Triple solid slot Zero 75-7
Ohbse   10 kW
Re: Sextuple Zero 75-7
Post by Ohbse » Jul 06 2015 8:51pm
Farfle wrote:
Ohbse wrote:Very cool indeed.
Given that you're going to one turn, wouldn't this be an ideal application for an extruded/pin type 'winding'? or are there disadvantages compared with conventional stranded stuff?
If I had a super badass 2400A controller, It would already have TIG welded copper bars in it. BUT, I need to split it up into six seperate strands. So I haven't come up with a way to do that yet.
So obviously you found a way around the previous hang up, what are you doing for controller/s now? Awesome work, so keen to see this thing come together and RIP. Interesting to read through the other potential losses that come with the larger conductors.
madin88   100 MW
Re: Triple solid slot Zero 75-7
Post by madin88 » Jul 07 2015 2:33am
impressive improving in copper fill!
- 10kW belt drive with Neumotor 8057: viewtopic.php?f=30&t=91144&start=50#p1377787
- Fully road legal (L1E approval) e-bike based on Votec V-FR frame
/ MXUS 3T / 17" Mitas MC11 / Adaptto Max-E / 20s12p 25R
Doctorbass   100 GW
Post by Doctorbass » Aug 17 2015 10:31pm
any update yet Farfle?
Doc
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
athlon   100 mW
Post by athlon » Aug 23 2015 5:53pm
flathill wrote:http://eprints.whiterose.ac.uk/9077/1/Zhu_Influence.pdf
Note the 1 strand winding has 35 turns (2.65mm) is the thickest they try and you can see the AC losses started to rise faster and faster as the wire size goes up
Don't let this stop you but just something to think of when sizing the conductors. You may want to keep them away from the maximum leakage flux area in the slot
interesting document , also it points out that 2 layer windings have higher loss for added interference between 2 phases , 1 layer windings have higher loss for longer end turn but maybe with the better copperfilling of 1 layer and also with this reduced interference 1 layer windings can still be an option insted of the more common 2 layer windings
h0tr0d   1 kW
Post by h0tr0d » Sep 15 2015 2:53am
Farfle,
Does the CAD estimate the motor weight?
micahbayless   1 µW
Post by micahbayless » Mar 13 2016 1:26pm
update update update? ReFuel May 22... will you be there?
http://www.refuelraces.com/about.php
macribs   1 GW
1 GW
Post by macribs » Mar 14 2016 10:51pm
This I got to see.
Hillhater   100 GW
Post by Hillhater » Mar 17 2016 4:42pm
Did this project get completed ?...shelved ?....or has it gone "black" ? :?:
macribs   1 GW
1 GW
Post by macribs » Mar 17 2016 4:52pm
Hillhater wrote:Did this project get completed ?...shelved ?....or has it gone "black" ? :?:
Shelved maybe? I see Farfle is still active on ES just not on this very thread.
Farfle   1 MW
Post by Farfle » Mar 25 2016 10:50pm
sorry guys, just busy with work stuff.
Test Review Revise Repeat
