izeman
1 GW
in another thread i wrote about my idea of a motor test stand. and i've already selected 30x 100w resistors to make them a 3kW load.
but i'd also like to try to use a 2nd controller for the generator in REGEN mode to generate the load.
unfortunately all infineon/xie chang/etc type setup software only lets you choose between 3 different levels.
i'd like to use the controller while doing regen in the same way (power wise) as it behaves while accelerating. so if i have a 12FET rated for 4kW motor load i'd like to enable regen and get 4kW (or any other similar number) REGEN. is this possible, and if yes: how? some kind of hardware mod, or maybe i over looked something in the setup software??
