QS 3000w midmotor
ltu   100 mW
Re: QS 3000w midmotor
Post by ltu » Jun 21 2019 10:47am
hello
the motor can be shorter?
looking the disassebled video each cover have plenty empty room
ltu   100 mW
Post by ltu » Jun 21 2019 10:49am
because less 150mm wide motor can be more usefull for diy project
ltu   100 mW
Post by ltu » Jun 25 2019 11:13am
my question are:
can the side covernear the rotor ,in an inrunner,cause some drag?
same side are for the MXUS and QS design.both are outrunner but MXUS side cover are near flat,be less efficent due the field of the stator?
markz   100 GW
Post by markz » Jun 25 2019 5:13pm
There are a few "new" motors on the Cyclone TW website.
Gaston   10 µW
10 µW
Post by Gaston » Jul 02 2019 3:09am
There are a few "new" mid-motors on the QS website.
7 kW 180mm
10 kW 205mm
no details yet on price and availability
http://www.cnqsmotor.com/en/article_list_107.html
ctirad   10 W
Post by ctirad » Jul 29 2019 2:50am
QSMOTOR, do you plan to alternativiely equip your MID motors by SINCOS encoders instead fo halls?
Member of http://www.cezeta.com team
Erider VK2008 4kW electric scooter
Guewer Classic 2kW electric scooter (modded)
QSMOTOR   1 kW
Location: QS Motor,Jinqing Town, Luqiao District, Taizhou City, Zhejiang Province
Post by QSMOTOR » Jul 30 2019 6:47am
ctirad wrote:
Jul 29 2019 2:50am
Yes, for our new 180 90H 9000W mid drive motor we will use encoders instead of hall.
Judy -Powered by SIA
No QS Motor, No Super EVs!
-QS Motor/Taizhou Quanshun Motor Co., Ltd. -Taizhou SIA Trading Co., Ltd. (Export Dept.)
-International Sales -Tel: +86 0576 88551619 -Skype: vito-ho -QQ: 289026969
-WhatsApp/WeChat: +86 13575887162 -Email: judy@tzquanshun.com
-Official Web: http://www.cnqsmotor.com/en/
-Facebook: https://www.facebook.com/judy.gong.775
-Amazon: https://www.amazon.com/s?k=SPOKE+HUB+MO ... nb_sb_noss
PITMIX   100 W
Post by PITMIX » Jul 31 2019 3:21pm
My Qs motor 3kW with Risunmotor controller.
eee291   10 kW
Post by eee291 » Jul 31 2019 3:39pm
Is that.. a Microcar?!
I need to see this thing on the road please.
PITMIX   100 W
Post by PITMIX » Jul 31 2019 3:59pm
Yes it's an Aixam 550 Twin.
eee291   10 kW
Post by eee291 » Jul 31 2019 4:19pm
That's pretty cool :thumb: I'm guessing it's not road legal though?
Are you really just running 3Kw through that beast motor?
The display in the engine bay is quite hilarious :lol:
PITMIX   100 W
Post by PITMIX » Jul 31 2019 4:26pm
6,8kW on the video.
8kW max with this controller.
Controller is not mine. I made a temporary montage just to test.
A bike with a 6kW engine is illegal too.
eee291   10 kW
Post by eee291 » Jul 31 2019 4:57pm
I wasn't pointing out that it was illegal, rather curious if you would try to make it road legal.
Still, cool project mate :thumb:
I just bought myself a Fiat Uno for 50€ and after I run the engine dead I want to convert it to electric.
PITMIX   100 W
Post by PITMIX » Aug 01 2019 12:25am
For a real car I think there is more risk of getting fined by the police.
In France there is no technical control on the Microcar is one of the main reason to choose.
icecold   1 µW
Post by icecold » Aug 20 2019 6:47am
Hi
I have just purchased this motor (and the Votol EM150SP controller) to use in a 85cc dirtbike chassis.
What kind of battery would you recommend for maximum output of this motor? Power output and weight is prioritised. Run time not so much.
LiPo/Lifepo4...?
Voltage?
BMS max amp?
Link to a specific battery!?
Any help would be much appreciated.
(My very first post on this forum)
larsb   100 kW
Post by larsb » Aug 20 2019 12:04pm
I run 200A battery current at 72V and it pulls well :D
I’d aim for this.. but spec can offcourse be lower also.
Lipo if you want this current and low weight.
300A smart bms from icgogogo at aliexpress is good. There’s a looong thread on it here at ES.
https://m.aliexpress.com/item/32826820690.html
Ride on :D
QSMOTOR   1 kW
Post by QSMOTOR » Aug 30 2019 8:42pm
icecold wrote:
Aug 20 2019 6:47am
Hi
LiPo/Lifepo4...?
Voltage?
BMS max amp?
For this motor and controller you can use 72v 40Ah lithium battery, which can bear max 150A current.
icecold   1 µW
Post by icecold » Sep 05 2019 3:58am
I got my QS138 3000W motor and Votol EM150SP controller yesterday, I'm very exited to start building!
I think that I will go the LiPo way for my application since weight and size of a battery is a major factor.
The 300A BMS that larsb recommended will suite my needs, thanks for that tip larsb!
After some research I found that it seems that 6s batteries are much more common (and cheaper!?) than 5s batteries.
The original plan was to go for 20s 74V (4 5s batteries in series).
Would it be possible to go for 24s 89V instead (4 6s batteries in series)? Or would that be to push my luck a bit too much? The bike I'm building will run on small tracks and I imagine the longest full power bursts will last approximately 7-8s.
I look at batteries like this one:
https://hobbyking.com/en_us/turnigy-hig ... tore=en_us
larsb   100 kW
Post by larsb » Sep 05 2019 7:22am
It will blow the controller if you have the 72V.
24s is >100V which is above the component ratings
Ride on :D
SlowCo   100 kW
Post by SlowCo » Sep 05 2019 10:25am
@icecold:
So then go 3x 6s for 18s LiPo or 5x 4s for 20s LiPo:
j bjork   1 kW
Post by j bjork » Sep 05 2019 1:18pm
There are usually 4s packs too.. 2x4s+2x6s makes 20s
PITMIX   100 W
Post by PITMIX » Sep 08 2019 9:27am
hello I can not unscrew the nut of the engine pulley. Do you have a technique? I use an impact wrench with a 24mm socket and I left the strap on the transmission to prevent it from turning. I tried several times without success. thanks for your advices
SlowCo   100 kW
Post by SlowCo » Sep 08 2019 9:38am
Could it be left hand thread? Did you turn it the correct way?
PITMIX   100 W
Post by PITMIX » Sep 08 2019 9:41am
counterclockwise
SlowCo   100 kW
Post by SlowCo » Sep 08 2019 9:56am
If it is left hand thread you'll have to turn it clockwise to loosen it. But I don't know if it is LHT so someone who is certain should confirm (or deny).
