Yes. Both of the cheap 12FETs on my trike do. One was sent by Dogman near the beginning of the SB Cruiser thread,
https://endless-sphere.com/forums/viewtopic.php?f=2&t=67833&start=25#p1025351
http://www.ebay.com/itm/271700702048?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
and the other I've forgotten now where it came from but it's origin is probably also posted in that thread, or CrazyBike2's. (I seem to vaguely recall it was sent to me while I was at Bill's after the fire in 2013).
The one from Dogman actually has better than plain regen, it has "EABS", "active braking", that actively powers the wheel against it's direction of rotation to force it to slow down faster. This uses power rather than recovering any but it works to a lower speed and it works harder all teh way down to that speed. With the X5304 on there it would brake hard enough to brake-steer the trike to the right that it requires significant steering input to compensate for it. It's not as hard with only the HSR3548 in it's place.
The other one is just regen, but it's a two-stage regen. Above a certain speed it's kinda weak, but once it drops below a certain speed it grabs harder. Neither level is spectacular, but it's there, and on a regular bike would work just fine.
Unfortunately neither controller actually uses it's hall wire inputs, even though they both have hall wires installed and all the motors tested with them have working halls. They only work sensorless, rather than auto switching between modes, or when the "learn" wires are used, etc. Annoying.
And the first one above has all hall and phase wires as green wire, all the same color. Guess it's their way of preventing you from bothering to try different combos, and forcing you to use the learn wires? Or just cheaper to make with only one spool of wire needed, rather than three?
