Hummina Shadeeba
I want to find a shape that can fit in these 6 air holes in the motor's rotor and the air will exit out of holes on the other side of the motor that aren't spinning.
The purple flange holds the wheel and there are small recesses in the steel u can see for screen.
Is there an ideal shape fin or something that would fit in this 3mm thick hole. Or the fin could come further in a bit. Or maybe I could add a lump of material on the side of the hole and create a vacuum?
If I can find a shape I could 3D print it and then make a mold and pour it in whatever material and glue it in or on
