Dirkro   10 W
Re: TSDZ2 mid drive -- Flexible OpenSource firmware for TongSheng TSDZ2 mid drive motor
Post by Dirkro » Jun 10 2019 1:06pm
Hi,
I made mesurments with input by an old style analog torque wrench and the values shown at menue 9.2
Input Value 9.2
0 Nm 50
10 Nm 60
20 Nm 69
30 Nm 78
40 Nm 91
50 Nm (98) maybe not fuly correct
I hope this helps to improve the calculation of input power. I am ready for testing :-)
Maybe we can try the simple way by calculating the power evey 1/10 second (I think that is the cycle in the software)
Use the average of last 4 (last 0.4 second ) values of rpms and torque.
Oh darling, this is not a new bike.. :roll:
daenny   10 mW
Post by daenny » Jun 10 2019 3:17pm
I just upgraded from 0.17 to 0.19 beta 8 I have to say I am very impressed! I just did a quick 500m around the block, and the bike feels as if I upgraded the motor :)
Of course, this is just an initial impression. I will commute to work ~9km one way tomorrow, so hopefully my first good impressions will be confirmed.
My setup is: 12s LiPo, 48V motor (set now on High Cadence mode), boost always enabled, start-without pedal rotation disabled (no ebrakes), no throttle, no tempsensor, no walk-assist, no cruise-control. Street-mode (limited to 27km/h) is enabled on startup
Things I have noticed:
- New button logic in settings is much more intuitive. One thing to consider might be to also allow short on/off presses to go back one level when in the lowest level, i.e. after changing a value. For instance, in the bike screen setup somehow all my settings were set to 0. So I needed to do: Short press on/off (go into level change mode), press up (change value to 1), long press on/off (go back), press up (select next sublevel), short-press on/off (select), press up (change value), long press on/off (go back), etc.
For me, in would have felt intuitive to short-press on/off to go back after changing the value.
- The motor is much quicker to respond, (I did not test 48v without high cadence mode yet)
- High cadence mode allows 110rpm cadence with just little power loss, whereas before the motor drastically lost power above 80-90 rpm
- I did not encounter the dreaded 2 second lags yet
- on very low torque, e.g. riding slowly in a low gear on a even surface, I previously had the the motor was switching on and off, this seemed a lot better in my first test
- Drag will pushing the bike back is gone
Thank you guys for the hard work!
Current build:
GSM Woosh Middrive, with VESC controller, color LCD Display and Teensy ForumsController:
https://endless-sphere.com/forums/viewtopic.php?t=84042
buba   10 kW
Post by buba » Jun 10 2019 4:31pm
Dirkro wrote:
Jun 10 2019 12:50pm
I think the function is implemented in the setup menue under item 7.2 Curent ramp up per second . Standard is 5, can be set up to 10. I would like to set it up to 12-15 if you ask me.
Will remember this for the next version. Definitely possible to increase the current ramp up.
Dirkro wrote:
Jun 10 2019 1:06pm
Hi,
I made mesurments with input by an old style analog torque wrench and the values shown at menu 9.2:
Input Value 9.2
0 Nm 50
10 Nm 60
20 Nm 69
30 Nm 78
40 Nm 91
50 Nm (98) maybe not fully correct
Thank you very much for the data and the willingness to test! The more data we have the better!
After the stable 0.19.0 release we can take a look at improving everything even more.
In short, you wish for a faster updating cadence value and more accurate human power measurements?
buba   10 kW
Post by buba » Jun 10 2019 5:01pm
daenny wrote:
Jun 10 2019 3:17pm
:bigthumb:
daenny wrote:
Jun 10 2019 3:17pm
The user elfnino mentioned something similar when testing a previous beta.
buba wrote:
elfnino wrote: #new button logic - to exit the submenu once the value is set the long press of on/off button is required however I think just a short press would be enough.
Now by exiting submenu with the long press I have ended occasionally two levels higher than initially wanted as well it takes more time to configure parameters.
Good note! I have decreased the time needed to hold the button. Much faster now but still not a click. I strongly believe it is best to have two different button events/actions for different menu actions so as to have a clear logic. I truly recommend this and would love that you test the new faster logic in the next beta as it should be better!
So after the feedback from elfnino, the button hold time was drastically reduced for the beta 8, daenny. But I understand you still feel it is slow. If you do not mind I will take a look at it and try to improve it for future versions. This is so that we can release a new stable version for all users and finally finish the development on the 0.19.0.
daenny wrote:
Jun 10 2019 3:17pm
Thanks for the analysis and feedback! Always interesting to hear. Especially when it seems that you are very satisfied with the 0.19.0 beta 8.
btslo   10 W
Post by btslo » Jun 11 2019 4:52am
Dirkro wrote:
Jun 10 2019 12:50pm
jbalat wrote:
Jun 10 2019 5:25am
Grisha_lv wrote:
Jun 08 2019 8:35am
jbalat wrote:
Nov 04 2018 11:59pm
Just some testing on the inverse ramp factor to reduce lag
Hello,
I'm new to this forum. I just installed and flushed Kt-lcd3 with my TSDZ2. I also experience this lag which you have mentioned before and would love to fix if but I don't now how. I already checked WiKi and watched your video about it and still didn't figure it out.
It it's not too much to ask could you please step by step guide me what exactly I have to do.
How to compile?
How to flash if back to the controller?
P. S. I really like your videos about installing and flashing Kt-lcd3 with TSDZ2.
Grisham I made one change to the variable using version 16 and that eliminated the drag for me. As I have not moved to any newer versions of the firmware I cannot comment as to whether it has been addressed or not. At the time boost mode was causing issues and had to be disabled. Perhaps someone else can answer. If this is fixed then you won’t need to compile it yourself.
JB
Is this used to reduce lag? There is still too much lag from 0 for my taste, for example it's impossible to wheelie from a standstill as power comes on later after about a second (I don't use boost as there is even more lag probably) Max ramp up I tried was 7 since I assumed higher values could damage the controller or blue gear. Torque values change instantly after you push on the pedals but takes some time for the power to come.
Also is it normal for the motor to still deliver power for about 1-2RPM after you stop pedalling? (especially in higher assists, similar to stock turbo mode, I have boost disabled)
And it seems the motor is louder than on stock firmware. Will try to grease it but it's already loud by design.
Dirkro   10 W
Post by Dirkro » Jun 11 2019 7:08am
buba wrote:
Jun 10 2019 4:31pm
Dirkro wrote:
Jun 10 2019 12:50pm
Dirkro wrote:
Jun 10 2019 1:06pm
Hi,
Input Value 9.2
0 Nm 50
10 Nm 60
20 Nm 69
30 Nm 78
40 Nm 91
Yes,you are right
There might be a bug in the calculation!!
In my setup, at a cadence of maybe 90 it takes about (feeling) 20 Seconds to climnb from 70 to 89. Zero is reached in one second , when stoping pedealing, when I start agaín (feels like 80 to 85) it is starting with 50,then climbing 60 , 70 but takes time !
Another thing, what can maybe be solved fast:
Could you please change the maximum Ramp maybe 15 A/s , it is 10A/s now (Menue 7.2)
Thank you very much!
buba   10 kW
Post by buba » Jun 11 2019 7:37am
Dirkro wrote:
Jun 11 2019 7:08am
buba wrote:
Jun 10 2019 4:31pm
Yes,you are right
There is a filter in the KT-LCD3 that filters the values. Have not developed this so can not say anything more about this except I will take a look at it. Thank you for the explanation, always great with detailed feedback!
Will change the current ramp up so a higher value can be used. But this will be made after the official 0.19.0 release. This is so the community can switch over to the stable 0.19.0 without creating another beta.
thineight   100 W
Post by thineight » Jun 11 2019 10:50am
Hello! Is the stable 0.19 released soon? If so, I just avoid to install the beta8.. or is it the same?
MTB KTM Ultra 29" - City bike DAYTONA 28"
buba   10 kW
Post by buba » Jun 11 2019 11:14am
thineight wrote:
Jun 11 2019 10:50am
Hello! I recommend to install the beta 8. If no one reports any errors the beta 8 will become the stable release. So you do not need to update then.
thineight   100 W
Post by thineight » Jun 11 2019 4:20pm
buba wrote:
Jun 11 2019 11:14am
thineight wrote:
Jun 11 2019 10:50am
Done it! Looks great so far!! :thumb:
There is just some wording mistakes left on the wiki due to the street-offroad logic change (e.g. menu 5-9). :wink:
As I consider more logic to have the street mode without the blinking ASSIST, I was wondering if I can invert the power and speed settings between the street and off-road menus, or if other functions act different between the two modes.
One last thing: in my case the assist 1 and 2 are set to 0.1 and 0.2 respectively (i.e. lower than most of the people here), as a consequence I have a delay in motor start due to the, let me call it this way, "actual resolution" of the motor.
With assistance 0.1 my motor kicks in with the minimum 20W only when my human power is 200W from the display, so after a little while. I guess there is a sort of ROUND function somewhere that cuts to 0 the motor power below 20W..
I guess this is happening only at very low assistance levels (not many people affected then), maybe after the release of the stable 0.19 we could evaluate to keep the minimum motor power instead of zero in the low ranges.
I think the actual logic follows the yellow path, leading to no assistance for the time from 0 to t0.
My idea is that the minimum motor power (20W) could be delivered also from 0 to t0, and after keep following the yellow path at higher assistance.
Please correct me if this idea is not applicable.
Many thanks.
buba   10 kW
Post by buba » Jun 11 2019 5:29pm
thineight wrote:
Jun 11 2019 4:20pm
buba wrote:
Jun 11 2019 11:14am
thineight wrote:
Jun 11 2019 10:50am
Great! :thumb:
Fixed! :wink: As always, thanks!
Wiki: https://github.com/OpenSource-EBike-fir ... ion-0.19.X
thineight wrote:
Jun 11 2019 4:20pm
Totally possible but the quick-set-power-menu will not be accessible in Street Mode. And if you wish to have throttle disabled in Street Mode (new feature) it will only work when in Street Mode. But if you are not using these features there is no problem at all.
I think there will be a future update where users can choose if they wish to have it blinking in Offroad Mode, Street Mode or not at all.
thineight wrote:
Jun 11 2019 4:20pm
Many thanks.
The "actual resolution" of the motor you speak of is actually extended throughout the operating range of the motor. This is due to the control algorithm relying on low resolution analog-to-digital-converters.
human power and motor power.png (6.76 KiB) Viewed 1584 times
But it is basically not noticeable except at the lower range.
I would presume that you wish for a smoother start with more resolution in said range. That is possible to implement in one way or another and something I have wanted to improve!
thineight   100 W
Post by thineight » Jun 12 2019 2:00am
Thanks buba, crystal clear!
For the blinking assist I can wait without problem.. this is a very low priority task.
For the initial power at low assistance I guess I can tackle the issue using the boost function (which I did not use so far), set for instance to 2.0 at assistance 1 (0.1) and 1.0 to the others where the delay is negligible.
Any future improvement is welcome anyway.
I will try to setup the boost and will report.
Thanks.
Uturn   1 W
Post by Uturn » Jun 12 2019 4:04am
buba wrote:
Jun 11 2019 11:14am
I have the tiny problem that the assist seems to switch on less quick than on 0.18. I drive PAS mode, and before, motor power came after 1/4 pedal turn. Now with 0.19 beta 8 I feel sometimes it will take 360° till the motor kicks in. (Motor only on torque sensor I tried but I do not like it).
casainho   10 GW
10 GW
Post by casainho » Jun 12 2019 6:14am
Usage of battery SOC based on Coulomb counting
I wounder how many users are using this feature on LCD3.
LCD3 implements 2 different ways to measure SOC: battery voltage and Coulomb counting.
There is an user reporting incorrect working of Coulomb counting SOC but I think is a bad configuration he did on LCD3 because he does not understand the configuration parameters. Battery voltage SOC on the other way is very simple to configure and seems good enough for me however, at begin of this project, I though battery voltage way would not be good enough.
If no one is using the SOC based on Coulomb counting, we could just remove it and that would make short the number of options on LCD3, avoid configuration error by the user, etc.
- TSDZ2 OpenSource firmware
Developer of OpenSource knowledge and technology for ebikes: Wireless Ebike boar ANT+ and Bluetooth, Flexible OpenSource firmware for EBikes: TSDZ2 mid drive motor, KT motor controllers and displays: Bafang 850C color, SW102 Bluetooth and KT-LCD3.
If you like my work, please consider making a donation to help my developments: paypal.me/jorgecasa
Dirkro   10 W
Post by Dirkro » Jun 12 2019 6:54am
casainho wrote:
Jun 12 2019 6:14am
Hi,
if you mean the backwards (forward) counting of the battery mW , then I can say that I am a fan of this feature and I use it regulary! For me one of the highlights :-)
casainho   10 GW
10 GW
Post by casainho » Jun 12 2019 7:03am
Dirkro wrote:
Jun 12 2019 6:54am
Hi,
And why? Can you please elaborate and compare with the other mode??
zappan   10 W
Post by zappan » Jun 12 2019 9:19am
I installed the ver. 0.19.08 the best I've ever tried, starting from Ver. 07 almost a year ago.
Congratulations to all the developers.
:bigthumb:
thineight   100 W
Post by thineight » Jun 12 2019 10:11am
casainho wrote:
Jun 12 2019 7:03am
Dirkro wrote:
Jun 12 2019 6:54am
Hi,
If the function you mention is the SoC from 100 to 0 based on the Wh consumed Vs the battery capacity.. I like that one as well.
It is easier to read than relying on a voltage reading (that is non linear with the discharge as far as I remember)..
But I also understand the fact that if you guys need more space for other useful function.. we can live without that indicator. :wink:
Nick   1 W
Post by Nick » Jun 13 2019 12:37am
casainho wrote:
Jun 12 2019 6:14am
+1
I use the counting of consumed Wh, too! Found my battery cell used in my pack here:
http://www.dampfakkus.de/akkutest.php?id=537
They tested the real Wh of one cell say at 2A and I can calculate the real Wh of my battery pack with this.
Even if the voltage drop is quite linear in the middle, some cells drop very fast at the end and Voltage-SOC will be quite unreliable there (when it is most important for me :wink: ).
Best regards
Niklas
Dirkro   10 W
Post by Dirkro » Jun 13 2019 1:26am
casainho wrote:
Jun 12 2019 7:03am
Dirkro wrote:
Jun 12 2019 6:54am
Hi,
For me this is the only reliable way to calculate the expected range while riding.
I have a battery with a quite high resistance (> 200 mOhm ) When I look at the current while I am standing still after a ride it is slowly going up during the first one or two in the range of 0.4V
My Battery is able to give me 350 Wh, counting back. So this counting is much more precise then the Voltage .
casainho   10 GW
10 GW
Post by casainho » Jun 13 2019 1:40am
Well, then maybe we could consider to make the graph change with this SOC instead of voltage and this be a configuration -- and I mean for future LCDs like SW102 and 850C because they have enough memory to implement that.
I really thought no one was using this feature... :-)
Uturn   1 W
Post by Uturn » Jun 13 2019 2:07am
Uturn wrote:
Jun 12 2019 4:04am
buba wrote:
Jun 11 2019 11:14am
I think this is related to having set the support level a bit lower than before, so it's not a problem.
daenny   10 mW
Post by daenny » Jun 13 2019 2:26am
casainho wrote:
Jun 13 2019 1:40am
I am also using the Wh counting, as I only use my LiPo cells from ~3.6V-4.1V as this prolongs the life of the cells. Thus the voltage based icon is useless for me as it shows half, when the cells are actually empty. I think it would be a great addition that the Icon uses Wh counting as SOC indication when this feature is enabled and Voltage if the Wh counting is disabled.
Current build:
spiked   1 mW
Post by spiked » Jun 13 2019 5:04am
daenny wrote:
Jun 13 2019 2:26am
casainho wrote:
Jun 13 2019 1:40am
I also rely heavily on the Wh counting feature, with my old Ping LiFePO4 battery. 5+ years old and still going strong!
Wh counting seems to work well for me - what was the problem reported?
Neil
P.S. I'm still on 17, about to make the move to 19.8.
dameri   100 W
Post by dameri » Jun 15 2019 7:30am
I took ride with v0.19.0-beta8 and it worked fine.
Tested walk assist, cruise and boost.
Big thanks once again for developers :bigthumb:
