devo1223 100 W
Post
by devo1223 » Oct 07 2019 1:44pm
ZERONEST wrote: ↑Oct 06 2019 11:55am
Really interested in these motors from qs, does anyone have any experience with the 1000 and 2000w versions?
My 1000 has been really happy at 3500w, around 8:1 reduction with a 26in wheel. I don't have a temp gauge but will bump it to 5000w once installed The motor shaft is 17mm nontapered so the 3000 sprockets won't work, I use a 219 sprocket
- almost done (600 x 450).jpg (84.77 KiB) Viewed 2959 times
ZERONEST 10 W
Post
by ZERONEST » Oct 08 2019 12:34am
That would be great as im hoping to convert a crf50/pit bike which i believe has these same engine mounts!
devo1223 wrote: ↑Oct 07 2019 1:44pm
Thats pretty to good! If it could handle 5-6kw that would be perfect for my application but I'd really need the splined shaft for the 420 sprockets
SilverLine 100 W
Post
by SilverLine » Oct 11 2019 4:49pm
Does the hall sensors run on normal 5v ?
Thanks
PITMIX 100 W
Post
by PITMIX » Oct 12 2019 1:15am
SilverLine wrote: ↑Oct 11 2019 4:49pm
Thanks
Yes
Aixam 550 Twin retrophite Qs 138 70H, Thermo-Nucular electronics 24F, LG Chem 20s 60Ah
Skaiwerd 100 W
Post
by Skaiwerd » Oct 17 2019 9:52am
My 1000 has been really happy at 3500w, around 8:1 reduction with a 26in wheel. I don't have a temp gauge but will bump it to 5000w once installed The motor shaft is 17mm nontapered so the 3000 sprockets won't work, I use a 219 sprocketalmost done (600 x 450).jpg
This is good to know thanks. I know it’s a thread for the larger motors but hell the qs motors are underrated or what. I have the 1000w sitting on a shelf and it’s time to rethink its use. I put myself back n the que for a nuclear controller 12f, 4-5 month wait time.
One question, where did you find the 219 motor sprocket in the 17mm. Staton-Inc. perhaps?
Thanks
PITMIX 100 W
Post
by PITMIX » Oct 17 2019 10:06am
hello, be careful the 12F is able to provide 10kW peak. There it is 10x the nominal power of engine. You'll tell us what it does. I have a QS 3kW and it will turn with the Thermonucular 24F.
I'm eager to see how he run.
I preorder this from June.
Skaiwerd 100 W
Post
by Skaiwerd » Oct 17 2019 10:34am
PITMIX wrote: ↑Oct 17 2019 10:06am
Thanks for the heads up. I will start out with extremely conservative settings with the nuclear controller for sure. And make sure not to exceed limits that are damaging to the motor. I’m hoping regenerative braking can replace the rear brake and let me just use the disc mount for the sprocket. Keeps the hub/swing arm narrow and the bike more bike-like.
Grantmac 10 kW
Post
by Grantmac » Oct 17 2019 11:18am
Can you weigh the 1kw? Also will it fit between bicycle cranks?
Skaiwerd 100 W
Post
by Skaiwerd » Oct 17 2019 2:11pm
It’s 174.2 mm in length to the pulley front not including the nut. It comes in at 10 pounds for weight.
PITMIX 100 W
Post
by PITMIX » Oct 22 2019 4:21pm
devo1223 wrote: ↑Oct 22 2019 11:32am
The nulear 12F and qs1000 are perfect together...
Could you give details please
Skaiwerd 100 W
Post
by Skaiwerd » Oct 23 2019 9:20am
Best is to convert 17mm to 3/4”. Or use Denzel 4500 with 12mm shaft and convert that to 3/4”. Then you can use a 12 tooth.
https://azusaparts.com/product/sprocket ... -12-tooth/
Wheel sprockets go up to 105 for 8.75ratio
- F0D10BD8-3D9C-4B90-9DD6-B58FAD21D614.jpeg (26.78 KiB) Viewed 2495 times
PITMIX 100 W
Post
by PITMIX » Oct 23 2019 9:59am
Waouh yeeessss !!
He says 8kW peak but he write 300A peak.
I don't understand !
I think that is 300A peak on motor phases and 8kW nominal...
The ratio is 3,7:1 = 52T/14T
Torti 10 W
Post
by Torti » Oct 24 2019 12:54pm
What is this engine, new?
should also have 3000Watt
- QS-138-3-72V80KPH.jpg_q50.jpg (45.82 KiB) Viewed 2443 times
- QS-138-3-72V80KPH.jpg_q50 (2).jpg (19.41 KiB) Viewed 2443 times
eee291 100 kW
Post
by eee291 » Oct 24 2019 2:23pm
It's the same as the old one, this one has two mounts made into the case instead of the old bolt-on version.
This way you don't need to make an adapter plate like I had to do.
PITMIX 100 W
Post
by PITMIX » Oct 24 2019 2:32pm
Yes it's the same as mine! This is the Qs motor 3kW. The motor shaft seems different from mine. I think it's for a sprocket 428.
sn0wchyld 1 MW
Post
by sn0wchyld » Oct 24 2019 7:53pm
looks like it could do with a few more 'through hole' mounting points... then it could become a structural member of any frame its mounted to.
Skaiwerd 100 W
Post
by Skaiwerd » Oct 24 2019 9:08pm
Here it is now on Amazon. This must mean something if Amazon puts faith in selling some of these. I know it’s a drop ship and they just get a cut but still. Old style Motor case though.
- 945B70E5-6A03-4A3A-8971-B88A1926189C.jpeg (227.67 KiB) Viewed 2407 times
Torti 10 W
Post
by Torti » Oct 25 2019 2:28pm
Torti wrote: ↑Oct 24 2019 12:54pm
How many volts can the engine
SilverLine 100 W
Post
by SilverLine » Oct 25 2019 5:55pm
Usually the heat is the problem and not how much volt. But I know for a fact that 96v is not a problem
larsb 1 MW
Post
by larsb » Oct 26 2019 12:38am
@Silverline: I’d like to see a plot of noload losses from zero to max rpm with a fully charged 96V battery. It will show if losses are getting too large. Would it be possible to get?
What controller do you use?
