TSDZ2 mid drive and 850C and SW102 displays only -- Flexible OpenSource firmware (Casainho code only)
casainho   1.21 GW
1.21 GW
Re: TSDZ2 mid drive -- Flexible OpenSource firmware for TongSheng TSDZ2 mid drive motor
Post by casainho » Aug 28 2019 5:59am
perryscope wrote:
Aug 28 2019 4:51am
Having said that I am hopeful that we may be able to program over Bluetooth from the outset so hopefully we wont need to open it at all :D
That should be possible already, Geeksville developed a bootloader and firmware that should be accepted by the original SW102 but none of us have in our hands and original SW102 so we can't test yet.
Please read here how to flash our bootloader and firmware on a new SW102, without open it: https://github.com/OpenSource-EBike-fir ... -525492910
- TSDZ2 OpenSource firmware
perryscope   100 W
Post by perryscope » Aug 28 2019 6:04am
casainho wrote:
Aug 28 2019 5:59am
perryscope wrote:
Aug 28 2019 4:51am
Yes, I actually have a untouched unit to try this with tonight so will let you guys know how I get on.
Empowered people support rider and trustee
www.empoweredpeople.co.uk
buba   10 kW
Post by buba » Aug 28 2019 6:17am
Rydon wrote:
Aug 27 2019 8:38pm
buba wrote:
Aug 10 2019 8:45pm
Rydon wrote:
Aug 10 2019 4:24pm
With A3 on coaster brake we are noticing that if you go from pedaling to brake quickly, as in an urgent braking situation, then backward resistance is there. If you then release the brake and then reapply the backward resistance is gone. Alternatively, if you have time to pause/coast before applying the brake, there is no backward resistance. Not absolutely sure but the resistance seems higher if you are in a higher level of assistance.
Good feedback and description! Will remember that and make some tests when I install the brake clutch! Did not expect I would be getting Coaster Brake feedback so soon so I do appreciate it as it prepares me for the different tests I need to do!
Thank you, Rydon!
Buba, just wondering if you had a chance to look at this with clutch installed. We did calibrate the PAS and had the same result.
Just installed the clutch and will do some testing!
Rafe wrote:
Aug 28 2019 5:43am
buba wrote:
Aug 27 2019 9:38am
Alpha 9 is up!
Here are the changes from Alpha 8:
- Walk Assist debounce time adjustable
- Walk Assist not changing assist level during accidental button bounce
- Some small display improvements
- Walk Assist, minor improvements
Thanks Buba you have made the walk assist mode just about perfect now :thumb:
That is great to hear!
GitHub: https://github.com/leon927
PayPal: leonstor at bredband.net
eyebyesickle   10 kW
Post by eyebyesickle » Aug 28 2019 6:21am
perryscope wrote:
Aug 28 2019 6:04am
casainho wrote:
Aug 28 2019 5:59am
perryscope wrote:
Aug 28 2019 4:51am
might want to hold off, I think I just killed a poor lil sw102 trying it. first one did take the update to completion, but after that..... crickets
perryscope   100 W
Post by perryscope » Aug 28 2019 6:33am
eyebyesickle wrote:
Aug 28 2019 6:21am
perryscope wrote:
Aug 28 2019 6:04am
casainho wrote:
Aug 28 2019 5:59am
perryscope wrote:
Aug 28 2019 4:51am
oh!, thanks for the heads up. are you able to try updating using the programming pins, or do you think its foo bared?
If it can be rescued by using the programming pins I am happy to take the risk, but will wait to hear before trying the Bluetooth method for now
casainho   1.21 GW
1.21 GW
Post by casainho » Aug 28 2019 6:55am
perryscope wrote:
Aug 28 2019 6:33am
Sure it is. We are trying to have 2 different ways to install our Bluetooth bootloader:
1. flash our bootloader using Bluetooth on a new SW102
2. flash our bootloader using SWD pins on a new or used SW102
If 1. fails, 2. will always work. Seems that we don't have yet 1. working.
buba   10 kW
Post by buba » Aug 28 2019 7:03am
Rydon wrote:
Aug 27 2019 8:38pm
buba wrote:
Aug 10 2019 8:45pm
Rydon wrote:
Aug 10 2019 4:24pm
Thank you, Rydon!
Just did a very quick test and I now know why there is a backwards resistance.
The problem is that the system only disables the motor if a couple of parameters are set. One of those parameters is the rotational speed of the motor. The rotational speed of the motor needs to be 0 if the motor is to be turned off.
There are two alternatives to solve this:
1. Allow to disable the motor if ERPS is below 40 instead of 0. From testing I noticed that I can get the motor to rotate to around 35 ERPS backwards so we need a threshold value of around 40.
2. Change the motor code slightly so it calculates backwards rotation as zero. (What I would do)
Casainho, would you mind if I change the motor.c code to address this issue? The hall sensor sequence should be:
Code: Select all
 hall sensors sequence with motor forward rotation: 4, 6, 2, 3, 1, 5
If it is anything other than that I would simply set ERPS to 0. This would disable the motor when Coaster Brake versions of the TSDZ2 are braking and remove the backwards resistance.
casainho   1.21 GW
1.21 GW
Post by casainho » Aug 28 2019 7:27am
buba wrote:
Aug 28 2019 7:03am
Code: Select all
For me seems good idea to go with 2. And yes, looking at the sequence of hall sensors transition is a way to find rotation direction.
buba   10 kW
Post by buba » Aug 28 2019 8:42am
casainho wrote:
Aug 28 2019 7:27am
buba wrote:
Aug 28 2019 7:03am
Code: Select all
No more backwards resistance when braking for the Coaster Brake versions! :) Just tested, works great! Will add a couple more changes and features that should make the experience even better. For everyone!
buba   10 kW
Post by buba » Aug 28 2019 9:49am
Rydon wrote:
Aug 27 2019 8:38pm
buba wrote:
Aug 10 2019 8:45pm
Rydon wrote:
Aug 10 2019 4:24pm
Thank you, Rydon!
Alpha 10 will be released tomorrow! Am finished with the changes but want to test it out some more and it just started raining. There will be several improvements and all users will benefit!
perryscope   100 W
Post by perryscope » Aug 28 2019 2:23pm
perryscope wrote:
Aug 28 2019 6:33am
eyebyesickle wrote:
Aug 28 2019 6:21am
perryscope wrote:
Aug 28 2019 6:04am
casainho wrote:
Aug 28 2019 5:59am
well I tried it but had the same issue as eyebyesickle. it took the bootloader update file fine. restarted but would not boot.
I tried multiple times to boot into DFU, but alas no joy . As It happened this was a unit I had opened but not yet programmed so i then connected via the programming pins and that method worked fine, so its working fine. but unfortunately no longer stock, to test again. i have a third unit arriving soon so we can test again on that. but for now. if anyone is willing to try this method be prepared to use the wired method if it fails.
casainho   1.21 GW
1.21 GW
Post by casainho » Aug 28 2019 2:34pm
perryscope wrote:
Aug 28 2019 2:23pm
Geeksville went very deep and is very experienced, I am almost sure he will be able to do it. Then, SW102 will be the recommended display on the wiki, as it will be the most easy one to install our firmware. Clearly much better for users than the first one we started with.
andrea_104kg   100 W
Post by andrea_104kg » Aug 28 2019 2:41pm
Today I did 2 tests: installed the alpha 9 version on the 36v engine, obviously it works great. thank you!
Unfortunately the emtb is still bad for me :-(
Later I tried to power the 48v bike with a 36v battery. It becomes very quiet, it is still fully usable on the road. I think we are the only ones who can use different batteries on a central :-)
Thanks again.
but a small test of emtb based on power mode, just to see if it works?
h27   10 mW
Post by h27 » Aug 28 2019 6:27pm
Hello
I am new to the forum and went through most of the post in this thread.
Great work - thanks to you big brains who have sacrificed so much time and effort to this project!
I I could not find an answer to the following beginner’s question here or in the wiki: I just ordered a 36v TSDZ2 motor, a 850C display and a 52V battery. If I want to flash the firmware to the 850C without the bootloader I will need the battery to power the display. Will this work with my wrong voltage of the battery (52 instead of 36)? Or would I first have to flash the motor/controller and set the correct value for the voltage? (And if the correct voltage has to be set first: How would I do that before my display works?)?
Thanks for your help.
casainho   1.21 GW
1.21 GW
Post by casainho » Aug 28 2019 8:13pm
h27 wrote:
Aug 28 2019 6:27pm
Hello
It will work with any battery voltage, don't worry.
btslo   1 W
Post by btslo » Aug 29 2019 3:42am
andrea_104kg wrote:
Aug 28 2019 2:41pm
Thanks again.
Try a higher sensitivity for emtb, like 6-7 or 8.
Rydon   100 W
Post by Rydon » Aug 29 2019 2:15pm
buba wrote:
Aug 28 2019 8:42am
That is awesome news. You guys truly rock!
elem   100 W
Post by elem » Aug 29 2019 2:31pm
V 0.20 alpha 8 tested in a MTB ride, full ride using eMTB sensibility 7 , 32km 1000m D+, 275Wh used :bigthumb:
eMTB could save energy :banana:
RockRider 9.1 TSDZ2 open source firmware .
andrea_104kg   100 W
Post by andrea_104kg » Aug 29 2019 4:06pm
Today tour of 53 km, 800m altitude difference v. 20 alpha5, no off-road but all unpaved roads.
Full gt force mtb bike. Everything perfect, used only power mode trying to save on consumption but not too much, about 600wh consumed.
Thanks to the modification of the engine he never reached even the 70 ° even on slopes of 20%.
Weight of the cyclist over 100 kg. Maximum satisfaction!
elfnino   100 mW
Post by elfnino » Aug 30 2019 4:27am
Have just a few points for the A9 finetune:
Odometer field 7:2,3
While setting average or peak speed in Odometer Field the AVG and MAX indication is shown in Wheel Speed Field and desired speed is shown in both fields (Odometer and Speed). However there is bug when AVG/MAX indication disappears after Odometer field menu 7 is changed and the desired speed value (peak/average) still remains in Wheel Speed Field.
Personally I would like to keep Current Speed in Wheel speed while simultaneously having average/peak in the Odometer Field.
I don't see any benefit of having same value in two field in the same time but community might not agree with me. But at least the the disappearing indication could be fixed easilly..
Cruise & Walk assist lunch from eMTB mode
With A9 the eMTB is really nice :bigthumb: however each time to start Walk assist I have to downshift from eMTB to Assist level which is little annoying.
buba   10 kW
Post by buba » Aug 30 2019 4:38am
andrea_104kg wrote:
Aug 28 2019 2:41pm
Thanks again.
Very glad to hear that you had a great experience on the 36 V motor! :)
I am afraid to change the eMTB now because:
1. Users already use the current eMTB and some are satisfied.
2. I would need to create another eMTB based on power so users can switch between eMTB modes. This would take up more space and I am not comfortable to "borrow" more space when there are a lot more things to fit inside the motor controller.
It will be possible to further improve everything in the future. And then experiment with more functionality and different implementations! Imagine the difference the torque sensor calibration will have that Casainho is planning! So do not perceive the 0.20.0 as the final version. This project will always steadily improve and evolve!
I value the feedback from the community immensely! There will always be someone that thinks of something and then someone else thinks of another thing. And a third thing gets to be implemented that is perfect for all. Together we are slowly making the world's best firmware for the TSDZ2. Without the user suggestions and different views from everyone we would be nowhere close to the firmware we have today.
So I do hope you understand I respect your desire for a power based eMTB! It would be very simple to implement but it needs to go together with everything else planned. It will just take time and cooperation to make everything fit. For the time being, I truly hope you are satisfied with the Power Assist mode and that everything else is working perfectly for you! :)
buba   10 kW
Post by buba » Aug 30 2019 4:42am
elem wrote:
Aug 29 2019 2:31pm
Amazing, Elem! :bigthumb:
andrea_104kg wrote:
Aug 29 2019 4:06pm
That sounds great! :bigthumb:
buba   10 kW
Post by buba » Aug 30 2019 4:54am
elfnino wrote:
Aug 30 2019 4:27am
That is actually a "feature" so that users can switch between Current/Average/Max speed and decide what they want in the Wheel Speed field to be displayed. This is similar to how many other e-bikes have it but you would prefer it to be limited to the odometer field? Or maybe only display when in the wheel speed sub menu?
More user inputs are welcome so we can decide for the best setup!
elfnino wrote:
Aug 30 2019 4:27am
Glad to hear that, Elfnino! :)
Cruise should work when using eMTB but Walk Assist is different because you need to choose assist level for Walk Assist. And that is mainly why it is disabled when the assist level is 0 or eMTB. I would recommend to reduce the number of assist levels so you have less clicking to do and can quicker get to the assist level you need. Let me know if you have other suggestions!
Maybe: 3-4 Assist levels + eMTB? (If I am suggesting a setup you already use, I do apologize!)
elfnino   100 mW
Post by elfnino » Aug 30 2019 6:23am
buba wrote:
Aug 30 2019 4:54am
elfnino wrote:
Aug 30 2019 4:27am
Let's wait for more inputs..
Nevertheless in current implementation the display graphics AVG and MAX are not shown when Average/Max is selected
and Odometer Field has other than menu 7 selected. (It is displayed properly only with menu 7 in Odo field) I think it is kind of bug which could be fixed.
buba wrote:
Aug 30 2019 4:54am
Actually less assist levels is not really helping. I use eMTB as the most powerful mode on the most difficult terrain and sometimes terrain is so difficult that I need to drop from the bike and use the Walk Assist and then continue with eMTB so it looks like : eMTB->Assist4->Walk->eMTB->Assist4-Walk . . .
May be the Walk Assist which is run from eMTB mode could inherit PWM duty cyckle value from the latest Assist level ?
Perhaps it is not that easy as I see it :)
buba   10 kW
Post by buba » Aug 30 2019 6:42am
elfnino wrote:
Aug 30 2019 6:23am
buba wrote:
Aug 30 2019 4:54am
elfnino wrote:
Aug 30 2019 4:27am
Now I see and understand what you mean! You are correct, the symbols are not displayed! Will fix and thank you for your quick reply! Can add this to the Alpha 10 thanks to your help!
elfnino wrote:
Aug 30 2019 6:23am
buba wrote:
Aug 30 2019 4:54am
Do you mean that it should use the assist level just before eMTB? That could be possible to fix but I am afraid that some users have really high values and could get surprised if accidentally on eMTB and enabling Walk Assist.
I understand the inconvenience you are trying to solve though!
EDIT: Have fixed the bug you reported! Thank you!
