stancecoke   10 kW
Re: KT motor controllers -- Flexible OpenSource firmware for BMSBattery S/Kunteng KT motor controllers (0.25kW up to 5kW
Post by stancecoke » Nov 25 2018 12:54pm
Valopallo wrote:
Nov 25 2018 12:15pm
Ok. I flipped the disk, but the situation remains the same :(
then you have to mount the whole sensor to the other side of the bottom bracket.
There are tons of posts regarding this topic in this forum.
regards
stancecoke
Valopallo   100 mW
Post by Valopallo » Nov 25 2018 1:58pm
stancecoke wrote:
Nov 25 2018 12:54pm
Valopallo wrote:
Nov 25 2018 12:15pm
regards
stancecoke
There's no locking ring at the driveside so I flipped the sensor unit in its metal holder and everything works now. Some glue and silicone and I'm set. ;)
haiyi911   1 W
1 W
Post by haiyi911 » Nov 26 2018 8:52am
Hi,when i twest the throttle at first time,the speed show after 5 seconds on the LCD3. then twest throttle again,the speed show immediately.
tomtom50   100 W
Post by tomtom50 » Nov 26 2018 11:12pm
Blik86 wrote:
Aug 06 2018 12:57pm
Hi
I got KT48SVPRM-XFCF06 (board KTE-9S5-J5). It has 9 transistors K150E09NE. Processor STM8S105C6T6. Current sensor acs711 (QFN).
Is it compatible with this OpenSource firmware?
What are the extra 3 transistors doing?
I bought this same controller from topbikekit. Have you used it yet? Any results?
Xnyle   10 W
Post by Xnyle » Nov 27 2018 12:10pm
Maybe passing more current? Or maybe they are just for optics.
Blik86   100 µW
100 µW
Post by Blik86 » Nov 27 2018 1:19pm
tomtom50 wrote:
Nov 26 2018 11:12pm
Did not touch the waterproof fill. Therefore, I use it in stock.
Bike and I are about 100kg. Motor bafang BPM 10t 26 ". 48V.
It starts moving away if the gas is lightly pressed, otherwise the current exceeds and switches off the motor.
Without a display, the speed is no more than 25 km / h. The seller said that with the display speed is more.
The display will soon arrive (lsd6), if the speed does not rise, I will try the OpenSource firmware.
tomtom50   100 W
Post by tomtom50 » Nov 27 2018 9:52pm
Blik86 wrote:
Nov 27 2018 1:19pm
tomtom50 wrote:
Nov 26 2018 11:12pm
Thanks. I'm interested in hearing how the open source firmware goes.
haiyi911   1 W
1 W
Post by haiyi911 » Nov 28 2018 5:17am
Hi,stancecoke
I want to add a protection function. when the power is turned on, if the throttle value is between ADC_THROTTLE_MIN_VALUE and ADC_THROTTLE_MAX_VALUE, it is protected. Release the throttle then protection function is unprotected. Some code have been added and protection is worked,but there is a problem.
when i released the throttle fast,the motor run a few time then stop.https://youtu.be/KL8o5s7RZMI
when i released the throttle slowly,the motor didnot run.
Maybe the throttle value is valid when i release the throttle?
stancecoke   10 kW
Post by stancecoke » Nov 28 2018 1:28pm
haiyi911 wrote:
Nov 28 2018 5:17am
Thank you for your effort.
I don't know, if this solves your problem, but zero current means
Code: Select all
ui16_setpoint = ui16_current_cal_b;
regards
stancecoke
haiyi911   1 W
1 W
Post by haiyi911 » Nov 28 2018 9:38pm
stancecoke wrote:
Nov 28 2018 1:28pm
haiyi911 wrote:
Nov 28 2018 5:17am
Code: Select all
regards
stancecoke
Thanks! but :( the same result.
another question, when i twest the throttle at first time,the speed show after 5 seconds on the LCD3. then twest throttle again,the speed show immediately.is there delay-code?
stancecoke   10 kW
Post by stancecoke » Nov 29 2018 2:53am
Uups, your code was right, ui16_setpoint is the duty-cycle, not the current target. The delay of the speed information is an issue of the display, not of our firmware.
Regards
stancecoke
j bjork   100 W
Post by j bjork » Nov 29 2018 5:14am
stanscoke already answered, but i can confirm that I have the same issue with the display not showing the speed at first. That is with standard controller and lcd3.
casainho   1 GW
1 GW
Post by casainho » Nov 29 2018 11:34am
Status of the OpenSource firmware for Bafang 850C color LCD
The configuration menu is now fully implemented and is well structured that is easy and fast to add/remove items to the menu. This LCD would be a good tool for KT motor controllers, for the ones that do prefer an LCD. In future I want to implement graphs so the LCD can show a graph of real time value of variables like motor current, rider pedals human power, etc.
Developer of the Flexible OpenSource firmware for EBike motor controllers (TSDZ2 and KT) and LCDs (KT-LCD3 and Bafang 850C color LCD).
geofft   1 kW
Post by geofft » Nov 29 2018 3:15pm
casainho wrote:
Nov 29 2018 11:34am
Nice work Casainho, some useful options on those menus.
I'm a little confused though, as to where this fits in with the KT controllers - I guess this isn't currently compatible with your KT (S06S etc) fw branch, do you have plans to upgrade the KT controller fw to work with this?
BBS02 V2 48v 750w, 12s lipo.
Q128H (36v 201rpm), KT36/48SVPR, LCD3, 48v 12s lipo.
casainho   1 GW
1 GW
Post by casainho » Nov 29 2018 4:59pm
geofft wrote:
Nov 29 2018 3:15pm
This would fit very well, because I developed the firmware and I did structure and program with the same logic I did for KT. Also the development tools are just the same! The good of this LCD is that is very flexible:
- 320x480 pixels, color
- has a clock that can keep date and time when system is powered off (1)
- very fast, running at 125Mhz, 32 bits ARM cortex M3
- has a LOT of program memory (0.5 mega byte and I am using 30% of it, while the firmware is at about 80% complete)
I wish I could make it for KT, but I can't do more because lack of time (I take already a LOT of my personal time for this projects!!). Time for other developers to join...
(1) I hate when riding and I have to slow down to look at my watch to see the hours, to see if I am late -- LCD3 do not have such clock and date.
casainho   1 GW
1 GW
Post by casainho » Nov 30 2018 2:17am
It's working for the very first time!!
I have an special ride on Saturday, and I decide to take the risk and use this fresh firmware that may have bugs and be a problem while I will be on the mountains...
haiyi911   1 W
1 W
Post by haiyi911 » Nov 30 2018 10:25am
stancecoke wrote:
Nov 29 2018 2:53am
Regards
stancecoke
ok.thanks , stancecoke.
and what is the ACA meaning? " #define ACA 4760""
j bjork   100 W
Post by j bjork » Dec 01 2018 2:06pm
I have read the instructions, but I don´t understand where to solder the wires for the st link. I have an 18 fet controller. Is it on J1?
j bjork   100 W
Post by j bjork » Dec 02 2018 1:10pm
It seems like there are a few users of the 18 fet controllers here, so there should be some people that knows I think. The second hole from the left is ground, but I don´t see any obvious 5v connection. At least it is not connected to the other 5v that exit the controller to pas, throttle etc.
If this is not theright spot, what markings should I look for?
Edit, I hooked it up and measured. There is 5v at the 4th hole from the left, so I guess it is the same as in the instructions. Just that it is wired the other way round.
stancecoke   10 kW
Post by stancecoke » Dec 03 2018 7:35am
haiyi911 wrote:
Nov 30 2018 10:25am
In this value the initial settings of some parameters are stored.
Code: Select all
typedef enum {
	ASSIST_LVL_AFFECTS_THROTTLE = ((uint16_t) 1),
	OFFROAD_ENABLED = ((uint16_t) 2),
	BRAKE_DISABLES_OFFROAD = ((uint16_t) 4),
	DIGITAL_REGEN = ((uint16_t) 8),
	SPEED_INFLUENCES_REGEN = ((uint16_t) 16),
	SPEED_INFLUENCES_TORQUESENSOR = ((uint16_t) 32),
	PAS_INVERTED = ((uint16_t) 64),
	DUMMY_ALWAYS_ON = ((uint16_t) 128),
	BYPASS_LOW_SPEED_REGEN_PI_CONTROL = ((uint16_t) 256),
	DYNAMIC_ASSIST_LEVEL = ((uint16_t) 512),
	TQ_SENSOR_MODE = ((uint16_t) 2048),
	ANGLE_CORRECTION_ENABLED = ((uint16_t) 4096)
} ACA_FLAGS;
It is transferred to the variable that can be changed at runtime during the init-procedere:
Code: Select all
ui16_aca_flags = ACA;
regards
stancecoke
IgorsLog   1 µW
Post by IgorsLog » Dec 05 2018 8:59am
Would it be possible to make the brake shift and throttle work separately? When you press the shift:idle. When you press the throttle: regeneration.
Need for a e-kickscooter ebrake.
stancecoke   10 kW
Post by stancecoke » Dec 05 2018 9:44am
IgorsLog wrote:
Dec 05 2018 8:59am
Yes, of course. You can do what ever you want :wink:
regards
stancecoke
glebor   1 µW
Post by glebor » Dec 08 2018 7:09pm
Hello friends :)
I have a problem with the LCD display KT-3
Well, the question is because LCD KT-3 in the old version work with the KT48ZWSRL controller, where there are only basic settings and type P. setting "C " not included.
I ordered new displays on aliexpress KT-LCD3 and they don't want to work with my old controllers, but with new sinusoidal controllers they work. What and where to upload for displays to work with an older version of the driver?
I don't know what it's all about, because I have KT-LCD-3 displays provided by the manufacturer of the software version V3.0 and I also bought the KT-LCD3 version V3.0 on aliexpress and these no longer work with old ones. They do not display, do not show speed, do not show watts, do not change settings.
haiyi911   1 W
1 W
Post by haiyi911 » Dec 14 2018 10:23am
Hi,stancecoke
whats the following lines meaning? calculate average? and how to calculate it?
in ACAsetPoint.c
“”ui32_erps_accumulated -= ui32_erps_accumulated >> 3;
ui32_erps_accumulated += ui16_motor_speed_erps;
ui32_erps_filtered = ui32_erps_accumulated >> 3;“”
