Astro 3220 Rewind
coleasterling   100 W
Astro 3220 Rewind
Post by coleasterling » Mar 27 2018 2:31pm
I have a burned Astro 3220 and would like to do a rewind on it. I already stripped the winding from the stator, but it was damaged badly enough that I was not able to follow the scheme. Has any rewound a 3220 or other similar motor? Do I need to find and follow the same distributed scheme they used, or would a more standard wind be fine? This will be my first large rewind, so going to be learning a lot!
Miles   100 GW
Re: Astro 3220 Rewind
Post by Miles » Mar 28 2018 7:38am
Hi Cole,
It's 8P 24T which is an integer-slot winding.
Best to wind it as a single layer winding to get a winding factor of 1. That means the coil will span 3 slots.
See here for more information: https://www.emetor.com/windings/
Astro winding.jpg (154.66 KiB) Viewed 461 times
coleasterling   100 W
Post by coleasterling » Mar 28 2018 10:53am
Excellent, thanks Miles! That's exactly what I needed.
-Cole
coleasterling   100 W
Post by coleasterling » Mar 29 2018 2:20pm
On this topic, what's y'all's favorite source for wire? I had a site saved years ago for 200C rated stuff, but can't seem to find it now.
