Power PCB for Lebowski Controller to be combined with Bobc's processor board
coleasterling   100 W
Re: Power PCB for Lebowski Controller to be combined with Bobc's processor board
Post by coleasterling » Apr 29 2019 11:45am
And we're done, minus our R1 and R2 that I had to order some more resistors for. I elected to go ahead and leave the board on bottom for testing, then will move it to the top later when everything is proven. I need to source some connectors for the brain board external inputs, as well. Any thoughts? I don't want to solder them directly. JST?
Power stage pics are before soldering the brain header back on.
coleasterling   100 W
Post by coleasterling » Apr 30 2019 6:36pm
Alright brain trust, tried powering up for the first time and it was a miserable failure. Tried powering up the brain board separately and saw the faintest flicker from an LED, then nothing. I can't see anything obvious as to why there'd be an issue. Anyone want to take a shot at diagnosing the package? Happy to pay for your time.
kiwifiat   100 W
Post by kiwifiat » Apr 30 2019 6:51pm
coleasterling wrote:
Apr 30 2019 6:36pm
The first thing you need to do is verify you have +5V going to the brain and +15V going to the fet drivers.
“You never know if quotes on the internet are genuine.” - Abraham Lincoln
coleasterling   100 W
Post by coleasterling » Apr 30 2019 10:10pm
kiwifiat wrote:
Apr 30 2019 6:51pm
No +15V or +5V, both on the power board and powering pin 14 (Edit: This was also a mistake?) with 35V and using pin 21, 17, or 9 as ground.
EDIT: Bad, bad, bad news bears. I've apparently killed the microcontroller. I gave it 5V power through the hall connection as seen in BobC's original thread and saw smoking on the dspic. Don't really have a clue what I did, which is probably the problem.
At this point, I'm happy to send the assembly away for someone else to fix and happy to pay for it. Whereswally606, interested?
Animalector   10 kW
Post by Animalector » Apr 30 2019 11:17pm
have you got the orientation of the board correct??
note that when you flip the board over, assuming your layout shows Pin 1 as Top-Right on the Brain board (the square pin), your Brain Board pin 1 actually goes to this pin shown... so note that there is a PIN translation, and you need to be careful how the board is oriented. I'd need to see the PCB layout and the schematic to be sure.
**EDIT**
I just read back through the thread, looks like you have it the same as others, that's probably not the problem though, I just get worried when I see people mounting boards upside-down underneath other boards, and then referencing pin numbers...
All good.
Andy
kiwifiat   100 W
Post by kiwifiat » May 01 2019 12:57am
Apr 30 2019 10:10pm
That is odd, powering the 5V rail directly would not under normal circumstances cause the magic smoke to escape. If Whereswally606 can't help you can send to me, replacing the DSPIC is not a big deal but I suspect there will be some other debugging required.
coleasterling   100 W
Post by coleasterling » May 01 2019 4:53pm
kiwifiat wrote:
May 01 2019 12:57am
Thanks sir! I'll keep that in mind. I didn't think there would be an issue with it either, though I suppose it could have been damaged from the first test?
whereswally606   100 kW
Post by whereswally606 » May 04 2019 4:48pm
Due to family and other commitments im not able to help. I also dont have the knowledge/tools that bobc or lebowski had/has to debug or fix and currently im not setup for producing any replacements anytime soon. Kiwifiat thats a good offer and if you need spare components i may be able to send you them if i have them. I do want to see these controllers working.
Distributing "Lebowski" FOC Controller PCB (Through hole) since 2016
Moped: Emax 110s 2009
coleasterling   100 W
Post by coleasterling » May 15 2019 11:06am
No trouble, thank you for all you've done already!
I've contacted Lebowski, but haven't heard back, yet. Kiwi, if you want a shot at it, I'm happy to send your way. I think we'll have to get Lebowski involved somehow, since it'll need a new dspic, but no need to have him do it all.
kiwifiat   100 W
Post by kiwifiat » May 15 2019 2:07pm
May 15 2019 11:06am
I'll pm you my address, I have a couple of dspic's I can use one of those now. When you order a replacement get Lebowski to send it to me directly.
Post by whereswally606 » May 24 2019 4:33am
Hey guys. This has been playing on my mind a while. I dont think the circuit for the 80v to 15v is anywhere near as robust as required. With that said i bought an 80v to 15v circuit on alibaba to off load this job from the brain board.
I will reiterate i have very limited time to help but i will send you the link to the part i bought which i havent tested yet.
It is kind of leveraging mass production abit as i think the parts cost and time to make this board is considerable. Plus if the 80v dc goes pop you can more easily solder in a new one. I would get a few spares on hand.
Wholesale Product Snapshot Product name is 12W DC 80V-24V to 15V HV DC-DC Buck Step-Down Converter Voltage Regulator Board Power Supply Module
https://www.aliexpress.com/snapshot/0.h ... 2822090487
Also i may have some broke brain boards which i can send you kiwi if you can help Cole as i am have zero time to help myself. I am grateful to both of you for pushing ahead with the project.
coleasterling   100 W
Post by coleasterling » May 24 2019 10:07am
Thank you for the link, but it seems to be dead.
Thanks for the offer on the brain boards! If we do end up needing one, just shoot me an invoice on paypal and I'll take care of it immediately.
kiwifiat   100 W
Post by kiwifiat » May 24 2019 8:49pm
whereswally606 wrote:
May 24 2019 4:33am
Thanks for the offer, the boards should turn up next week and I will let you know then. I am also keen to see lots of these controllers running after seeing what great results zombiess and Arlo1 got and every one built helps support Lebowski.
Animalector   10 kW
Post by Animalector » May 25 2019 2:41am
I'm doing that as well with my design (but I'm getting a part from Digi-Key) one day I'll get around to finishing it and actually building one up
Andy
kiwifiat   100 W
Post by kiwifiat » Jun 28 2019 11:08pm
Animalector wrote:
May 25 2019 2:41am
Andy
Your version looks very professional, it would be nice to see a lot of them in use.
kiwifiat   100 W
Post by kiwifiat » Jun 28 2019 11:31pm
Thanks to Whereswally606 who sent me two blown boards from which I was able to scavenge almost enough parts to repair Coles blown BobC board.
A big heads up to anyone using BobC's board and following the build instructions, there is a typographical error where it is suggested that the board can be tested by applying battery voltage to the "bat" pin which is pin 14 on the board. If you do that you will fry the DSPIC and depending on the voltage applied most of the other silicon on the board. The instructions should read BPOW. The BAT pin is in fact the battery voltage feedback pin and is connected directly to the DSPIC.
Attached a short video showing Coleasterling's repaired board in action on a small RC motor and a Heinzmann PMS120W.
https://youtu.be/Hy8pevKWNp4
minimum   100 W
Post by minimum » Jun 29 2019 3:43am
kiwifiat wrote:
Jun 28 2019 11:31pm
Yeah...
If anyone has an interest in Power PCB + BobC's board (with exact fallout described above) and with custom CNC-milled aluminum enclosure, please let me know. I have abandoned this project (in favor over nucular).
coleasterling   100 W
Post by coleasterling » Jul 01 2019 10:47am
Looking great, Kiwi!
Minimum, PM me with some more info if you would, please.
Post by whereswally606 » Jul 02 2019 7:37am
hey Kiwi to embed yt clips just put the code i.e. Hy8pevKWNp4 at the end in the tag. Sad that this is no longer really supported but at least you see the image of the video
coleasterling   100 W
Post by coleasterling » Jul 31 2019 7:42am
Lebowski wrote:
Jun 26 2018 2:48am
On the bottom of the PCB, on the left (so with the temperature sensor on the right), there is a line going from the battery voltage to the two resistors that feed the battery voltage to the processor board. I would put a switch in this line...
I'm torn on this one. What I really want is 3-step process for turning on, then arming the system. Initial turn on would precharge and close the contactor. That's easy. Second, I want to turn power to the controller on separately from the high voltage. This doesn't have to be done by the user. Maybe through the precharge relay? Third, I want a method to enable throttle with a big, nasty, bright or easily audible signal that the bike is armed and ready to go. There have been too many times already where people unfamiliar with electric bikes will play with the throttle and it isn't immediately apparent what state the system is in.
On the second one, you're talking about the far left line in the picture, correct? Just cut that and wire a switch in line? I have a voltage-rated switch that will do it just fine (not even close to $0.5).
Do you have any ideas on the third? I'm guessing it isn't a good idea just to interrupt the +5V to the hall throttle, no?
coleasterling   100 W
Post by coleasterling » Aug 01 2019 1:15am
And a little preview of what's to come, finished this guy tonight:
coleasterling   100 W
Post by coleasterling » Aug 01 2019 9:49pm
I originally planned to 3d print a lower case out of petg, but had a terrible print and I had some down time today when some parts for the rest of my mini bike didn't show up. I ended up machining the lower case and making some significant changes to end up with the board on top as I originally planned. I'm pretty happy with how it has turned out so far.
Altair   1 kW
Post by Altair » Aug 03 2019 5:06pm
Wow! Superb work on that case.
Think about the hours of work drawing, programming, and machining...
You're not going to get this beauty splashed with mud under the bike, aren't you? :lol:
coleasterling   100 W
Post by coleasterling » Aug 05 2019 2:29pm
Altair wrote:
Aug 03 2019 5:06pm
Thanks! I do this stuff literally every day for my business, so it didn't take just too long. Total time with heatsink and lower enclosure for design, machining, and finishing was around 8 hours. Changing the board to the top and wiring everything, that was awhile. Probably about the same amount of time. I'm slow at that stuff.
Post by whereswally606 » Aug 06 2019 4:05am
Looks amazing cole. Do a video please once its mobile. :D
