QS 3000w midmotor
larsb   1 MW
Re: QS 3000w midmotor
Post by larsb » Feb 22 2020 3:24pm
I’ve done 110km/h on the votol em150 qs3000w combination. Shouldn’t you get even higher speed?
Ride on!
SilverLine   100 W
Post by SilverLine » Feb 22 2020 3:46pm
larsb wrote:
Feb 22 2020 3:24pm
The battery pack I am using right now (20s2p spim08hp) goes pretty fast to 66v when i´m pushing it, and stays there for long time, but I think that it take down some topspeed. I´m in the making of building a new pack out of 21700 p42a Molicels based on the NESE system... They hold voltage much better.
john61ct   1.21 GW
1.21 GW
Post by john61ct » Feb 22 2020 3:59pm
Sorry which specific # model is the topic of this thread?
I find just using the supposed watts rating to be confusing.
Besides QS website, is there a resource with a summary listing of the variois QS motors, and their most-relevant minimal specs?
larsb   1 MW
Post by larsb » Feb 22 2020 4:09pm
It’s QS 138 70h 3000w mid drive.
Ride on!
Overclocker   10 kW
Post by Overclocker » Feb 22 2020 9:05pm
i'm trying to save some $$$ by using either of these 2 controllers i have lying around:
1) kelly KLS7230
2) yuyangking YKZ7280
any thoughts on using those? the #2 is a square-wave controller if that's an issue at all...
these IPM motors are more picky w/ controllers, right?
crf150rb   1 mW
Post by crf150rb » Feb 22 2020 10:18pm
Hey Im new to this, just purchased a 3000w motor and esc combo from qsmotor for an electric pit bike build is there anything to know? Thanks.
amberwolf   100 GW
Post by amberwolf » Feb 22 2020 11:00pm
crf150rb wrote:
Feb 22 2020 10:18pm
you'll have to list everything you already know for us to know if there's anything left to tell you.
crf150rb   1 mW
Post by crf150rb » Feb 22 2020 11:08pm
I know basic electronics and machine work. mainly concerned about having to program the esc and securely mounting stuff.
john61ct   1.21 GW
1.21 GW
Post by john61ct » Feb 22 2020 11:37pm
larsb wrote:It’s QS 138 70h 3000w mid drive.
Which I noted you run at up to 20kW right? So what is max peak phase amps?
And which controllers get that level of power out of it?
Any of them true FOC? conducive to keeping multiple motors in sync?
ideally with variable regen?
PITMIX   100 W
Post by PITMIX » Feb 23 2020 3:13am
Hello I use this engine with a Nucular 24F. The motor is 20kW with 500A phase and 300A battery. It does not heat up. I noted 31 ° C in intense use with 15 ° C outside. QS recommends 470A phases.
Aixam 550 Twin retrophite Qs 138 70H, Thermo-Nucular electronics 24F, LG Chem 20s 60Ah
larsb   1 MW
Post by larsb » Feb 23 2020 7:11am
Has someone burnt one of these motors yet? I don’t think so. Where is LFP when we need him..
Ride on!
john61ct   1.21 GW
1.21 GW
Post by john61ct » Feb 23 2020 12:11pm
Is there any downside to using a much bigger controller than what is required to max out a given small motor?
Other than cost size weight of course.
And assuming you have good protective limits, set appropriately low for the motor.
Wh per km efficiency better, worse, about the same?
larsb   1 MW
Post by larsb » Feb 23 2020 1:35pm
More fets, less resistance losses, lower temperature in the controller and mean time between failure is exponentially proportional to lowered temperature.
It’s sound to overspec the controller :D
Ride on!
flippy   1 MW
Post by flippy » Feb 25 2020 3:32am
john61ct wrote:
Feb 23 2020 12:11pm
bigger means better/more fets wich means lower IR wich means more efficinecy. usually higher tier ones can switch more accuratly/faster dus to better parts so they are a bit more effcient in general.
especially chinese controllers you need to keep below 75% or so of full power in order to keep the efficiency acceptable. industrial stuff like sevcon you can go crazy as they are made with the best parts money can buy and designed by really expensive enginerds.
Lithium beats liquid dinosaurs.
macribs   1.21 GW
1.21 GW
Post by macribs » Feb 25 2020 3:49pm
*enginerds*
That made my day. What a beautiful word. And so wonderfully descriptive.
larsb   1 MW
Post by larsb » Feb 25 2020 3:51pm
Even better when you’ve got the expensive enginerds :mrgreen:
Ride on!
flippy   1 MW
Post by flippy » Feb 26 2020 3:05am
macribs wrote:
Feb 25 2020 3:49pm
*enginerds*
guess what elechicken means then... :mrgreen:
Torti   1 W
1 W
Post by Torti » Feb 26 2020 12:38pm
does the 138 motor have a temperature sensor?
SilverLine   100 W
Post by SilverLine » Feb 26 2020 12:42pm
Torti wrote:
Feb 26 2020 12:38pm
Nope... not by default.... Maybe in the future...
eee291   100 kW
Post by eee291 » Feb 26 2020 1:26pm
Mine didn't have one either, I think it's an option though so just tell them before ordering.
PITMIX   100 W
Post by PITMIX » Feb 26 2020 1:51pm
Torti Look at the 18 page, it's very easy to install. It is necessary to dismantle the flange at the front of the motor and pass the probe through the electrical box with the motor phases.
Torti   1 W
1 W
Post by Torti » Mar 01 2020 4:13am
how many motor poles does the qs 138 have?
and does anyone know what needs to be set on the kelly controller?
pole pairs or the individual poles.
PITMIX   100 W
Post by PITMIX » Mar 01 2020 4:32am
5 poles
flippy   1 MW
Post by flippy » Mar 01 2020 5:32am
Torti wrote:
Feb 26 2020 12:38pm
its a option when ordering. als mention the type of sensor.
Torti wrote:
Mar 01 2020 4:13am
for a kelly it generally does not matter what you enter, its just for getting the right rpm to register in the controller so you can set the right rpm limits for speed control.
flat tire   1 MW
Post by flat tire » Mar 09 2020 6:47pm
Has anyone run this with ASI successfully?
How many RPM can it take before failure?
