Jayls5
I've decided I want to avoid the chain drive route for noise reduction.
Dimensions of motor shaft: 7/8"x 1-5/8", 3/16" key
Random details: Motor will run at 74V nominal load (ball parking 3000 rpm, correct me if I am wrong). Total vehicle weight will be 100-200 lbs max. Not sure of final drive goal yet or even size of driven wheel; it's contingent on what I end up wanting to do.
Regardless, I'm having a really hard time getting ANY toothed pulley setup that bolts directly on this shaft. I'd like to get the drive pulley picked out before I bother with the driven side, but I'm not having any luck. I'd like to start as small diameter as possible and work from there.
What are the best suppliers of pullies, tensioners, and belts that would fit my needs (USA)? Thanks.
