I found something intresting while playing with the firmware and settings. I mapping the motor spec angle for finding best maching.
I made this for a 2 year a go, but it leaving the feel that it was not perfect. So i did it now again with new instructions "wheel in air with full throttle without load".
Previously 25 deg would work for best.
Now i start from there "25°"by increasing angle by 5° steps and found that current and erps stay invariable until 45°. From here current starts to grow, but also i got more speed.. I continued until 65° when current measured externally was about 5,5A and erps is 400!! witch is about double from starting point
I repeat this test with adding roughly 150W load to motor for confirm that i can increase the speed while loaded this way. okay by sacrificing the efficiency..
By degreasing the corr angle below 15° leads to current grow and reduce speed. No good!
Now question: Is this same as what happens in proper field weakening? I believe not, just courious if i add "bonus" angle to offset in certain needs
eg activate (off-road and assist 5) simultaneusly would get me fast back home or propapbly really slow (pushing bike back without walk assist after smoke escapes)
Thoughts!?
Ps 25-30deg fit nicely in middle of sweet spot, so i will continue for using it.
Diagnostic screenshots below,
Cheers,
