Sunwinn 1500W controller wiring with 9C hub motor
davidsvoboda   100 W
Post by davidsvoboda » Jan 29 2016 1:24pm
Hi, I just bought this controller : http://www.amazon.com/Sunwin-Electric-B ... B00DBM9HSK
Is anyone here running it with 9C hub motor and would be so kind to tell me the wiring combination (hall and phase)?
Thank you so much!! :)
stevc   10 W
Re: Sunwinn 1500W controller wiring with 9C hub motor
Post by stevc » Jan 29 2016 7:54pm
Could be self study (join 2 white wires with matching connections)
connect motor and hall wires, matching colors.
connect power.
you don't need the throttle yet.
identify the on / off wire (lock, should be red), connect to positive.
motor will run and self study. if in reverse direction, disconnect and reconnect white wires.
If it runs properly disconnect white wires.
Now you can use the throttle.
httpwww.soonwell.comebay_fileuser_manualController-Wiring-Guide.pdf
davidsvoboda   100 W
Post by davidsvoboda » Jan 30 2016 10:27am
stevc wrote:Could be self study (join 2 white wires with matching connections)
connect power.
what?
stevc   10 W
Post by stevc » Jan 30 2016 9:44pm
A few people here have bought Sunwin controllers, can they confirm the self study operation.
999zip999   100 GW
Post by 999zip999 » Jan 30 2016 11:49pm
What's the anti theft and alarm connectors do ?
davidsvoboda   100 W
Post by davidsvoboda » Feb 01 2016 5:02am
connect power.
Is it really this simple? I have never heard of this test.. So I dont have to try all the 36 combinations?
drewjet   10 kW
Post by drewjet » Feb 01 2016 5:34am
Yes it works
davidsvoboda   100 W
Post by davidsvoboda » Feb 01 2016 5:40am
Can I than ask what exactly is the procedure?
This is as was posted above:
connect power.
and this is different instructions found on the internet:
1. Make sure your battery / power supply can deliver enough power.;
2. Plug in the Black and Red power line;
3. Engage self-study wire;
4. Connect the key wire (Orange) to +V and the motor should start spinning;
5. Let it spin for awhile for the controller to learn the phase angle of the Hall probes;
6. Disconnect self-study wire and the motor should stop, DO NOT ramp up throttle at this stage as it will make the controller unlearn step 5;
7. Disengage Key to let the controller save the configuration, DO NOT disconnect the Power wires!;
8. Reconnect the Key wire, and self learning is done, motor should now respond to throttle command.;
9. Configuration is now permanently stored, power cable can now be unplugged without erasing the self-learned configuration.;
10. Enjoy!
So what exactly are the steps? thank you!
drewjet   10 kW
Post by drewjet » Feb 01 2016 6:06am
I hooked it up yesterday, so going from my memory...
Hooked it up, with wheel off ground and turned on controller (Connect small red wire). Twist throttle and motor will not turn, grunting sound. Hooked up 2 white wires and motor spun correct direction. Disconect 2 white wires, and throttle works normal. Done.
999zip999   100 GW
Post by 999zip999 » Feb 01 2016 12:34pm
Oh hand spin the motor the right direction for self learning. As step 4b ? Right ?
drewjet   10 kW
Post by drewjet » Feb 01 2016 1:23pm
no, the motor will just start spinning, that is why you need the wheel off the ground
