KT Bluetooh Controller Problem
Good evening everyone,
I have a fat bike with 1000w motor, 48v 20ah battery, the controller is a dual mode KT bluetooh. Having problems like that the bike jerks in a few moments, I started investigating. I discovered the cause by doing various tests with my bike and that of a friend of mine with 1500w motor and KT bluetooth control unit. We realized that the problem occurs only if we use the bike without the app (KT smartbicycle). So if we use the app the bike works well, but if we use the display without the app the bike gives problems and jerks. We have a lcd5 and a lcd8h. The parameters are the same both on the app and on the display. I tried to unplug the dongle from the controller but nothing changes. Do you have solutions? We don't want to keep the app running all the time.
I tend to point out that, both my friend and I have this problem so I'm thinking kt bluetooh controllers suffer from this problem.
Thanks to everyone who will answer and sorry for my bad English.
Re: KT motor controllers -- Flexible OpenSource firmware for BMSBattery S/Kunteng KT motor controllers (0.25kW up to 5kW
Help me
Hi everyone,
I bought a KT72V and a 72V battery, my motor is a 48V.
Can I use the 48V motor with this voltage?
In my opinion, there is no problem but I'd like to be sure...
have good day.
have good day.
Maybe,if reducing the current it not be a problem.so the strength does not increase too much
I have 48v motor too (golden motor magic pie 5)
I've read many high voltage mods to my motor.
this is a dd motor.
I think,more suitable in this regard.
In this case it is wise to use a temperature sensor.
this is a dd motor.
Hi,
I bought a KT72VSVP. I tried to program it and it doesn't work.
I have already programmed a KT48VSVP, and had no problems.
I dont know what to do.
Does somebody have an idea?
Have a good day.
Have a good day.
Hello Sylvain,
Can you give more details about what isn't working? Can you flash it properly?
Maybe your undervoltage limit is too low or If you use no display there are 2 wires on the display socket to short : red and blue.
Hi,
I can flash it.
The LCD display works but :
- the speed remains at zero while I pedal.
- the battery indicator remains empty while the voltage display by the LCD is 81V.
I checked the speed signal, the torque and PAS signal...
The hall sensors work well...
Here is the screenshot of my OSEC configurator.
I can flash it.
Does anyone have a schematic for the KT controllers? I was especially interested in a diagram of the 12 fet one. I was also considering removing the dissipation resistor and replacing that with lm2596hv step down module to reduce power consumption.
Solder that shunt!
And motor doesn't spin ? try to untick External Speed sensorsylvain_wm wrote: ↑Feb 17 2021 7:00amHi,
I can flash it.
No, the motor doesn't spin, and no noise... nothing happens...
Here are 2 pictures of my controller. On the second photo, the two resistors heat up a lot !!! I measure 22V at their terminals ... that's huge!!!
Did you try to adjust the "Motor spec angle" parameter? start from 0 and increase by 5.
An other thing, you say battery your battery is at 81V, 235 as overvoltage value seems a bit low to me, try 240 for instance.
I tried 241 for overvoltage value.atkforever wrote: ↑Feb 17 2021 10:28amDid you try to adjust the "Motor spec angle" parameter? start from 0 and increase by 5.
I unticked External Speed sensor...
I tried different angles...
Nothing.
I wonder why my LCD display doesn't display the battery capacity and the speed...?
- stancecoke 100 kW
Make sure, that the brake is not active, otherwise the controller sticks in startup:
https://github.com/stancecoke/BMSBatter ... ain.c#L100
Flash in Diagnostics mode and log the sent data with an USB-UART-Converter or a HC-05 bluetooth module.
Show us the log.
https://github.com/stancecoke/BMSBatter ... stics-Mode
regards
stancecoke
How can I know if the brake is not active?stancecoke wrote: ↑Feb 17 2021 11:19amMake sure, that the brake is not active, otherwise the controller sticks in startup:
What data do you want me to send?stancecoke wrote: ↑Feb 17 2021 11:19amFlash in Diagnostics mode and log the sent data with an USB-UART-Converter or a HC-05 bluetooth module.
Show us the log.
In Diagnotics mode I notice the ui8_BatteryVoltage = 156 while I measure 80,5V... I expected more than 235...
- stancecoke 100 kW
If the controller is sending data in diagnostics mode, everything is OK with the brake.
by default this parameters are sent:
https://github.com/stancecoke/BMSBatter ... ain.c#L193
Code: Select all
printf("%u,%u, %u, %u, %u, %u\r\n", ui16_control_state, ui16_setpoint, ui16_motor_speed_erps, ui16_BatteryCurrent, ui16_sum_torque, ui16_momentary_throttle);
You can check the meaning of the control state with the little tool, or "by hand"
https://github.com/stancecoke/BMSBatter ... leshooting
The probably critical bits for over- and undervoltage are not implemented in the tool. So you have to analyze them by hand
2048 undervoltage
4096 overvoltage
obviously the calibration factor for the voltage is different for your high voltage controller.sylvain_wm wrote: ↑Feb 17 2021 12:33pmIn Diagnotics mode I notice the ui8_BatteryVoltage = 156 while I measure 80,5V... I expected more than 235...
regards
stancecoke
I used the default parameters and received this :
ui16_control_state = 28
ui16_setpoint = 0 and sometimes 5
ui16_motor_speed_erps = 0
ui16_BatteryCurrent = 313 ?????
ui16_sum_torque = 0
ui16_momentary_throttle = 73 ?????
I don't really understand these values.
Weird, the transmission is bad? I didn't have this problem with my other KT 48.ui16_control_state = 28
ui16_sum_torque = 0
- stancecoke 100 kW
There's very much noise on the UART line obviously.
The values are OK so far.
What kind of torque sensor are you using? You have to apply torque and turn the pedal at the same time to make the motor start.
Does the last value increase, if you apply torque on the crank?
You should print out the value of ui16_time_ticks_between_pas_interrupt_smoothed for checking the PAS interrupt. The value has to decrease, the faster you are turning the pedals.
The PAS interrupt seems to be the problem...
For debugging, it would be easier to test with a thumb throttle and not in torquesensor mode.
The values for throttle min and throttle max are not correct, obviously.
Concerning the not working display: have you checked the last XOR of the checksum? See the FAQs in the wiki how to check.
regards
stancecoke
regards
stancecoke
Thanks for your help.
It's getting late here in France.
I use a torque sensor from aliexpress : https://fr.aliexpress.com/item/33027685 ... 6c37IkGFF5
I'll do this first thing tomorrow morning.stancecoke wrote: ↑Feb 17 2021 3:07pmFor debugging, it would be easier to test with a thumb throttle and not in torquesensor mode.
I tried changing ui16_current_cal_b -= 1; using values between -10 and 10. Negative values made the wheel rotate itself and positive values did nothing to remove the resistance. I did accidentally change ui16_current_cal_b >>= 4; to >>=8 and as soon as the controller was switched on, the wheel spun up to ridiculously high speed, even faster than my old controller, without any throttle input which brings me on to the issues I have been having with the speed limits. It doesn't seem to matter what I set them to, some lower values give me slightly higher speed and setting them all to maximum makes the motor even slower. Gear ratio is totally random, As I increase it from 1 in steps of 5, some values give me higher speeds and others lower. For example, gear ratio 88 runs quite fast and on 89 it's much slower. It still doesn't spin as fast as the old squarewave controller I had no matter what settings I use for wheel circumference, gear ratio, etc. These are my current settings. I don't have any torque sensor or pedal assist connected to the bike. The hub motor is geared and is on a 20 inch wheel. Is there a way to just bypass or remove all the speed limit code as it seems to have some sort of bug in it?
Solder that shunt!
- stancecoke 100 kW
This is exactly the expected behaviour. Set the offset to a value that lets the wheel rotate slightly when the wheel is in the air and the throttle is closed. Then there can't be a resistance any more, as the motor will always produce a little positive torque.
?! a geared motor with regen?! There are only very few motors with this strange setup.
I recomment to read the wiki carefully, everything is explained there.
regards
stancecoke
Yes, the clutch in the motor has been welded.
No, everything isn't explained in the wiki. You mention schematics, where can I find them? Temperature sensors are mentioned. Where do I connect the sensor? x4 throttle doesn't even have a setting for it's upper and lower limit like the normal throttle does. Your suggestion to set all the speed limits to 100 does not work and you have done nothing to explain the strange behavior of the gear ratio setting. I don't want the wheel to rotate slightly by itself as that is wasting power. If I pedal faster with no throttle or regen input, the controller consumes more power. It is far worse efficiency wise than my old controller.
Solder that shunt!
- stancecoke 100 kW
To be honest, you're getting on my nerves
Please use the search function, try to understand what's happening in the code.
For the use of the BluOSEC app, ask @Xnyle, he has developed it, I'm not using it.
Nobody asked you to use our open source firmware.
regards
stancecoke
Edit:
Please show us logs of the power consumption of both controllers in various ride situations. The slightly spinning wheel will only draw very few current, maybe 400 mA. To have a measurable impact on the system efficiency, you would have to ride without electric assistance most of the time.
Hi,
It's OK, the value decreases while I pedal faster.stancecoke wrote: ↑Feb 17 2021 3:07pmYou should print out the value of ui16_time_ticks_between_pas_interrupt_smoothed for checking the PAS interrupt. The value has to decrease, the faster you are turning the pedals.
There is a problem : I connected a thumb Throttle as you suggested. I checked the signal on the 18 pin of the processeur, everything is OK : 0.8V min and 2.9V max for the THROTTLE signal. The problem is that I don't see any change with the BlueTerm app: i16_momentary_throttle remains zero.stancecoke wrote: ↑Feb 17 2021 3:07pmFor debugging, it would be easier to test with a thumb throttle and not in torquesensor mode.
