notger said:
Wye
- less amps at the start (at lower rpms)
- approx. 1.7X less KV as Delta - means lower end speed
- better suited for batteries which are not so strong (laptop cell zombies)
- Wye runs rather cool than Delta
- take wye if you want to have more torque at high-speed/rpm
- but therefore you get lamer starts
- with the weak cells of the past, Wye was still important
Delta
- more current at start and less at topspeed
- 1.7X higher top-speed than wye
- high currents at start, therefore high current-cells
- Delta runs rather warmer than wye (because of the start-currents in the lower-rpms)
- take Delta if you want burnout-starts, but accept less power at top-speeds
- most ebike and RC engines today are Delta because of high current cells
- The missing bite of Delta in the higher speeds can be compensated by "clever controllers", which in the end push more current, but the motor will get quite warm
Still open questions and assumptions about this:
- can one say that one of the types of windings is "more economical" with current (or is the higher current of the Delta at the start compensating with the higher current from wye to the topspeed?)
- does it make sense to choose Wye or Delta for the following reasons:
- I'll take wye because I do not care about burnout starts, but i want torque close to the top-speed, I live in a flat city!
- I take Delta because the most important are traffic-light-burnouts, or a lot of torque in dirt- tracks. I get my high top-speeds by gravity because I live in the Alps
Notger
A quick WYE vs delta primer...
1. Wye for the same voltage and amps will give you more torque than will delta. Delta requires more amps to generate the same amount of torque as WYE.
2. For the same volts WYE will be slower (less RPMs) than delta at any given throttle position.
3. Wye does better at lower RPM's than does delta mostly because it doesn't require as much current to generate torque.
4. Any BLDC motor is limited by how strong its magnets are and how strong of a magnetic field it can produce. You can't produce more torque than the motors magnets or magnetic fields are strong. WYE or delta is equally limited by those magnetic limits.
5. The same motor rewired for WYE or delta should run equally well assuming that the controllers eRPM isn't exceeded.
6. At no load, Delta at any RPM will require more current than WYE. In my tests at barely creeping along my motor in WYE used less than an amp and soon went up to 3 amps all the way to WOT. On delta, it took 3 amps just to get turning and soon jumped to 9 amps all the way to WOT. Holding the throttle steady and switching from WYE to delta or back always included an increase or decrease in current draw.
7. The windings for WYE or delta are exactly the same. It's how you terminate the winding ends that determines whether a motor is WYE or delta. Connect the three starts of three windings together and feed current into the ends of each winding and that is WYE. Think of the letter Y. Each leg is a winding. 3 winding ends connect together in the middle and there are three ends. Delta is just a triangle. The three sides of the triangle are the windings. So windings a,b,c...the end of a connects to the start of b, the end of b connects to the start of c and the end of c connects to the start of a.
To directly address your WYE and delta lists...I'm going to assume no load always in my answers. Load is dynamic so that adds variables.
Wye
Always less amps, but also lower top RPM
yes...true
Not true...build your battery pack to suit your current needs. The cell type is irrelevant. Use AAA batteries or watch batteries if you want...just be sure that the end pack build can deliver the voltage, current and capacity that you require. I use free/used laptop cells a good bit. They work fine, just means I need to use more of them to get the same discharge rates of an EV grade cell. Laptop cell or EV cell or tool cell are all fake distinctions. They will all work for whatever you want to use them for as long as you plan around that particular cells limitations.
No...not really. Delta since it needs more current to generate the same amount of torque will probably run warmer while generating the same amount of torque since that also means a bump in current too over what WYE needs.
Torque is a factor of magnetic strength, not WYE vs delta. The same motor wired either way should have the same maximum torque.
If you have the current delivery ability, delta or WYE will deliver the same amount of torque at zero RPM or any RPM assuming you are comparing their two power bands correctly. However, to get that maximum torque WYE will use less amps to do it. That means your battery charge will last longer running WYE than it will running in delta.
Wye is still important. It flat out uses less current than does delta to generate any amount of torque. Weak or strong cells is irrelevant.
Delta
No...more current than WYE at all RPMs
Since the same motor wired in WYE will have 1.7X less Kv than that motor wired in delta, yes, there is a 1.7X increase or decrease in maximum motor RPM's for a given battery voltage.
Higher currents than WYE all the time, not just starts. Just build your entire battery pack out of whatever cells it is made from to handle the delta current load. The type of cell used or its specific limitations is irrelevant...just use what you have and plan your battery pack to take into account those limitations. 18650 cells commonly used in laptop battery packs are usually 2600mah and have 2 or 3C discharge rates. While a 31Q had a much higher discharge rate and a bit more capacity. Which ever cell you use, plan the battery pack to be enough cells to cover your current and capacity needs.
No...not quite...since delta draws more current all the time, it will run warmer than the same motor wired for WYE. It's not just at start up from zero RPM.
No...not true. In WYE, I can gear for rubber burning, wheelie riding performance. Same can be done in delta. The motor can only produce as much torque as it's magnets and magnetic fields can produce. Delta or WYE doesn't change this. Since the motor in delta has a 1.7X higher Kv than it does in WYE, the motor will continue producing the same amount of torque up to a higher RPM than it would in WYE. BUT...it will use more current to do it.
No...not true. Outrunners are commonly wired in delta and inrunners are commonly wired in WYE...but not always. So when you say "RC", consider the type of BLDC motor to which you are referring. Outrunners are used extensively in drones, planes and helis while inrunners are mostly used in ground craft. In EV use, either motor type if it fits the needs of the EV will work. A lot of people are using hub motors on their EV's...that's an outrunner inside a shell with a crazy low Kv. Sometimes they are wired delta and other times they are wired WYE. I have a hub and it is wired WYE. My blue scooter runs a big block motor and it is wired WYE. It tops out at 50mph on level ground and I can accelerate faster than most cars while maxing out at less than 60 amps. I have smaller scooter running an outrunner wired delta. It draws similar amounts of current as the big block despite pushing less weight and being a smaller motor.
So this this little bit of wording is a bit confusing since it's a mix of multiple concepts and implementations. A "clever controller" would be one that does FOC and feild weakening. Regardless of WYE or delta, it will run the motor a bit faster than it will run on a non-FOC controller and will cost you a little more current to do it. Can you get 1.7X via field weakening? No not likely, but .3X or so is doable. Any controller can push "more current". If your 2000 watt controller can only deliver 40 amps, then double the mosfets or use higher wattage mosfets and now it can deliver "more current". A semi smart controller with phase and battery current control can be set to say 20% of it's maximums and run a motor. Then change those settings to 100% and now it delivers more current to the motor.
WYE is more economical...for the same amount of torque, wye requires less current than does delta. Ignoring the rest...already discussed.
All ready talked about burn out starts...that's just gearing. Torque at higher motor RPM's is a matter of what you mean by "higher RPMs". As long as either wiring method is used on the same motor, both will generate the same amount of torque. WYE will start petering off sooner than delta, but if you took the same motor at 50% of full RPM in WYE or delta, they would produce the same amount of torque. Delta will continue applying that torque up to a higher RPM than will WYE, but the amount of torque will be the same.
Read everything else I wrote. Your conclusions are incorrect.
