Best 48V 250W hub motor for hot rodding?
davidsvoboda   100 W
Post by davidsvoboda » Aug 17 2015 6:33am
Hi, so I am considering buying a street legal hub motor for my 48V 15Ah battery (capable of 100A maximum output).
Which hub motors are best for "hot rodding" - would I be able to run some as high as at 750Watt and still maintain the appearance of a legal 250W motor?
Thank you!
David.
motomech   1 GW
1 GW
Re: Best 48V 250W hub motor for hot rodding?
Post by motomech » Aug 17 2015 9:22am
Where do you live that having a motor rated at 250 Watts is important(Nobody fills out their profile these days)?
750 Watts is only 15 Amps on a 48 V battery and any 250 W rated motor will do that, provided it's not asked to climb long, steep hills on a 90 Degree day.
The 350 W minis will take up to 20 Amps.
The key is to match the motor speed rating to the intended usage.
Motomech
'03 Rocky Mountain Edge 2WD 260 Q100H frt and Ezee V1 rear 2 Elifebike 20A & 25A 9-FET controllers 12S/10Ah Multistar Lipo rear 4Ah Turnigy frt Luna Cyclops Extra lite Alex 24DM rims, Crazy Bobs run ghetto tubeless. 25 mph. Mean Well HLG-320H-54A
https://endless-sphere.com/forums/viewt ... =3&t=83430
'07 GT Idive 4 4.0, Q100C 201 14S LiPoly elifebike 9-FET 20A controller. 23 MPH.
https://endless-sphere.com/forums/viewt ... 4#p1378484
davidsvoboda   100 W
Post by davidsvoboda » Aug 17 2015 11:03am
greeting to mexico!! :)
I will be going for my masters to the United Kingdom - Brighton, I am worried my current set up - monstrous 3 Kw turbo bike kit mid drive will get me in trouble if I ride it there to school daily.. :/
motomech   1 GW
1 GW
Post by motomech » Aug 17 2015 1:54pm
Salutos,
Britton, Euro regs, I should have guessed. Your use of the term "hod rod: threw me off :lol:
Mini's range in weight from the teeny tiny 1.85 Kg Q85 to the over-weight mini Q128 at 3.0 Kg.
In general, the more a motor weighs, the more power it will handle.
An exception to that rule are the 350 to 400 Watt Q100 "H" models, That are the same size as the standard Cutes, 2.1 Kg.
We suspect they are fitted with higher power magnets.
I have run them @ 44V/22 Amps, or 970 Watts, although E life Bike offers a 9-FET 19 Amp controller that is a little more reasonable and combined with a Q100H, makes for the best "mini hot rod" combo I.M.O.
At one time, there were some folks offering 250 Watt stickers on the Sale section @ Pedelecs UK. You might see if they are still available.
Motomech
Russell   10 MW
Post by Russell » Aug 17 2015 2:27pm
davidsvoboda wrote:Hi, so I am considering buying a street legal hub motor for my 48V 15Ah battery (capable of 100A maximum output).
Thank you!
David.
I would not consider 750W to be "hot-rodding" a 250W motor unless you are planning to use that power continuously. For example I run my YOUE 250W geared motor at 1000Wp however I pedal all of the time and ride at (mostly) moderate speeds keeping my average power consumption to less than 250W. If you plan on using average power levels higher than rated then you should consider oil cooling the motor.
-R
Jeep Comanche Trekking Bike w/YOUE geared motor, 42 lbs + 15 lb rear trunk bag w/12S 16Ah LiPo battery, tools, etc., 21A controller, 700 x 40C tires. 27 MPH.
My other E-Bikes: Nashbar Steel Flatbar
davidsvoboda   100 W
Post by davidsvoboda » Aug 18 2015 2:00am
so I won't do wrong if I go with this one- http://www.elifebike.com/peng/iview.asp ... RK1S.8TKFU
I would like it to be fairly lightweight too - maximum 3 kilos. And - do you I just order a controller for 48V 750W motor and run it with it and that's gonna do the trick?
Thank you!
Russell   10 MW
Post by Russell » Aug 18 2015 11:59am
davidsvoboda wrote:so I won't do wrong if I go with this one- http://www.elifebike.com/peng/iview.asp ... RK1S.8TKFU
Thank you!
That motor has a wider dimension than the standard 135mm at 144mm plus it's a 1 speed. Is that what you want?
What size wheel are you using and what is your desired unassisted top speed? Once you answer those questions you can determine the rpm of the motor you will need. Getting the motor that spins at the desired RPM/V can be difficult as most vendors don't seem to understand the concept. Usually the RPM they quote is for a nominal 36V...but not always.
I really like my 8 RPM/V YOUE 250W motor for its combination of torque, speed (27 mph 12S LiPo 700Cx40mm) and serviceability.
http://www.aliexpress.com/item/36V-48V- ... 38628.html
I've also enjoyed the 2 (front) MXUS geared motors I've owned. The 6.6 RPM/V model was a little brute while the 8.9 RPM/V model was fast (29 mph on 12S LiPo/700Cx40mm) but lacked low-end torque. I would love to find one somewhere in the middle.
http://www.aliexpress.com/item/36V-48V- ... 94600.html
http://www.aliexpress.com/item/36V-48V- ... 75185.html
You really can't go wrong with a Bafang, either the front SWXK5 or rear SWXH though they generally only come in a slow wound version. I don't know anyone who has tried their latest smaller SWXU model.
The Cute Q100H is generally the go-to motor for those who want the smallest motor that can still handle some power. I've only used the regular 201 RPM Q100 (actual 6.4RPM/V) so I can't comment on the H's performance. The standard Q100 isn't particularly strong but I did appreciate the ability to use a 160mm disc with a conventional alternating lacing pattern and its smooth operation. The 260 RPM Q100H does provide decent speed in a 26" or 700C wheel when used at 48V.
Yes there are lots of choices but as I said you can narrow it down by determining the parameters that are important to you;
wheel size used
speed desired
front or rear application
freewheel or cassette
disc compatibility
serviceability
-R
davidsvoboda   100 W
Post by davidsvoboda » Aug 19 2015 2:16am
Thank you!
wheel size used
speed desired
disc compatibility
serviceability
-R
Thank you so much! I definitely need rear wheel (because I have 20mm axis on the front Marzocchi fork)
Wheel size- 26inch
speed unassisted - lets say 22 (miles per hour) maximum would be great.
rear
disc needed for 160 mm disc brakes..
also if I could have some cassette there that would allow me to change gears, that would be great, as I would like to take it off road also..
