Carguy7555
- Joined
- Nov 17, 2016
- Messages
- 10
I just spun my first axle. Does anyone have a source for motor cabling-wiring? It can be 8 or 9 wire cabling. I don't use the temp wire so it can be 8 or 9 wire for my application. My spun cable is 6.85mm O.D. (pict attached). So it could not be larger then 6.85mm as that fits tight through the axle. I'm really hoping to find the pre-made 8-9 wire cable with the black insulator around the 8-9 wires for a clean look and wire protection. I don't need any ends on the cable. Just bare 8-9 cable-wire with the outside insulator cover. The phase wires are 2.54mm. I'm really hoping not to have to splice the wires. A clean run from the motor to the controller would be ideal. Help! Carguy7555
