Leaf / leafmotor / leafbike high efficiency 1500w motor
Cowardlyduck   100 MW
Re: Leaf / leafmotor / leafbike high efficiency 1500w motor
Post by Cowardlyduck » Sep 26 2020 10:05pm
neptronix wrote:
Sep 26 2020 9:35am
That's a beautiful sight, my dude :mrgreen:
I never took mine past 6kw due to the simple fact that i couldn't keep the front wheel on the ground.
Rad to hear that someone has finally taken it to max :)
Thanks!
I actually did it several years back. At one point I was even playing around with it at 8.4KW and it was going ok till I killed my Adaptto MiniE. After I replaced it I decided to tone it down so I didn't kill the next one.
I also did the same on a Crystalyte HS4080. Worked a treat and both motor's/wheels went together with my Fighter when I sold it earlier this year.
Pushing hubs like this to the limit was fun, but as many others state, it's not using the right tool for the job once you go that far over the rated spec. I would certainly do it again for the right situation, but where the opportunity exists to use a better tool (i.e. beefier hub, or mid drive) then that should be the first option.
As a point of comparison, my LMX64 with it's mid drive has the same pull at 2.5KW that my Leaf did at 7.5KW and doesn't need any cooling mods.
Cheers
My stuff:
Ebike Garage - My YouTube Ebike ramblings.
Cowardlyducks - Videos - Ride videos
BikeE recumbent commuter - 9C, 6Fet Grinfineon, internal 17AH, 52V, + on-board solar.
For Sale:
Custom made 18650/21700 battery packs - Australia only
High Power LiPo wiring harnesses - 4P - XT90, HXT4mm, 5.5mm. 200Amp+ capable. Global shipping.
markz   100 GW
Post by markz » Sep 29 2020 1:55am
ZeroEm wrote:
Sep 26 2020 9:53pm
Hub Monster's
Its just a scooter motor, you'd have to find out what it came out of and that info is out there.
ZeroEm   10 kW
Post by ZeroEm » Sep 29 2020 2:08am
ZeroEm wrote: ↑Sep 26 2020 9:53pm
Hub Monster's
That is like me doing this
just a scooter motor.
abundans cautela non nocet
2019 Performer E-Trike 9w/km
2013 Nissan Leaf S 7 bars 331.5w/KM
