS solution
Visit my blog. Personal projects: Clean Peugeot conversion | Ultralight enduro
Any and all information, such as texts, specifications, drawings or other material that I post are to be used only as a reference for personal, non-commercial projects ONLY. Any republication for personal or commercial needs must be agreed on individually. Use of any information, that I post, for commercial purposes is strictly prohibited.
Lebowski   1 GW
1 GW
Post by Lebowski » Aug 16 2012 5:41am
circuit wrote:Why are there 3 current sensors instead of 2?
Well, it's not my intention to build and sell complete controllers, at the moment I'm just in this for the
hobby. What I can sell is PCB's and programmed IC's so that people can build their own controllers. What John suggests
is very well possible. Or maybe someone who likes soldering and building can build and sell controllers based
on my IC's and PCB. My intention and interest is to develop my controller IC further and to include power
startup with full torque at motor standstill, without hall sensors. My interest is in the algorithm running on the
MCU, less in soldering everything together and building controller boxes. I build the box of the first post because
I want to try out my algorithm on a powerful motor, and as a demonstrator to show that the algorithm works.
About the current sensors, theoretically 2 sensors (lets say Ia and Ib) are enough because the current in the 3rd motor wire (Ic)
can be calculated with
Ic = - Ia - Ib
But typically the sensors pick up noise from their supplies etc, a noise which can be in a large part common in all sensors.
Ia = Ia_wanted + I_noise
Ib = Ib_wanted + I_noise
then
Ic = - Ia_wanted - Ib_wanted - 2 * I_noise
So with 2 sensors all the noise gets assigned to the 3rd motor wire.
With 3 sensors though the noise part common to all sensors (the I_noise) can simply be filtered out by the
algorithm running on the MCU....
Jeremy Harris   10 GW
Post by Jeremy Harris » Aug 16 2012 5:57am
Looks very good to me. I particularly like the cooling arrangement, very neat. My guess is it took longer to build that bit than assemble the rest of the controller!
I always find building the hardware of any project like this the hard part, it always seems to take more effort to get the physical layout neat and the housing OK than it does to do the electronic stuff.
drewjet   10 kW
Post by drewjet » Aug 16 2012 6:09am
Lebowski wrote:The finished controller. Unfortunately it does not have the impressive wiring spaghetti we're used to, two battery wires, three motor wires and (the thin wires) gnd, 5V and 2 throttle inputs.
So this will only run sensorless?
How well will it drive an RC motor? either Astro or 80/100.
