I saw an ebike hub motor kit for sale where I could choose between a 48V1500W or a 72V1500W Hub motor. I was not able to find the information so I'm asking here.
From my actual understanding:
A 48V hub motor can be run with 72V battery, but does a 72V hub motor necessarily has to be ran with a 72V battery?
Does the controller voltage rating has anything to do with the hub motor voltage rating? For instance, would a 48V rated controller work with a 72V rated hub motor?
And, I thought the controller amperage had to be higher than the battery, but I saw another source saying the opposite. What is the right answer?
