I have a hub motor 800w 60v, Connected to a controller 1000w 60v max 28A. and max speed is 32 km/h 18 inch wheel
And I need to make it go max 25 km/h, there is some way to put a resistor on the throttle, but how to?
There's a few ways. Some of them are in threads in this list, if it helps.
https://endless-sphere.com/forums/search.php?keywords=Speed+limit*&terms=all&author=&sc=1&sf=titleonly&sk=t&sd=d&sr=topics&st=0&ch=300&t=0&submit=Search
Some of the methods are better than others.
Using a resistor in the throttle can limit speed but it also limits max acceleration from a stop, because you can't get full throttle (thus not full power). (unless you also make a bypass switch).
Using an electronic limiter (like a Cycle Analyst v3, or whatever limitation your controller may have, activatable either by a wire pair/jumper or by programming it) would just limit the speed itself.
