Motor comparison spreadsheet
Arlo1
Re: Motor comparison spreadsheet
Post by Arlo1 » Jan 26, 2016 12:18 am
crossbreak wrote:
Lebowski wrote: Battery current is not equal to phase current at full rpm...
At no load and 100% duty, input should be equal to output? where is the rest? what is the part that's lost?
Its not lost.
The system is still working as a buck converter. Except in the case when some field weakening is used. Then its working as a boost converter.
But non the less its always changing the DC amp Volts around the something different in AC amps and Volts. Its never the same on both sides.
My Leaf motor controller build. viewtopic.php?f=30&t=63982&p=963227#p963227
My YSR build http://www.youtube.com/watch?v=BRo8r5g4NBg
RC and most types of Lithium batteries you MUST know your individual cell voltages charging and discharging.
Don't keep them were you cant afford smoke or fire!
HI power controller design. Game Changer
http://www.undergroundelectrics.ca/
crossbreak
Post by crossbreak » Jan 26, 2016 12:56 am
At 100% duty cycle, a buck converter does not lower the voltage any more. Input and output are directly connected as the MosFET is on 100% of the time. In a 3 phase converter, the current is distributed to 3 phases. as peak voltage=Battery voltage, battery current must be the same as RMS phase current. So nothing gets lost.
John in CR
Post by John in CR » Jan 26, 2016 6:26 am
crossbreak wrote:At 100% duty cycle, a buck converter does not lower the voltage any more. Input and output are directly connected as the MosFET is on 100% of the time. In a 3 phase converter, the current is distributed to 3 phases. as peak voltage=Battery voltage, battery current must be the same as RMS phase current. So nothing gets lost.
Zombiess measured that they never actually get to 100% duty and Lebowski said that they're not equal, so I'll stick with them.
Arlo1
Post by Arlo1 » Jan 26, 2016 10:41 am
crossbreak wrote:if there is no controller that does so, then lets build one. Why waste this potential?
Its not potential at all.
The sine wave from the motor does not match the Square waveform you would get from full block communication from the battery.
You have to remember at full rpm the controller will pwm voltage from the battery that's higher then the back EMF at that very spot on the sine wave then the back emf at peak of the sine wave will climb above the voltage from the battery. Having the Controller hold the IGBT or Mosfets on for the whole length of the sine wave is stupid.
Also remember its also a combination of what's stored in the Caps in the controller it self.
crossbreak
Post by crossbreak » Jan 26, 2016 11:35 am
what i see on the pic i just made with my DSO is not 100% duty at the rise and fall edges of the trapeze. But at least it looks like in the middle :?
the controller does 20 khz PWM (i think) it is a x8m06c from BMS battery. So I sould be able to see about 10 PWM cycles on the "tip" of the trapeze at 5µs capture.
crossbreak
Post by crossbreak » Jan 26, 2016 11:56 am
pics above where at full throttle. This one is at almost full throttle. You can clearly see that it does PWM at the tip of the trapeze
crossbreak
Post by crossbreak » Jan 26, 2016 12:46 pm
Did some more measurements with the BPM 11T and x8m06c controller
peak to peak phase voltage is a little less then 100V, i read from the DSO pics (1:10 probe)
RMS phase to phase voltage: 36.9 V
RMS phase current at 1 phase: 1.699A
apparent power: 62.7 VA
Battery voltage: 48.8 V
battery current: 1.083 A
effective power: 52.85W
phase to ground AC: 22.08 V
phase to ground DC: 24.01V
frequency between phases: 218 Hz measured by UT139C DMM
looks like it is not doing PWM at Full Throttle but it's not putting out an RMS phase voltage that is equal to battery voltage, too. This is my bad, sure it cannot output RMS phase voltage close to battery voltage, it can just output peak phase voltage that is close to battery voltage. The difference should be √2 for a sine wave. The trapezoid wave comes close to this figure.
In addition to this, RMS phase current will not be close to battery current at full throttle as the motor itself has inductance and thus a reactive current is flowing that adds up geometrical to real phase current
Arlo1
Post by Arlo1 » Jan 26, 2016 1:01 pm
Looks like a waste of energy to me.
Also watch out the little DSO scopes are just toys for kids they don't have the resolution to catch the small PWM events and other things we usually look for with a scope.
I keep mine in my back pack for emergency ICE motorcycle diagnosis. And I use my 100Mhz scope for the real work... (which I'm also looking to upgrade accepting donations :) )
crossbreak
Post by crossbreak » Jan 26, 2016 1:05 pm
at no load conditions there is no energy wasted. FOC controllers seem to use the same amount of energy at this condition. Energy savings seem to rise with current for trapezoid vs FOC
Arlo1 wrote:Also watch out the little DSO scopes are just toys for kids they don't have the resolution to catch the small PWM events and other things we usually look for with a scope
sure screen and vertical resolution is low, but you can clearly see PWM event if zooming in
next queston is: Is resistive power calculated right in the spreadsheet? As phase current seems to be at lest √2 larger than assumed, resistive loss should be at least 2 times larger (as reactive current additionally adds up geometrically). Something tells me that it cannot be 2 times larger as there are 3 phases and not just 2. But we measure resistance only across two phases (so called terminal resistance)
Arlo1
Post by Arlo1 » Jan 26, 2016 2:01 pm
John in CR wrote: Zombiess measured that they never actually get to 100% duty
This was just a test for full throttle at lower then max rpm.
I also did this test and found random 400+ uS on pulses with full throttle at lower then max rpm, which explain some of my failures trying to run low inductance motors.
crossbreak
Post by crossbreak » Jan 26, 2016 2:06 pm
i dont get it? doesn't full throttle account for max rpm for a given battery voltage? (without using flux weakening).
Maybe some controller do 100% duty at max rpm and some dont? i remember the Kelly KBS-X had a shape much closer to a sine wave with almost no 100% duty period at the tip. I took that measurement with a better osci back then
Arlo1
Post by Arlo1 » Jan 26, 2016 2:15 pm
What I am pointing out is when the motor has a load on it and is accelerating from 0-max rpm its not yet at max rpm its at something LOWER THEN MAX RPM we were concerned the PWM was going to full block communication (NO PWM JUST ON OR OFF) but Zombies and I tested this at LESS THEN MAX RPM WITH FULL THROTTLE.
We were not looking for max rpm unloaded we did not care about that.
Yes some controllers are different for sure.
MOST SINE if not all sine controllers will not go to full block communication ever. You can not get a sine wave if you do.
crossbreak
Post by crossbreak » Jan 26, 2016 2:37 pm
thx, got it. that wasnt no load. Cannot do any loaded testing though. Sadly i have got no dyno... would be nice to make some loaded tests and measure torque
did not find the old shot from the kelly measurement, i'll repeat that when i find the time. ATM i'm reading a bit about reactive current in BLDC machines... may have some influence, need to dig out some formula to predict it's influence on rpm and resistive loss. I think for motors that have a lot of inductance like the MAC Hub motor, it may have noticeable influence
sure, that is also a reason why you get a different max rpm figure at the same battery voltage. And thus you calc a different (higher) Kv. A 13% higher Kv leads to a 28% lower Km² and thus a 28% higher resistive loss
At the end of the day, this would not matter if we all would use the same equip to measure motor constants...which isn't the case unfortunately
Miles
Post by Miles » Feb 06, 2016 1:42 pm
Some measurements of phase to phase resistance on a couple of Astroflight 3210 motors that I have to hand.
Measured at 20 deg. C.
3210 12t
A-B: 0.1648 ohms
B-C: 0.1651 ohms
A-C: 0.1705 ohms
[specification: 0.190 ohms]
3210 7t
A-B: 0.0625 ohms
B-C: 0.0607 ohms
A-C: 0.0607 ohms
[specification: 0.060 ohms]
3210 6t
A-B: 0.0440 ohms
B-C: 0.0423 ohms
A-C: 0.0417 ohms
[specification: 0.045 ohms]
crossbreak
Post by crossbreak » Feb 06, 2016 3:59 pm
Nice to measure all three. I always take the mean of the three...still nice to see all of them and she how they differ.
Now that you have your meter. What does it show you if it connects to one of shunts I sent you?
Miles
Post by Miles » Feb 06, 2016 4:51 pm
crossbreak wrote:Now that you have your meter. What does it show you if it connects to one of shunts I sent you?
0.005014 ohms.
It's not quite the same as the one you have. I got this one: http://www.ebay.co.uk/itm/White-OLED-Fo ... SwYIhWlb1j
Miles
Post by Miles » Feb 12, 2016 8:44 am
Here's the complete measured data for the Astro 3210 12t [manufacturers data in brackets].
Controller: Castle Creations Phoenix HV85
Rm: 0.167 ohms [0.19 ohms]
Kv: 113.8 rpm/V [113 rpm/V]
N.L. amps @ 2930 rpm: 0.43A (battery side) 0.33A RMS (phase)
N.L. amps @ 5458 rpm: 0.50A (battery side) 0.39A RMS (phase)
[0.5A at 7500 rpm??]
Weight 0.957 kg [0.964 kg]
Miles
Post by Miles » Feb 13, 2016 6:39 am
Astro 3210 7t
Rm: 0.061 ohms [0.06 ohms]
Kv: 206.5 rpm/V [194 rpm/V]
N.L. amps @ 5334 rpm: 0.85A (battery) 0.67A RMS (phase)
N.L. amps @ 9894 rpm: 1.12A (battery) 0.89A RMS (phase)
[0.9A @ 7500 rpm?]
Weight: 1.022 kg [0.964 kg]
Miles
Post by Miles » Feb 13, 2016 6:42 am
Astro 3210 6t
Rm: 0.043 ohms [0.045 ohms]
Kv: 234.9 rpm/V [225 rpm/V]
N.L. amps @ 6067 rpm: 0.85A (battery) 0.77A RMS (phase)
N.L. amps @ 11227 rpm: 1.14A (battery) 0.93A RMS (phase)
[N.L. amps @ 7500 rpm: 1.0A]
Weight: 1.028 kg [0.964 kg]
teslanv
1 GW
1 GW
Post by teslanv » Mar 26, 2016 1:41 pm
MXUS 28mm DD Hub, 12X5T Winding, V2 Stator
Phase Resistance: 0.122 Ohms
No Load Current: 1.64 Amps, at 50V
No Load Power: 82 Watts, at 50V
Bare Motor Weight: 6.45Kg
RPM Per Volt: 596 RPM/50V = 11.92 Kv
I build custom ebikes.
http://www.westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
redline2097
Post by redline2097 » Mar 28, 2016 2:39 am
What would be ideal high toruq, highpower under 12lbs motor to 16" dirt bike? I am looking for Revolt 120 Pro but is there any better with more torque? :)
crossbreak
Post by crossbreak » May 11, 2016 11:51 am
https://endless-sphere.com/forums/viewt ... 9#p1166771
VasiliSk wrote:Got this data from RV160 short
80mOhm
33.36kV (RPM/V)
this gives me 39.6Nm on shaft of motor with 180 phase amps
so this motors Km² is only ~1 :( weaker than the RV120 that gets 1.6 if we can trust the specs from Revolt
justin_le
Re: Motor comparison spreadsheet, add simulator link?
Post by justin_le » Nov 09, 2017 4:22 pm
Just an idea here but since we've now added the ability to input a custom motor on the ebike simulator page ( see https://endless-sphere.com/forums/viewt ... 2#p1324922 ), you could in principle add a column to this spreadsheet that uses the string and math functions to produce a direct URL for viewing this as a custom motor in the online simulator. The only thing missing in your columns right now is the one for the inductance, but everything else is there.
For instance, if we look at the Joby JM1S motor, we have
11 pole pairs
94 rpm/V
.015 ohms
0.107 Nm hyst trq
0.00007 Nm/rpm eddy trq, which is .0000073 Nm/Rad/sec
If I assume that the winding inductance is .05 mH, then this can be expressed in the custom URL string as motor=cust_94_0.015_0.05_11_0.107_0.000007_0
The order is just KV_Ohms_mH_PolePairs_Hyst_Eddie_TransmissionLoss Append it to the URL like this:
http://www.ebikes.ca/tools/simulator.ht ... 0.000007_0
Of course the default shows it directly coupled to a 26" wheel diameter, while a motor like this would be geared down, so it might make sense to have the string default an initial effective wheel size based on the KV. Here's a more realistic set of parameters for this motor on an ebike:
http://www.ebikes.ca/tools/simulator.ht ... A&cont=C35
Big Dummy Frame (yes This One, thanks ES!) with prototype 26" Grin all-axle front hub, Phaserunner controller, and 52V 11Ah Cellman triangle pack
My website: http://www.ebikes.ca
Please contact via email, info@ebikes.ca, rather than PMs, which are disabled
