How can i control this 15kw motor
dewz   10 µW
10 µW
Post by dewz » Jan 06 2018 8:42am
Hello ,
i just bought this 15kw motor from accident Pao chun E100 (www.baojunev.com) car owner , but i have no idea how to use them because there are no wiring and no any detail about what i have . I already ask the car company they will not provide wiring for me :shock:
Motor have 8 wiring + 3 phase wire.
Can i use another controller and how to motor phase calibrating with another controller ?
Anyone have any idea for me ?
and if you want can ask me i have more motor like this.
amberwolf   100 GW
Re: How can i control this 15kw motor
Post by amberwolf » Jan 07 2018 2:22am
You'd need to know what kind of motor it is to find a controller to run it. There are probably some controllers (on the rather expensive side) that cna run multiple different types of motors, but the cheaper ones will typically only run one kind well.
The 8 wires you may be able to open the motor up and trace the wires to their electronics to see what they are for.
If it is a BLDC motor, they could be a set of three hall signals, plus power and ground for the sensors, plus a temperature sensor with it's own separate power/ground/signal, perhaps. Or it could be two independent sets of three hall signals plus their power and ground.
If it's some other kind of motor, it could be other types of position or speed or temperature sensors, etc.
dewz   10 µW
10 µW
Post by dewz » Jan 07 2018 6:50am
Thank you so much Amberwolf.
What i know it PMSM 115v
Punx0r   10 GW
Post by Punx0r » Jan 08 2018 5:22am
Ah, you could use the green controller if only you have a wiring diagram for the control-side connector!
Can you get a wiring diagram for the car it came from? That might be enough.
Or maybe find the manufacturer of the controller? It looks like a generic product, not one custom made for the car.
dewz   10 µW
10 µW
Post by dewz » Jan 11 2018 7:19pm
Thank you Punx0r ,
Now i know the controller is Sevcon Dragon8 ,that have only in China market. I am try to contact the manufacturer of this car brand . Still nothing update.
Punx0r   10 GW
Post by Punx0r » Jan 12 2018 4:07am
Ah, that's good you know it's a Sevcon - hopefully you can find a manual for the dragon8. Otherwise, maybe their other controllers use the same connector? Here's the pinout for the Gen4 model (page 3-11): http://www.thunderstruck-ev.com/Manuals ... l_V3.0.pdf
dewz   10 µW
10 µW
Post by dewz » Jan 14 2018 8:30am
Punx0r wrote:
Jan 12 2018 4:07am
Thank so much now . I already find the detail about Dragon8 , now only focus on the motor 8 pin. I have no idea about AB , UVW , Sin/cos , R .
Can you help ?
amberwolf   100 GW
Post by amberwolf » Jan 14 2018 2:58pm
We have no way of knowing what position/rotation sensors the motor is actually using, unless you can find the specifications for that exact model motor from the motor manufacturer.
But if it's 8 pins, and that last set of pins on the diagram above is 7 pins, and a thermistor is one more, there's a decent chance that is the kind of sensor it has, plus the thermal sensor.
As for how it's wired, though--you'd need to know that from the motor manufacturer or the vehicle manufacturer.
One other way you could find out is to get someone with one of the vehicles it came out of to let you use a continuity tester to test their wiring harness for where things hook up, and then you just build a new wiring harness that is wired like that.
Punx0r   10 GW
Post by Punx0r » Jan 15 2018 5:36am
I'm afraid I have no experience using Sevcon controllers, but a few on this forum have, so you might want to search for "sevcon" and see what they say.
The diagram above appears to show several methods for driving the motor, with regards to determining the rotor position for proper timing of the phase coils (with a rotary encoder).
Most of us here are used to "BLDC" motors that use three hall-effect sensors for this purpose.
U,V & W is just the traditional terminal designation for each phase on an induction motor.
I hope you can get it working - the Sevcon controllers are supposed to be quite good, although hard to program (but yours should already be programmed for the motor!).
sanfox   10 mW
Post by sanfox » Jan 15 2018 1:58pm
Yes you can control this motor by SEVCON, but you will need to find by experiments several internal parameters of your motor.
3250 km in hybrid mode
My car discription at http://www.evalbum.com/5316
amberwolf   100 GW
Post by amberwolf » Jan 15 2018 11:59pm
No, he won't, because the controller he has came with the motor and is already setup for it.
He just has to determine the wiring to use and build a wiring harness.
dewz   10 µW
10 µW
Post by dewz » Mar 12 2018 6:03am
Update
