QS 3000w midmotor
QSMOTOR   1 kW
Location: QS Motor,Jinqing Town, Luqiao District, Taizhou City, Zhejiang Province
Re: QS 3000w midmotor
Post by QSMOTOR » Apr 25 2019 9:02pm
The testing is without reduction, if with 1: 5.3 radio, the RPM is about 4139
For flux weakening report, will post later.
Grantmac wrote:
Apr 25 2019 10:35am
What about flux weakening for that motor? RPM including reduction it seems?
SiAECOSYS & QSMOTOR-Vito Ho
EV your life!
-QSMOTOR/Taizhou Quanshun Electric Drive Technology Co., Ltd. -SiAECOSYS (Export Dept.)
-International Sales Manager -Tel: +86 0576 88551619 -Skype: vito-ho -QQ: 289026969
-WhatsApp/WeChat: +86 13656892883 -Email: vito@tzquanshun.com
-Facebook: https://www.facebook.com/cnqsmotor/
-Aliexpress: https://siaecosys.aliexpress.com/store/5881618
QSMOTOR   1 kW
Post by QSMOTOR » Apr 25 2019 11:05pm
Controller of 1000w 2000w 3000w mid drive motor
For 1000w mid drive motor, we suggest EM50SP
Specification:
Unit price for sample:
1000w mid drive motor: $125/pc
EM50SP(40V/60V): $55/PC
EM7250SP: $70/PC
https://www.alibaba.com/product-detail/ ... 71d2LNPn3I
For 2000w mid drive motor, we suggest EM100SP
Specification
2000w mid drive motor: $192/pc
EM100SP: $155/PC
For 3000w mid drive motor, we suggest EM150SP
Specification
3000w mid drive motor: $235/pc
EM72150SP: $210/PC
EV your life!
lesta   1 µW
Post by lesta » Apr 26 2019 6:49am
Any Votol’s EM 300 controllers coming?
Grantmac   10 kW
Post by Grantmac » Apr 26 2019 12:53pm
Is the EM50 "peak current" battery or phase? Can you adjust phase current?
The EM7250SP is the 72v version right?
QSMOTOR   1 kW
Post by QSMOTOR » Apr 28 2019 1:14am
Have not now.
lesta wrote:
Apr 26 2019 6:49am
EV your life!
QSMOTOR   1 kW
Post by QSMOTOR » Apr 28 2019 4:02am
The peak current is phase current, rated current and boost current are battery current.
The phase current can be adjusted, but we do not suggest.
Yes, EM7250SP is 72V.
Grantmac wrote:
Apr 26 2019 12:53pm
EV your life!
Grantmac   10 kW
Post by Grantmac » Apr 28 2019 10:52am
QSMOTOR wrote:
Apr 28 2019 4:02am
Grantmac wrote:
Apr 26 2019 12:53pm
Why dont you suggest adjusting the phase current?
Also what is the maximum RPM of the 1000w when using flux weakening?
QSMOTOR   1 kW
Post by QSMOTOR » May 22 2019 9:38pm
Grantmac wrote:
Apr 28 2019 10:52am
QSMOTOR wrote:
Apr 28 2019 4:02am
Grantmac wrote:
Apr 26 2019 12:53pm
The phase current in the controller parameter is fix, you do not need to change it.
The max RPM for 1000w mid drive motor is about 4000RPM, the max speed can be about 50-60km/h
Thank you,
Judy
E-mail: judy@tzquanshun.com
EV your life!
larsb   1 MW
Post by larsb » May 24 2019 12:40am
I have got water in my motor so one hall sensor is dead. Opened up motor and there's a pcb that is activated by a sensor magnet ring.
I cannot find the exact hall sensor from the markings but it might be a copy of SS511AT from honeywell (precision bipolar SMT mount sensor) since it has C511A 145 marked on it.
Bartosh   100 W
Post by Bartosh » May 24 2019 2:44pm
larsb, this may actually be a (kind of) good information. However, seems like there was no sealant whatsoever under the little side cover, right? If so, I think you should get replacement parts under warranty. They should’ve applied some silicone in this place in production. Look at the photos attached. Apart from the fact my motor came with broken hall mount (they put some white goo to hold it, instead of replacing the damn thing), there is a substantial amount of blueish sealant applied on every cover. So I think you should report it to QS and expect a replacement. Hope you’re gonna fix the problem soon. Good luck mate.
Bikegirl   1 W
1 W
Post by Bikegirl » May 25 2019 5:20am
Just wondering what the shaft diameter is on the 1000w motor?
I'm looking to fit a powergrip belt and pulley to drive a 10inch go kart wheel with a bore of 33mm and 6 holes spaced the same as a 160 mm brake disc.
SRFirefox   1 W
1 W
Post by SRFirefox » May 28 2019 8:14pm
Can anyone confirm that this comes stock with a taper shaft and 22T pulley? Also, is 6600RPM a hard limit for the 3000W - as in the rotor will self destruct or is it more a limit for core and hysteresis losses, or just as fast as you can go with FW and 72V? I'd think being an IPM that it could probably handle some significant over speeding above it's rated RPM.
larsb   1 MW
Post by larsb » May 29 2019 10:51am
Yep, 3000w 138 70h motor comes with 22t pulley and tapered axle in stock version
larsb   1 MW
Post by larsb » May 29 2019 10:56am
Bartosh wrote:
May 24 2019 2:44pm
.. I think you should report it to QS and expect a replacement. Hope you’re gonna fix the problem soon. Good luck mate.
Thanks! I will get a replacement PCB from QS free of charge, it's on it's way :D
Bartosh   100 W
Post by Bartosh » May 30 2019 8:15am
Finally I got my hall mount and PCB replacement from QS. Free of charge, of course. So now it's time for some bench (re)testing. BTW I need to admit that I'm happy with the QS support after all :thumb:
Speedtospare   1 mW
Post by Speedtospare » May 30 2019 4:52pm
Excellent. Good to hear there supporting the motors. I'm looking into one as well for my next project
PITMIX   100 W
Post by PITMIX » Jun 06 2019 3:52am
hello I need to mount a 34 tooth pulley on this engine. Do you know if Qs motor can supply pulleys larger than 22 teeth?
You confirm me that the belt is a 8M 25mm wide? Thanks for your help.
Aixam 550 Twin retrophite Qs 138 70H, Thermo-Nucular electronics 24F, LG Chem 20s 60Ah
larsb   1 MW
Post by larsb » Jun 06 2019 4:00am
Guess you need to check with QS for the pulley. I guess no but it could be screwed to original pulley.
Belt is 8M20mm, pulley is 25mm wide but some clearance to flanges is needed.
PITMIX   100 W
Post by PITMIX » Jun 06 2019 4:15am
ok thank you for the answer I ask the question to Qs but for the moment I have no answer from them.
PITMIX   100 W
Post by PITMIX » Jun 10 2019 1:01am
hello, I asked the question to Qs to know if they can provide a pulley of 34 teeth but they propose me to replace it myself. They only shred the 22-tooth pulley, but if I want they can take it apart ...
larsb   1 MW
Post by larsb » Jun 10 2019 5:46am
The axle seems very non standard to me. Tapered axle, woodruff key.. Probably you'll need to machine another pulley quite a lot to make it fit. Will you have so small wheels that you need to go from 22 to 34?
PITMIX   100 W
Post by PITMIX » Jun 10 2019 6:02am
Yes because it is a heavy machine of 400 kg. The bridge has a reduction of 8 and it would take 7 or 6 at most.
With a 5kW engine running at 3500rpm, the speed is 30km / h with 8 réduction. But I want to 50km/h.
I found composite pulleys, it is necessary to machine the center to adapt it on the motor shaft. It seems perfect.
https://www.123courroies.com/modules/sh ... duct/72590
larsb   1 MW
Post by larsb » Jun 11 2019 11:28am
Will it hold in composite.. Could be easier to get a smaller driven pulley. What do you men 1:8?
Original gearing is 4.7, if you want 1:6 then you'd need a larger driven pulley
PITMIX   100 W
Post by PITMIX » Jun 11 2019 11:54am
On my vehicle there is a primary reduction and a secondary reduction. The secondary reduction is 8 turns for 1 wheel revolution.
I wanted to lengthen the reduction by installing a smaller pulley on the box than on the engine.But smallest pulleys are 22T.
Finally I think that with the pulley of origin it should work very well. Leaving a direct drive between the engine and the reducing bridge will make 4250 rpm to the engine for 50 km / h.
If the engine runs at 5600 rpm it will be 65km / h ... So the engine should not force too much and do not over heat.
ltu   100 mW
Post by ltu » Jun 21 2019 10:47am
hello
the motor can be shorter?
looking the disassebled video each cover have plenty empty room
