Speed controller and motor wattage
Ramsart   10 µW
10 µW
Post by Ramsart » Dec 04 2017 11:50pm
Hi,
Can anyone help my question i have 500 watt 36 volt motor can i use a 36 volt 350 watts speed controller
What are the disadvantage and will the speed controller have a shorter life span?
Is it better to use 500 watts controller instead?
Additional question whats the difference between sine wave and square wave which is better to use.
Manny   10 W
Re: Speed controller and motor wattage
Post by Manny » Dec 12 2017 2:43am
the 500 watt of the motor is the max, so driving it with a 350 watt controller is on problem.
the sine controller make less noise and can be smoother.
macribs   1.21 GW
1.21 GW
Post by macribs » Dec 18 2017 4:27pm
Motor ratings you can thing of as understated, most motors will handle way more and be happy doing so. People here run 14-15kw into a 3 kw motor. And have for years.
But to get motor to output more then rated power you need a bigger controller. If you use 350 watt controller, you will underpower your motor. Bigger is better for controller.
geoff57   10 kW
Post by geoff57 » Dec 31 2017 3:10am
Hi
To many degrees you can forget about the wattage rating of the motor a lot of my motors are only rated at 250w but I can pull 1.5kw out of them.
As for controllers there is a general rule of thumb whatever the wattage rating of the controller you can pull twice that, so a 500w controller will draw a max of 1kw when under maximum load, a side note if there are bridges or hills where you are you will need at least 500w to get over without peddling 750w would be better.
Geoff
DrkAngel   100 GW
Post by DrkAngel » Dec 31 2017 10:40am
Ramsart wrote:
Dec 04 2017 11:50pm
Hi,
350w controller should work with no "problems".
Performance on acceleration and hills will suffer!
But, top speed on level travel should be just as good.
Economy should improve, partly due to more efficient amp throughput, mostly due to encouraged pedal assist getting up to speed and on hills.
Index - Homemade Battery Packs - Updated - December 2019
EBike Toolbox - Bargains! $
Endless Sphere Wiki - Lost?
casainho   10 GW
Post by casainho » Jan 03 2018 10:13pm
Ramsart wrote:
Dec 04 2017 11:50pm
Go with a sine wave, as is more silent and efficient.
I suggest you to use this controllers that are sinewave: https://opensourceebikefirmware.bitbucket.io/
- TSDZ2 OpenSource firmware
