onloop
- Joined
- Jun 24, 2013
- Messages
- 600
Hi,
I thought i would start a new thread on this topic....
I started reading the thread Conclusive proof gearboxes are awesome and I have been thinking about this topic for my skateboards.
Unlike bikes / cars or any larger EV... skateboards don't have much space to mount mechanical systems or extra battery cells to improve the DC motors range of performance.
So if electrickery can be used to improve motor speed & overall vehicle performance that would be fantastic... But i can't seem to get much info about.
So why don't more people talk about this Field Weakening topic?
1. is it just because it is not a reliable or efficient way to run an EV?
2. its cheaper / easier to use more cells in your batteries?
3. its cheaper / easier / more reliable to use mechanical systems?
I suppose the other idea i had was stepping up the voltage of your battery using a transimpedance amplifier... (convert capacity for higher volts?) to make motors spin faster when not under big loads... such as perfect flat (or slightly sloping downwards) ground.
