Power PCB for Lebowski Controller to be combined with Bobc's processor board
marcos   100 W
Re: Power PCB for Lebowski Controller to be combined with Bobc's processor board
Post by marcos » Jan 17 2018 4:53pm
Lebowski wrote:
Jan 17 2018 3:24pm
Thats the one position I tried, gave DRC error..
Thats why you first define your assembly and mounting points and then you do layout :mrgreen: . I wish I could help you there.
Don't you need through holes on the big terminals of the current sensors? Looks like you exposed the copper to use both layer as current carrying.
Remember that your control board connector is on the top layer and your actual control board is on bottom side. Maybe there is a chance you have that connector mirrored, I've seen that happen.
Lebowski   1 GW
1 GW
Post by Lebowski » Jan 17 2018 4:58pm
I come from the world of chip design and making layout for chips.... theres no mounting holes with chips :D neither with the processor board, no holes in the corners...
Njay   10 kW
Post by Njay » Jan 17 2018 5:04pm
You pull the tracks a little to the left, even just making them make half roundabout, making space for the holes.
Animalector   10 kW
Post by Animalector » Jan 17 2018 5:29pm
If you move the tracks and make yourself some mounting holes, we could use some 3d printed PCB clips that holds the edges of the CPU board. And then a touch of silicon to hold it.
I can model some clips of you give me the board spacing, PCB thickness and hole size.
Andy
Buk___   10 kW
Post by Buk___ » Jan 17 2018 5:48pm
Lebowski wrote:
Jan 17 2018 3:24pm
Just the presence of the holes? Or only with a screw in situ?
If the latter, perhaps those click-fit plastic standoff would work: Image
If the former, maybe self-adhesive standoffs would suffice:Image
marcos   100 W
Post by marcos » Jan 17 2018 5:52pm
These could save the day. Saved mine back in the day.
https://www.digikey.com/product-detail/ ... ND/2746023
It constrains you to 1.6mm thick pcb though.
Animalector   10 kW
Post by Animalector » Jan 17 2018 6:03pm
I was thinking exactly like that with press pins for the bottom (power board) but then the top (CPU board) would have edge clips that hold onto the sides of the PCB. Because there are no holes in the CPU board..
minimum   10 W
Post by minimum » Jan 18 2018 12:11am
Solderable "dummy pins" (from 2.54mm male-male SIL headers) to conserve PCB space?
Njay   10 kW
Post by Njay » Jan 18 2018 2:04am
minimum wrote:
Jan 18 2018 12:11am
Looks like a good idea until you need to take out the board for some rework or repair...
Lebowski   1 GW
1 GW
Post by Lebowski » Jan 18 2018 5:14am
I added 2.5 mm holes:
As already mentioned in the 3rd post of this thread, I see the need for mounting holes for a support for the processor board. But to sacrifice electrical performance, however minute, for some mounting holes ... hurts my engineering soul :?
Anyway, I had to route one line to the other side via 2 vias.. But I want to have all vias easy to solder through, maybe even with a small bit of wire. Don't really trust the manufacturers vias that much, plus some people may want to make their own boards at home. So the solder mask will be removed around all vias exposing the copper, and the hole will be relatively large for a via (0.8mm) to allow insertion of a bit of wire.
kawak   1 µW
Post by kawak » Jan 18 2018 7:22am
1 question/suggestion : it seems to me that we can pile-up 2 or 3 of this power board to make it a 12/18 FET controller. Apart from shorting the current censors on additional boards and keep them on 1 board only, what other modifications might be needed ?
whereswally606   100 kW
Post by whereswally606 » Jan 18 2018 7:52am
Better to have one brain and a bigger control board. Perhaps in the future Lebowski will extend on this design for higher power levels
Distributing "Lebowski" FOC Controller PCB (Through hole) since 2016
Moped: Emax 110s 2009
Lebowski   1 GW
1 GW
Post by Lebowski » Jan 18 2018 8:01am
kawak wrote:
Jan 18 2018 7:22am
Bit risky but worth a try. I think all it needs is resistors at the current sensor outputs such that the feedback voltage provided to the processor board is the average of the current sensor outputs. This way you can have 150 A sensors on each board, but for 2 or 3 boards in parallel the effective current sensor would be 300 or 450 A respectively. I would run a bit longer deadtime than absolute minimum to account for switching delays (runtime differences) between the different power boards.
emmgee   10 W
Post by emmgee » Jan 18 2018 11:17am
Glad that kawak was bringing it up. I like the piling-up idea following lebowski's "low inductance output stage construction" thread.
If three fully equipped Power PCB's would be stacked with their outputs from the current sensors in parallel (with common GND): Wouldn't the controller just 'see' the average voltage of the current sensors? No modifications needed, just split the battery and phase wires?
Modified Scott Nitrous, 74V, MagicPieV2, waiting for Lebowski-Controller.
Quantya Evo1 and eScooter vRone, waiting for Lebowski-Controller and brushless motor.
Lebowski   1 GW
1 GW
Post by Lebowski » Jan 18 2018 2:37pm
So this is what I have now, I think I will send it like this to PCBway to get 5 made :
I think I haven't posted the schematic yet:
schematic.pdf
(70.17 KiB) Downloaded 90 times
marcos   100 W
Post by marcos » Jan 18 2018 5:23pm
P1 silkscreen on the wrong side
P3 and P5 are probably connected to chassis. There is exposed copper like 1mm away with battery voltage.
Do those external dimensions fit nicely in an enclosure? extruded for example. I see no clearance on the edges to slide it into an extruded enclosure.
board ID? version? mfg date?
Its mostly random stuff that one might want, but forgets.
Lebowski   1 GW
1 GW
Post by Lebowski » Jan 19 2018 5:06am
Some good points there, thanks Marcos.
- I'm only putting the component outline in the silkscreen, not their designation (gets real messy real quick)
- reduced the copper circle around the 4 corner mounting holes
- On request from emmgee I've kept the width below 80 mm (it's at 78 now), so to add empty space for sliding... His bike will hopefully be the test vehicle for this build. Plus I'm only getting 5 boards and will post the Kicad data base in the first post of this thread, so everyone can make the changes they want
- added a date to the board ('jan 2018')
emmgee   10 W
Post by emmgee » Jan 19 2018 7:30am
By coincidence I was just checking the dimensions of a Lyen-type controller and a BMS this morning... both have a similar sliding case with inner dimensions of ~ 72 x 140 x 32 mm. With 78 x 145 mm at the moment we are very close, but a further reduction of a few mm in each dimension seems difficult. For the testing of the first boards it's maybe better to leave it as it is (works well for me!). Of course the future optimisation for a cheap chinese controller case would be nice, maybe (if waterproof) suited to be attached to the front tube.
What disturbs me... this mounting hole really hurts a bit... nowadays they attach loudspeakers with velcro to walls... ;-)
Lebowski   1 GW
1 GW
Post by Lebowski » Jan 21 2018 4:42am
Succesfully uploaded the gerbers to PCBway so board is being made :D
I added the Kicad database to the first post of this thread.
Lebowski   1 GW
1 GW
Post by Lebowski » Feb 16 2018 12:40pm
So the boards showed up :D
Made an aluminium piece to attach to the main heatsink, with an additional little screw for clamping the temp sensor
Fatting up traces with copper wire
A piece needs to be cut off the low side FETs source, as theres no hole for this leg:
First test setup for determining the gate resistors for the 4468 (note also the added insulation pads to the heatsink to prevent shorts):
Lebowski   1 GW
1 GW
Post by Lebowski » Feb 17 2018 6:43am
I've added a table to the first post giving recommendations for R_on, R_off and deadtime for different FET types.
I also added all scope pictures of the measurements, for reference.
Post by whereswally606 » Feb 19 2018 3:33pm
I've not soldered any headers to the boards yet but I notice yours are male headers from the power stage.
1) I don't know If I have female headers in a 12x2
2) I cant work out from your PCB which pins are which so I will no know which side to solder a header to even if I had one
(I will leave that to you I think), should make it flater to post.
btw I've been very Ill with tonsillitis but I am making some progress.
Lebowski   1 GW
1 GW
Post by Lebowski » Feb 19 2018 3:42pm
I will solder the headers on, i have tons of those in all kinds of configurations...
Lebowski   1 GW
1 GW
Post by Lebowski » Feb 20 2018 3:13am
built and ready for testing :D
Lebowski   1 GW
1 GW
Post by Lebowski » Mar 04 2018 5:14am
Results ! :D
