honya96   1 kW
Re: Flexible OpenSource firmware for BMSBattery S/Kunteng KT motor controllers (0.25kW up to 5kW)
Post by honya96 » Jan 09 2018 11:08am
Casainho, at your link I cant see connection to st-link pins.
Thanks stancecoke :wink:
So first things done.
casainho   10 GW
Post by casainho » Jan 09 2018 11:10am
honya96 wrote:
Jan 09 2018 11:08am
Then I will update with stancecoke pictures and maybe even your picutres.
- TSDZ2 OpenSource firmware
Developer of OpenSource knowledge and technology for ebikes: Wireless Ebike boar ANT+ and Bluetooth, Flexible OpenSource firmware for EBikes: TSDZ2 mid drive motor, KT motor controllers and displays: Bafang 850C color, SW102 Bluetooth and KT-LCD3.
If you like my work, please consider making a donation to help my developments: paypal.me/jorgecasa
honya96   1 kW
Post by honya96 » Jan 09 2018 11:44am
So, I have it connected and light is up still.
but looks like you are working on the website right?
casainho   10 GW
Post by casainho » Jan 09 2018 11:47am
geofft wrote:
Jan 09 2018 10:31am
That's much better now, powers up dead on zero, maybe starts to drift a little after around 20 secs and eventually settles drifting slightly around 22 watts. Not perfect but probably near enough.
I also got on my ebike around that value. I think i8_motor_current_filtered_10b = 1, that is multiplied by two before sent to LCD. Each unit is 0.25A. So, in your case: 38V( 10S * 3.8V), 22W --> I = P / U; 22/38 = 0.58A
Maybe we could always decrement i8_motor_current_filtered_10b by 1 or 2 units, before sent to LCD.
I wounder it that 22W will not increase after you run the motor for some time, if the shunt on the controller will not change his value considerable...
casainho   10 GW
Post by casainho » Jan 09 2018 11:51am
honya96 wrote:
Jan 09 2018 11:44am
No, maybe some temporary problem with bitbucket:
- https://bitbucket.org/opensourceebikefi ... tbucket.io
- https://bitbucket.org/opensourceebikefirmware
I have the source files on my computer and I think stancecoke also has, no worry :-)
stancecoke   100 kW
Post by stancecoke » Jan 09 2018 12:06pm
honya96 wrote:
Jan 09 2018 11:44am
Perhaps you can proceed with the german tutorial, until the page on bitbucket works again:
https://www.pedelecforum.de/wiki/doku.p ... controller
regards
stancecoke
geofft   1 kW
Post by geofft » Jan 09 2018 12:18pm
casainho wrote:
Jan 09 2018 11:47am
geofft wrote:
Jan 09 2018 10:31am
In fact my battery is 12s so in theory the current is around 500mA. This does not agree with my ammeter (good quality multimeter) in series with the battery which shows (at idle) the current drain is actually just 180mA (for display and controller electronics, etc, etc) so it seems this 22w drain is untrue and being generated by the firmware.
I hope to do a road test tomorrow, I'll see how this looks after the motor has been run for some time.
Just for interest, the idle current drain with the stock firmware is just 90mA....
BBS02 V2 48v 750w, 12s lipo.
Q128H (36v 201rpm), KT36/48SVPR 6-fet, LCD3, 48v 12s lipo.
stancecoke   100 kW
Post by stancecoke » Jan 09 2018 12:27pm
I wonder how many board version are available of the KT36. At honyas we see KTE-SVP5, yesterday mdtr from the german forum posted a photo, where the PCB is labeled with KTE-SVP7 and casainho and me have various versions labeled with KTE-6S3-xxx
Strange....
regards
stancecoke
casainho   10 GW
Post by casainho » Jan 09 2018 12:38pm
geofft wrote:
Jan 09 2018 12:18pm
If possible, unconnected the motor phases and compared. As you can see, they are energized on oir firmware while motor is stop -- I wounder if unbalance of phases and circuit gives that result.
geofft   1 kW
Post by geofft » Jan 09 2018 12:59pm
casainho wrote:
Jan 09 2018 12:38pm
geofft wrote:
Jan 09 2018 12:18pm
I think you're correct because there is some slight resistance to turning the wheel at idle that the stock firmware doesn't have. Will check further tomorrow.
honya96   1 kW
Post by honya96 » Jan 09 2018 1:54pm
Looks like I have removed the original firmware but can't flash new.
How I understand, all I need to do is download firmware.rar folder, open tool and click write configuration? If so then it does not work.
Or do I have to compile by cmd and flash via st programmer? (As in old pdf instructions)
casainho   10 GW
Post by casainho » Jan 09 2018 2:07pm
Documentation site is now online again. Please follow the tutorial there, it has some information what happens in background of fimware configuration tool, so you can try to do it manually if the tool fails for some reason.
honya96   1 kW
Post by honya96 » Jan 09 2018 4:50pm
Cmd window should stay open so we know what happend and say on the last line that it went ok and we can close it.
geofft   1 kW
Post by geofft » Jan 09 2018 5:24pm
I had trouble with this too - the answer is - edit the .bat file you're trying to run (right click-edit) and put a 'pause' command on a separate line before the 'exit' command at the end. It will then do exactly what you are asking.
honya96   1 kW
Post by honya96 » Jan 09 2018 5:37pm
Thanks, its working :) and about the error I am getting? :D It can't find any of the file's its working with. I have the folder in C:/
casainho   10 GW
Post by casainho » Jan 09 2018 5:50pm
Looking at your screenshot, seems that main.bin and main.ihx does not exist and that probably means that build of firmware did fail.
Woild be great if you could look at the build script to find the commands it execute for building, then you could run that commands by yourself and see the output feedback and post here - that feedback is very clear to say what did fail in build (sometimes, something missing on config.h, due to bug on condiguration tool or some error on the firmware sources (because as you know, we have being improving it every day).
honya96   1 kW
Post by honya96 » Jan 09 2018 5:58pm
That's allready over my head
honya96   1 kW
Post by honya96 » Jan 09 2018 6:02pm
Basicaly it can not find anything. Thanks for your help, I am done for today.
casainho   10 GW
Post by casainho » Jan 09 2018 6:11pm
So, let's looking at the script Start_Compiling.bat. That script is called after firmware_configuration_tool generates the config.h file inside the "firmware" folder (that file has written the options that you did chose on firmware_configuration_tool) -- you can look at config.h by editing with notepad.
So, Start_Compiling.bat has the following lines which you can run on command line, one by one (you can copy-paste from here to the command line):
Code: Select all
PATH = %PATH%;C:\Program Files (x86)\STMicroelectronics\st_toolset\stvp
That seems to set the path of ST software for flashing, to be known by Windows command line.
Code: Select all
cd firmware
Let's go inside "firmware" folder!! This mean that this script should be called on the root folder from the unzip file you did download from github.
Code: Select all
..\configuration_tool\windows_scripts\make -f Makefile_windows clean
This command will "clean" any previous generated files, if any, on a previous build firmware process.
Code: Select all
This one will build the firmware!! You should look at the output and see if there is any error mentioned. And copy paste and post here, so we can help you.
Code: Select all
STVP_CmdLine -BoardName=ST-LINK -ProgMode=SWIM -Port=USB -Device=STM8S105x6 -FileProg=main.ihx -verbose -no_loop
This will use the ST software to flash the firmware file "main.ihx". That "main.ihx" file is generated on the previous build firmware process and if it failed, main.ihx does not exist and you will get something saying that file does not exist.
Code: Select all
exit
Should be to close the window of command line.
geofft   1 kW
Post by geofft » Jan 09 2018 6:17pm
Honya, best if you post the complete cmd page log. What I suggest you do:-
With the cmd log on your screen, right click on the title bar (at the top), click edit, now click 'select all'
Right click title bar again, click 'edit', then click 'copy'.
Open notepad or wordpad, right click on the page and 'paste' the contents of the cmd log. Give it a name and save it.
Post it on here as an attachment and let the guys take a look at it, they can probably point you in the right direction.
Time for bed for me too.... :)
Edit to add: Casainho, just seen your last post, I think it's very difficult to follow. Maybe best if he posts the complete cmd log and you can give him some more concise, easy to follow instructions. Leave it until tomorrow.
stancecoke   100 kW
Post by stancecoke » Jan 10 2018 2:36am
As far as I can see, the path to the SDCC-Folder is missing. There has to be an entry like "C:\Program Files\SDCC\bin;" in the PATH information.
You are asked at the installation process of SDCC if you want the installer to set it automatically.
So reinstall SDCC and make sure that the checkbox is activated at this point, then click "Next".
SDCC Setup Screen.PNG (37.65 KiB) Viewed 2486 times
Alternatively, you can add the path in the Start_Compiling.bat manually.
Here an example for the first line in the Start_Compiling.bat, if you have installed SDCC with the default settings on a 64bit system.
Code: Select all
PATH = %PATH%;C:\Program Files (x86)\STMicroelectronics\st_toolset\stvp;C:\Program Files\SDCC\bin;
regards
stancecoke
honya96   1 kW
Post by honya96 » Jan 10 2018 6:13am
Thanks Stancecoke, looks better now, I had 20 minutes free so I tried again and copied like geofft sugested :wink: no time to chceck myself or test. will continue in 4-5 hours.
log.txt
(10.88 KiB) Downloaded 120 times
honya96   1 kW
Post by honya96 » Jan 10 2018 6:22am
I have the start compiling. bat edited with timeout /t -1 /nobreak but It does not work with java tool. It needs to be added in the app? :shock:
casainho   10 GW
Post by casainho » Jan 10 2018 6:33am
Looking at your log, seems that everything did work well :-)
The firmware build went well as also the flashing.
Code: Select all
Configuration:
BoardName=ST-LINK ST-LINK_ID=0 Device=STM8S105x6 Port=USB ProgMode=SWIM
>>> Filling PROGRAM MEMORY image in computer with Blank Value
<<< Filling PROGRAM MEMORY image in computer succeeds
>>> Loading file main.ihx in PROGRAM MEMORY image in computer
<<< Loading file succeeds
Hit 'Esc' key to abort during communication.
>>> Programming PROGRAM MEMORY
<<< Programming PROGRAM MEMORY succeeds
>>> Verifying PROGRAM MEMORY
<<< Verifying PROGRAM MEMORY succeeds
geofft   1 kW
Post by geofft » Jan 10 2018 8:06am
Just been out for a short test ride and have to say that the firmware is working really sweetly now, a credit to you guys. Still one or two details to tidy up but the major stuff all works well.
I don't have much time for this today but will ride some more and feedback later this week.
