How to improve cooling in Cyclone motor?
andrenoites   100 W
Post by andrenoites » Nov 18 2013 9:31am
Did anyone tried to improve cyclone cooling by adding thermal paste between the stator and the motor housing?
stator removed cyclone.jpg (110.91 KiB) Viewed 1522 times
source of the photo: http://www.endless-sphere.com/forums/vi ... f=2&t=8621
The thermal sensor is in the stator and it will cut off power at 85ºC
At this temperature the motor cover it's only at 48ºC so I think there is much room to improvement here.
No need to add aluminum cooling fins until the contact between the stator and the housing it's fixed. It just isn't efficient.
Cheers,
André
kfong   1 MW
Re: How to improve cooling in Cyclone motor?
Post by kfong » Nov 18 2013 9:40am
What about oil cooling, seems to have worked with hub motors.
andrenoites   100 W
Post by andrenoites » Nov 18 2013 10:40am
kfong wrote:What about oil cooling, seems to have worked with hub motors.
It's a idea!
But still I would prefer something more simple and less messy
h0tr0d   1 kW
Post by h0tr0d » Nov 26 2013 9:33am
I saw a Russian guy put a blower on flat part of the casing (red) and drilled holes (green), 7000W. His blog is offline now... :(
stator removed cyclone.jpg (28.09 KiB) Viewed 1448 times
André, és da região de Lisboa?
Thank you Justin! Life is so much sweeter with this forum... ;)
jateureka   10 kW
Post by jateureka » Nov 28 2013 2:25pm
Yes, he stuck a fan on the motor similar to an alternator http://endless-sphere.com/forums/viewto ... =2&t=42812
E-bikes: Bafang 8FUN; Mac; Ezee; FreeGo; Aprilia 7s LiPo; eLation V2; TerraTrike recumbent
E-motorbikes: ZEV 7100 LR scooter, 84V 60Ah LiFePO4.
ZERO 2011 S motorcycle, 51.8V 70Ah LiMno2, 2012 headlight, Kilovac EV-200 contactor
E-mower: EGO 56V mower & line trimmer
Dlogic   1 kW
Post by Dlogic » Dec 10 2013 12:29pm
For my first ever e-bike build a new housing was made for the cyclone motor.
I lived in Spain back then and especially during the hot summer month the motor overheated quit often.
After this modification it was run at approximately 1,2 Kw and never failed again. :mrgreen:
