honya96   1 kW
Re: Flexible OpenSource firmware for BMSBattery S/Kunteng KT motor controllers (0.25kW up to 5kW)
Post by honya96 » Jan 20 2018 7:59am
24" x 3.0" tire so almost like 26". 46 magnets, no reduction. Firmware has some bugs for sure, I left my bike running on stand to drain battery and after about 2 minutes running with fixed throttle possition it started to accelerate to 78km/h on display and back to 35 and again. After releasing throttle it did once again and stopped, then after adding throttle just some sound but no turning. Had to flash again.
casainho   100 MW
Post by casainho » Jan 20 2018 9:26am
honya96 wrote:
Jan 20 2018 7:59am
On that test, was the motor accelerating and keep always increasing the speed the the speed shown on LCD was wrong or do you think the speed shown on the LCD reflects the real value??
I must say I don't have a motor that fast, maybe there are some variable doing overflow with such high speed values. I need to think more about this. Every information about your tests is important, but please give detailed information!! Say in which conditions, which options the firmware and options on LCD like the values for P1, etc.
So, with 46 magnets, has 23 poles.
For the limit of 520 ERPS, would be:
- 520/23 = 22.6 RPS; 22.6*60 = RPMs = 1356
On this table, https://endless-sphere.com/forums/viewtopic.php?t=16114, 1356 RPMs would be 154km/h!!! So you are not hitting the MOTOR_OVER_SPEED_ERPS of 520.
Developer of the Flexible OpenSource firmware for EBike motor controllers (TSDZ2 and KT) and LCDs (KT-LCD3 and Bafang 850C color LCD).
geofft   1 kW
Post by geofft » Jan 20 2018 10:27am
honya96 wrote:
Jan 20 2018 7:37am
@Casainho - edited config.h does not change it. I am far from hiting max erps, as I explained, I get 37km on display while set 72. Motor rpm is changing by P1 but still limits to about 37 on display
@Geofft - can you try the 100% throttle?
Always 100% throttle works ok for me, after I requested it casainho added this line to config.h :-
#define EBIKE_THROTTLE_TYPE_THROTTLE_PAS_ASSIST_LEVEL_PAS_ONLY
...and it has worked ok since then. Maybe double check you have this exact line? There are a couple of other lines that are very similar.
BBS02 V2 48v 750w, 12s lipo.
Q128H (36v 201rpm), KT36/48SVPR, LCD3, 48v 12s lipo.
casainho   100 MW
Post by casainho » Jan 20 2018 10:31am
geofft wrote:
Jan 20 2018 10:27am
honya96 wrote:
Jan 20 2018 7:37am
That option, can be seen on config-example.h file on the firmware folder (should be added manually to config.h or main.h):
https://github.com/OpenSource-EBike-fir ... -example.h
honya96   1 kW
Post by honya96 » Jan 20 2018 12:06pm
casainho wrote:
Jan 20 2018 9:26am
The speed shown was real (like full throttle on original fw), but much higher than full throttle on this fw (I cant get rid of 35-37km/h limit.)
P1 - 46 P3 - 1
12 magnets max cadence 20
Stock assist levels etc.
14s batt.
214 angle
137 angle
Stock pwm rise
No file edited (config.h, main) all stock
Battery at 57V (doing this I wanted to discharge my battery a bit, cause I have blown 2 mosfets and then seen they are 60v (others have 68v or 80v) only so not enough margin for 14s.)
Bike on stand, throttle fixed manually to stay same, was running 37km /h then 35 for a while and then started doing what I explained. Anything else you need to know? I am going to test it more now
@Geofft - so its working with no need you to edit config.h? now I realize maybe maybe it worked for me to with germotor bike (and other kt-lcd3)
Maybe its "all" caused by lcd? The wrong speed, etc
honya96   1 kW
Post by honya96 » Jan 20 2018 1:27pm
tried the other display, and throttle is 100% at pas 0! (?), blown mosfets again when turning off the lcd. weird.
First blown was mosfet 1 and 4 now its 1 and 2 counting from shunt side.
casainho   100 MW
Post by casainho » Jan 20 2018 1:38pm
honya96 wrote:
Jan 20 2018 1:27pm
You can try without LCD and define your own default variabke valies that LCD define, they are on main.h. They are the EEPROM variables. Please erase first the firmware writing the option bytes, to nake sure EEPROM is also erased.
Also maybe I can make a firmware with speed controller disable, so you can try with juat direct throttle value to be dutycyle.
I am not at home so I can't help more until today.
casainho   100 MW
Post by casainho » Jan 20 2018 2:35pm
When first run of firmware and without an LCD connected, the default values are this, defined 9n main.h. This values are after saved on persistent memory of STM8, everytime the LCD change their correspondonding values.
So, If you think your LCD can be source of problems, don't use it amd instead change this default values for your needs:
Code: Select all
// EEPROM memory variables default values
#define DEFAULT_VALUE_ASSIST_LEVEL 		2
#define DEFAULT_VALUE_MOTOR_CHARACTARISTIC 	202 // for Q85 motor (12.6 * 16)
#define DEFAULT_VALUE_WHEEL_SIZE	 	20 // 26''
#define DEFAULT_VALUE_MAX_SPEED	 		25
#define DEFAULT_VALUE_POWER_ASSIST_CONTROL_MODE 1
#define DEFAULT_VALUE_CONTROLLER_MAX_CURRENT	10
honya96   1 kW
Post by honya96 » Jan 20 2018 2:44pm
thanks, but I dont want to use without lcd. I am just pointing out things which dont work as they should.. the other lcd is running at 42km/h while its like walking speed with gear motor, now running on table, waiting if it fails again.
So its the communication between lcd and controller, limiting the speed.
@geofft you can test by setting P1 at like 20 so display shows 42 and you get walking speed and no way to go faster if I am right.
btw whats your board model number (like KTE-SVP5-A..)
Even my gearmotor bike at 1kw is going 60 downhill so it will be a problem for more people
@Casainho, just seen your last post. I allready tried changing "#define DEFAULT_VALUE_MAX_SPEED" to 72 but looks like lcd overrides it with "its own" 72 which means 42 or 37 on the two lcds :roll:
casainho   100 MW
Post by casainho » Jan 20 2018 3:00pm
honya96 wrote:
Jan 20 2018 2:44pm
To make sure it is the LCD: do the same test but never connect the LCD and please tell us of the results.
honya96   1 kW
Post by honya96 » Jan 20 2018 3:03pm
still same speed without display. set 72 and even 0, same. I did it all as you said :?
honya96   1 kW
Post by honya96 » Jan 20 2018 3:15pm
Original fw does not limit speed without display, since it doesnt know P1 value, which pole number is set by default here?
honya96   1 kW
Post by honya96 » Jan 20 2018 3:44pm
I can say for sure that some other options than P1 P3 and C5 do some changes. I restored original values, put those 3 back as they was, and now I get no throttle at PAS 0 and much higher motor speed while still showing max 35.
Edit: Tried hard but found no specific value causing this, maybe C3 or C4, but after changing them back to stock throttle stays active at PAS:0
so, If anyone wants Throttle still 100%, change a lot randomly :D .
If throttle scaling with PAS, restore original settings by C10
casainho   100 MW
Post by casainho » Jan 20 2018 6:57pm
So, good to know that LCD is not limiting the speed.
Tomorrow I can change the firmware to disable speed and current controllers, then you can put directly PWM dutycyle on the motor, using the throttle -- can't be more direct.
honya96   1 kW
Post by honya96 » Jan 21 2018 3:39am
casainho wrote:
Jan 20 2018 6:57pm
I think it is limiting the speed somehow, when I set P1 to higher value I get higher rpm on motor but same speed reading. Without display I cant set the P1
Disabling current control is a big step back, thats the main feature I like.
geofft   1 kW
Post by geofft » Jan 21 2018 3:59am
Didn't realise that the P1 setting was still active - my setting for this was 211 (16 magnets x 13.2 gear ratio). I'll try your numbers and let you know if I find anything that may help you.
My controller is a KT36/48SVPR, board number KTE-SVP5-A.
Edit to add: My P3 is set to 1, if set to 0 found it applied some restrictions to speed or throttle, can't remember exactly what they were.
My speed is set to max in display (72kph?) but my setup can only achieve about 33kph. I think this is probably the limit for a 201 rpm motor at 48v.
honya96   1 kW
Post by honya96 » Jan 21 2018 4:26am
geofft wrote:
Jan 21 2018 3:59am
Great, so you have the same controller. Please test the low P1 value so you get much higher speed reading than reality, and see if it will go up to 72 or more like 35-42 while not full rpm at motor. Thanks :wink:
casainho   100 MW
Post by casainho » Jan 21 2018 4:54am
honya96 wrote:
Jan 21 2018 3:39am
casainho wrote:
Jan 20 2018 6:57pm
P1 is the DEFAULT_VALUE_MOTOR_CHARACTARISTIC!! So ypu can change it without the LCD!!
The idea to disable current and speed controllers was jist for you to make a test and see if you can run your motor at max speed, without any limitation.
stancecoke   10 kW
Post by stancecoke » Jan 21 2018 8:28am
honya96 wrote:
Jan 20 2018 7:37am
@Stancecoke - Thanks but I will stick with main branch, can test the value if you want, but I am not intersted because it does not work with lcd3.
mtdr has sent a LCD3 to me, so I have now implemented basic functions for the LCD3 in my fork. I added the option of using a higher PWM frequency, also. See the new branch HighSpeedMotors.
The java tool is not updated yet. So you have to edit the config.h manually and doubleclick on Start_Compiling.bat at the moment.
regards
stancecoke
geofft   1 kW
Post by geofft » Jan 21 2018 8:40am
honya96 wrote:
Jan 21 2018 4:26am
Found that reducing the P1 number caused a reduction in both displayed and actual wheel speed. At P1=40 was getting a max speed (wheel and display) of just 8-9kph. BTW, my speed detection is via the motor signal (white wire on hall plug), I don't have an external speed sensor. Seemed to get the best result (speed and torque) around the 'correct' setting for my motor, 211.
Not sure if this of any help, or how much these results relate to the rather different characteristics of your motor - but if you need any more tests done then just let me know.. :)
geofft   1 kW
Post by geofft » Jan 21 2018 9:11am
Bought one of these just recently:-
Lots of these for sale quite cheap on ebay and great for controlled load testing, especially with weather like the UK today... :wink:
honya96   1 kW
Post by honya96 » Jan 21 2018 9:16am
geofft wrote:
Jan 21 2018 8:40am
Thanks, I think it confirms my problem.. for Casainho so he knows there is a bug. :wink:
@Casainho - no need to hurry with this issue, I can get the speed I want by setting wrong P1, then just the displayed speed is wrong.
honya96   1 kW
Post by honya96 » Jan 21 2018 9:19am
stancecoke wrote:
Jan 21 2018 8:28am
Looks like correct power measurement also, good work :wink:
I am going to try it right now.
casainho   100 MW
Post by casainho » Jan 21 2018 9:34am
@honya96: I disabled the speed and current controller and also the protection for motor stall, on the new testing branch "direct_throttle". Please download and test, you should be able to get your motor max speed: https://github.com/OpenSource-EBike-fir ... t_throttle
The motor controller is now simple as this (no speed and current controllers):
Code: Select all
void do_motor_controller_mode (void)
  // set PWM duty_cycle target value only if we are not braking
  if (!motor_controller_state_is_set (MOTOR_CONTROLLER_STATE_BRAKE))
    motor_set_pwm_duty_cycle_target (ui8_throttle_value_filtered);
@geofft: nice that you got the training bike roller, would be great if you could put a constant speed and adjust the value for FOC_READ_ID_CURRENT_ANGLE_ADJUST. Can you please share with us how was the process and the final value for your motor?
@stancecoke: great that HighSpeedMotors, would be great to have feedback from users!!
casainho   100 MW
Post by casainho » Jan 21 2018 9:39am
honya96 wrote:
Jan 21 2018 9:16am
geofft wrote:
Jan 21 2018 8:40am
I am lost here: can you please resume?
I understand that your motor is direct drive, with 46 magnets and you set P1 = 46, which is ok.
