Paralleling MOSFETs and IGBTs?
sa2tms   10 µW
10 µW
Post by sa2tms » Oct 20 2017 7:24am
Hi, first post on here. Got wind of this place existing from marcos' VESC variant being featured on Hackaday.
Anyway, a thought struck me the other day: IGBTs are good for higher currents due to their limited voltage drop. But there is also an almost constant bias to this drop, which is a disadvantage at lower currents. MOSFETs have the opposite properties - almost entirely linear I/V curve when fully saturated but higher voltage drop than similarly priced IGBTs at higher currents. So a thought occurs: why not parallel them? Both are driven the same way, typically have similar gate capacitances and voltages etc.
I decided to whip up a quick thing in Octave using numbers that fit two simplistic models to numbers in the datasheets for IXXX110N65B4H1 (used in the IGBT_board.pro KiCAD project) and IXFX100N65X2 (reasonably priced, low Rds(on), Vds >= 650V). Idea is we can populate a PCB like IGBT_board with six devices. How does the total power loss vs current vary with how many MOSFETs vs IGBTs we have? See attached figures.
As you might expect, one trades efficiency at higher current draws for efficiency at lower draws. Unless you just keep adding devices of course, and then it's just a question of BOM costs :)
MOSFET and IGBT models
Different numbers of IGBTs and MOSFETs in parallell, always six devices in total.
sa2tms   10 µW
10 µW
Re: Paralleling MOSFETs and IGBTs?
Post by sa2tms » Oct 20 2017 7:25am
And the Octave code for anyone interested:
Code: Select all
% Voltages to derive currents for
VI = 0:0.01:1;
VI2 = 0:0.01:1.15;
VM = 0:0.01:1.5;
% IXXK110N65B4H1 model
function V = v_igbt(I)
  % Mostly linear model with an exponential dropoff toward 0V @ 0A
  % Kinda stupid, but seems to follow Fig. 3. Output
  % Characteristics @ T_J = 150ºC well enough
  % Very little conduction until around 0.5 V
  Vth = 0.5;
  % Looks to be around 1.9V @ 100A
  % R = (1.9 - Vth) / 100;
  % "At 30A, 0.9v Vce = 27W per transistor"
  R = (0.9 - Vth) / 30;
  % Exponential term
  k = 5;
  V = R*I + Vth*(1-exp(-I*k));
endfunction
% IXFX100N65X2 model
function V = v_mosfet(I)
 % Worst case = Fig 3. Output Characteristics @ T_J = 125ºC
 % Be even more pessimistic by not accounting for the lower
 % resistance at lower currents
 R = 6.7 / 100;
 V = R*I;
endfunction
% Inverse of v_igbt
function I = i_igbt(V)
  Vth = 0.5;
  k = 5;
  % Initial guess
  I = V / R;
  % Newton's method
  h = 0.1/k;
  for x = 1:100*k
    I = I - h*(v_igbt(I) - V)./(R + k*Vth*exp(-I*k));
  endfor
endfunction
function I = i_mosfet(V)
  % Trivial
  % Avoid defining R twice be calling
  % v_mosfet with I=V and dividing away V
  I = V./(v_mosfet(V)./V);
endfunction
% Show models
% Base model has voltage as a function of current,
% But current as a function of voltage will be useful further down
figure(1);
plot(i_igbt(VI),VI, i_mosfet(VM), VM)
xlabel('Current (A)')
ylabel('Voltage drop (V)')
legend('IGBT model', 'MOSFET model')
% P/I curves for different configurations
II = 6*i_igbt(VI);
IM = 6*i_mosfet(VM);
IMIX  = 5*i_igbt(VI) + i_mosfet(VI);
IMIX2 = 3*i_igbt(VI2) + 3*i_mosfet(VI2);
figure(2);
plot(II,    II.*VI,
     IM,    IM.*VM,
     IMIX,  IMIX.*VI,
     IMIX2, IMIX2.*VI2)
axis([0,180,0,250])
ylabel('Power loss (W)')
legend('6x IGBTs','6x MOSFETs','5x IGBTs + 1x MOSFET','3x IGBTs + 3x MOSFETs')
billvon   1 MW
Post by billvon » Oct 20 2017 11:07am
sa2tms wrote:IGBTs are good for higher currents due to their limited voltage drop. But there is also an almost constant bias to this drop, which is a disadvantage at lower currents. MOSFETs have the opposite properties - almost entirely linear I/V curve when fully saturated but higher voltage drop than similarly priced IGBTs at higher currents. So a thought occurs: why not parallel them?
A few reasons:
1) Twice the gate drive losses, twice the parasitic (D-S) losses.
2) They don't share. On resistance of MOSFETs goes up with temperature - which means you can parallel MOSFETs and they will share quite well. IGBTs have their ON voltage go down with temperature, at least at lower currents - which means they don't share well. As a single IGBT gets hotter, it draws more and more current, until it is very hot and taking almost all the load.
(That means if you parallel MOSFETs and IGBTs, the IGBT will end up taking most of the current.)
That being said, an adaptive system (where the system switches from MOSFET to IGBT at some point) may be worthwhile if you have to design a system that has a very wide voltage range.
--bill von
sa2tms   10 µW
10 µW
Post by sa2tms » Oct 20 2017 3:27pm
A few reasons:
This I've anticipated. I have a potentially very clever or very stupid idea for reducing gate drive losses that I'm going to post so no asshole goes and patents it: bounce the gate charge to/from an inductor. Use this inductor both for charging and discharging the gate. Don't bother with a gate resistor. Keep the inductor current topped up to whichever charge/discharge current you need. Use an ideal diode to freewheel when not needed. Unless I've completely brainfarted on the physics this should keep the switching energy from being turned into heat as in a normal driver, apart from ESR losses of course. See attached KiCAD sketch (not pictured: oodles of voltage/current sensors, op-amps and switching logic).
Some critical things: L1 would need to be air wound or maybe a PCB inductor in an 8-32 layer board (thick copper, very wide traces, not overly many turns). Not sure if much can be done about D-S losses however. Maybe Cds could be discharged into the inductor before switching the device on?
billvon wrote: 2) They don't share. On resistance of MOSFETs goes up with temperature - which means you can parallel MOSFETs and they will share quite well. IGBTs have their ON voltage go down with temperature, at least at lower currents - which means they don't share well. As a single IGBT gets hotter, it draws more and more current, until it is very hot and taking almost all the load.
How do you even manage this with IGBTs then? Sounds like you'd have to monitor the current going through each one very carefully. Or stay out of that troublesome range..
marcos   100 W
Post by marcos » Oct 21 2017 5:53am
I wouldnt worry too much about gate driver losses, it could be 1 or 2 watts in a 10 kw system.
More imporant are switching losses in the drain/source while the half bridge is switching from 0 to 400v for example. That I×V do make a difference, and is easy to optimize by driving harder the gate and making the switching sharper. There is a limit of course given by the di/dt that your layout allows. And then there is how good your current sharing is between your paralleled devices,there are IGBTs out there that behave well in parallel applications.
A Model S has 14 IGBT in parallel, I wonder how that plot looks like.
sa2tms   10 µW
10 µW
Post by sa2tms » Oct 21 2017 12:41pm
marcos wrote:I wouldnt worry too much about gate driver losses, it could be 1 or 2 watts in a 10 kw system.
di/dt? Not dV/dt? As I understand it the main limit to switching is the resulting dV/dt on the gate potentially causing damage. Seems most drivers use a constant voltage + series resistor to the gate. So gate current drops as gate voltage increases. Plus a long time is spent in the Miller region. This seems kind of dumb to me when an op-amp could potentially overcome this. This sketch hopefully shows my thinking (zero effort spent drawing in any kind of compensation):
Ideally the gate voltage would rise with a constant dV/dt that is as high as one is comfortable with, right? My idea is you apply that square-ish signal to CTRL.
billvon   1 MW
Post by billvon » Oct 22 2017 12:26am
sa2tms wrote:This I've anticipated. I have a potentially very clever or very stupid idea for reducing gate drive losses that I'm going to post so no asshole goes and patents it: bounce the gate charge to/from an inductor.
That's resonant gate drive. We use that for our very high frequency (>2MHz) inverters.
What gets you is the Miller capacitance, which will prevent that from working as well as it seems like it should. But it will still reduce gate drive losses.
A few ways.
1) Don't parallel them. (There are some VERY large IGBT's available these days.)
2) Keep the load in the region where the imbalance is either zero or in the right direction (tough to do with motor inverters tho)
3) Ballast resistors, which work great but of course increase losses.
--bill von
sa2tms   10 µW
10 µW
Post by sa2tms » Oct 25 2017 4:51am
Aha, "resonant gate drive" are the magic words to search the literature for. Thanks :]
Seems gate drive losses indeed start to dominate as switching frequencies go up.
Good to see my mental model is sensible at least. Dumping enough charge into the gate to get past the Miller region as fast as possible would be quite a challenge.
As I suspected none of these are novel ideas. Darn!
