Time for MORE POWER! 1400a 1200v IGBT controller build!
Arlo1   100 GW
Re: Time for MORE POWER! 1400a 1200v IGBT controller build
Post by Arlo1 » Oct 13 2017 10:48pm
Lmfao So dumb to make you sign a NDA for a SW file :roll:
Anyways thank you very much. How much time from where I was to this did it take you and what all (short answers) did you have to do?
I will now start trying to make the layout.
-Arlin
My Leaf motor controller build. http://endless-sphere.com/forums/viewto ... 27#p963227
My YSR build http://www.youtube.com/watch?v=BRo8r5g4NBg
RC and most types of Lithium batteries you MUST know your individual cell voltages charging and discharging.
Don't keep them were you cant afford smoke or fire!
Support me on Patreon. https://www.patreon.com/user/posts?u=6842045
http://www.undergroundelectrics.ca/
Coolohm   1 mW
Post by Coolohm » Oct 14 2017 11:42pm
Love what you're up to man!
I've got a dozen Infineon fs400r07a1e3 IGBTs out of used TM4 inverters that I should do something with (if I can get time). Looks like they have part of the gate driver attached. First I need to figure out how to test them, then ditch the TM4 logic board and come up with something else.
For CAD I very much recommend the new cloud based system called Onshape www.onshape.com
It's from a bunch of Solidworks developers who got sick of Solidworks not doing anything with cloud based systems so they started their own (and raised hundreds of millions of $$$ venture funding).
I stopped using SW and have been using onshape for 6 months and making full professional parts and drawings that we outsource to manufacturers no problem.
Because it's cloud based it would be ideal for open source projects! In-fact it's free for open source projects. Free users have all the same functionality as paid users do, but free users are not able to make documents private therefore everyone can see them - also known as "open source" :)
Lebowski   1 GW
1 GW
Post by Lebowski » Oct 15 2017 12:42am
What if a company behind a cloud CAD tool goes bust or decides to start charging ? Then all your stuff is lost or behind bars ? With FreeCAD even 15 years from now you can still startup your old computer and access your designs...
Coolohm   1 mW
Post by Coolohm » Oct 15 2017 1:23am
Lebowski wrote:What if a company behind a cloud CAD tool goes bust or decides to start charging ? Then all your stuff is lost or behind bars ? With FreeCAD even 15 years from now you can still startup your old computer and access your designs...
It's possible but with this particular company unlikely IMO. They have an open API that you can use to automate pulling backups and then run from your browser. I'm willing to bet they will be around longer than photobucket and image shack hosted photos :lol:
I'd be happy to help with any CAD stuff for these cool projects.
coleasterling   100 W
Post by coleasterling » Oct 15 2017 8:23pm
Arlo1 wrote:Lmfao So dumb to make you sign a NDA for a SW file :roll:
-Arlin
It took a bit to figure out how to handle the workflow, but went okay from there. Prolly about 45 min total. You might verify dimensions against your parts. I had to infer some of them and some were different than your sketches. They should all be easy to change if something is amiss.
Basically just verified your sketches were close, then started making sub-sketches with individual pieces of the model I wanted to extrude. I started with the base aluminum plate and built up from there.
Happy to help!
-Cole
Arlo1   100 GW
Post by Arlo1 » Oct 16 2017 1:14am
Ok So here is my thoughts on how I want to lay it out. I will be working on options with solid works and by hand to get an Idea how it will go together.
It will be to use 36 of these MKP1848620704P CAPs which my math shows should be OK... But with the localized layout it should help the caps share the load better then a conventional layout.
14002 (800 x 657).jpg (38.9 KiB) Viewed 1242 times
Coolohm   1 mW
Post by Coolohm » Oct 16 2017 2:09am
How about rotating them 180 degrees so that they clamp onto a central extruded alloy "cooling tower"?
Something like this, which you could weld a plate on one end with two fittings, and a plate on the other with a notch out of the gussets so the coolant flows down then back up.
Arlo1   100 GW
Post by Arlo1 » Oct 16 2017 9:36am
Coolohm wrote:How about rotating them 180 degrees so that they clamp onto a central extruded alloy "cooling tower"?
Absolutely not.
The 2 big reasons are the caps will be in the middle making all 6 power switches share current from and to all caps much better and
the Driver boards will be outside to help reduce noise.
Now having said that the heat will be easier to remove from the outside. Having the heat sink face outwards will make air cooling work much better.
Remember even liquid cooling is air cooled. With something like this you want to keep the heat sinks as cool as possible and every time you have to transfer heat from 1 surface to another you have differences. If we put a heat sink right on the back and a fan on it that's the best we can do without using co2 or HVAC.
Arlo1   100 GW
Post by Arlo1 » Oct 17 2017 3:01am
Ok to day I come up with the Ideal layout for the buss bars! I am so Stoked!
I will try to add them soon. First I need to check a couple measurements because it seems the inside distance from + and - to the phase out are not quite big enough on the SW file.
After I sort that out and some problems with mates I will draw the bus bars.
1000hp3 (800 x 648).jpg (74.1 KiB) Viewed 1200 times
coleasterling   100 W
Post by coleasterling » Oct 17 2017 11:07am
Not 100% sure which dimension that is when looking at a plan view of the module. If that was built from your original sketch, that could be difficult. If you can highlight what's wrong and give me the correct dimension, I'll hop to fixing it. I also heard from my local distributor for Powerex, so they maaaayyyy be able to help get the official model. No promises, yet.
Arlo1   100 GW
Post by Arlo1 » Oct 17 2017 12:12pm
That's great news.
I measured the caps and they measure 21.11582 mm when the data sheet says 21.5mm I will measure the igbts then look for a measurement on SW later.
Arlo1   100 GW
Post by Arlo1 » Oct 17 2017 10:47pm
I found it.
The measure tool shows 126.86mm when its actually 128mm between these.
This is just enough room for 6x the caps i plan to fit in there.
Capture (800 x 661).jpg (43.52 KiB) Viewed 1160 times
coleasterling   100 W
Post by coleasterling » Oct 17 2017 11:16pm
Updated. I cheated and just made an extrude-cut to open up the space. I assumed an equal cut on either side. If that's not the case, it is adjustable if you edit the sketch in the last extrude-cut feature on the tree and change the dimension at the top.
[The extension sldprt has been deactivated and can no longer be displayed.]
Arlo1   100 GW
Post by Arlo1 » Oct 18 2017 12:01am
Sweet thanks. I was trying to figure that out.
Coolohm   1 mW
Post by Coolohm » Oct 18 2017 12:13am
Absolutely not.
Ah ok, I just assumed you would water cool with something this big.
Here's another probably dumb idea - What about putting it in a tube and having one large fan?
Arlo1   100 GW
Post by Arlo1 » Oct 18 2017 1:12am
To bulky,
I think a fan on each heat sink with the option to be water cooled.
Either way its easy to deal with cooling when the heat sink is on the outside.
A big reason for the SW work is to get the design layed out then use it for the heat sink design.
Arlo1   100 GW
Post by Arlo1 » Oct 22 2017 7:51pm
Bus Bars are partially finished!
All + and - buss will be paralleled on each end of the IGBTs to help the caps share current much better.
1000hp (800 x 693).jpg (60.07 KiB) Viewed 1077 times
Coolohm   1 mW
Post by Coolohm » Oct 22 2017 8:23pm
Ahh I see now the reason for the orientation - that makes the bus bars and caps very tidy!
liveforphysics   100 GW
Post by liveforphysics » Oct 23 2017 1:50am
I agree! Beautiful cap and bus bar layout!
Arlo1   100 GW
Post by Arlo1 » Oct 23 2017 2:44am
And here is the buss bars with the end connections rolled up I will make a triangle or circle buss that links the 3 in parallel on each end soon as well.
1000hp with bus (800 x 657).jpg (72.79 KiB) Viewed 1061 times
Post by liveforphysics » Oct 23 2017 3:11am
Looks so much easier to make than your last bus bars, and makes very clever use of the shared cap leg Inductance between banks. Beautiful.
coleasterling   100 W
Post by coleasterling » Oct 23 2017 12:15pm
Did you model the bus bars as sheet metal features in SW? If so, great job. That makes it a lot easier to unfold and send out for laser work.
Arlo1   100 GW
Post by Arlo1 » Oct 23 2017 1:16pm
coleasterling wrote:Did you model the bus bars as sheet metal features in SW? If so, great job. That makes it a lot easier to unfold and send out for laser work.
Yes they are. It also lets me change the thickness to what I can actually source when I get home. I need to dress them up a bit yet but it all a learning experience for me
Ohbse   10 kW
Post by Ohbse » Oct 23 2017 5:26pm
Amazing work Arlo! Once you CAD you never go back... Design is incredibly elegant! How are the driver boards going to integrate with the package?
Thumbs up for laser/waterjet cut bus bars. I might have missed it, are you going to have this one air cooled or integrate a waterjacket?
Arlo1   100 GW
Post by Arlo1 » Oct 23 2017 11:28pm
I am thinking about something like this to link the ends together.
Now to let everyone know.. HH is very doubtful this will work well. He let me know I am breaking all the design rules. But I know I am breaking the laminated buss design rule and my hope is because they are in side the middle it won't be such a big deal.
On that note I am not using ANYTHING laminated in the crx controller. Maybe it would be more successful with laminated buss but I have my doubts. I spent a lot of time testing that and could not prove the laminated buss helped my design at all.
I do want things to be laminated and the buss inside the IGBTs is laminated but you still need to add caps and other items and non of these parts are ever designed with to work in harmony with each other.
1000hp end links (800 x 610).jpg (51.49 KiB) Viewed 998 times
