TSDZ2 mid drive -- Flexible OpenSource firmware for TongSheng TSDZ2 mid drive motor
michih.   1 mW
Re: TSDZ2 mid drive -- Flexible OpenSource firmware for TongSheng TSDZ2 mid drive motor
Post by michih. » Feb 22 2019 12:57am
I have the smal Display on my other bike with a bafang bbs02. I musst say, yes is enough Information and the Bluetooth Update and configuration via App is great!!!
Mfg Michael
gaber   10 W
Post by gaber » Feb 22 2019 5:59am
gaber wrote:
Feb 20 2019 3:37pm
Running into an issue with 18.0 that I'm hoping is just a configuration problem that you guys can help out with. Assist is working properly from a stop, but then 3-5 seconds later it cuts out. Almost like I have boost turned on (I have boost disabled) and when boost fades out there is no power there. I can get the assist to kick back in, but only after wheelspeed has returned to 0.
Any thoughts?
Any ideas on this? Would it be beneficial to wipe my configurations back to factory and try that? (not sure how to do that) This is my first time troubleshooting things, I remember conversations somewhere in the history of this thread on how to do that....but couldn't find anything captured in the wiki. TIA!
sometimes you eat the bear, and sometimes, well, he eats you.
michih.   1 mW
Post by michih. » Feb 22 2019 9:15am
gaber wrote:
Feb 22 2019 5:59am
gaber wrote:
Feb 20 2019 3:37pm
Any thoughts?
Motor assistance startup without pedal rotation.
Set this to 0
Mfg
shaddi   100 mW
Post by shaddi » Feb 22 2019 9:36am
Anybody trying to build the latest github code under linux? Im getting a crashing sdcc :(
Code: Select all
sdcc -c -I../../common/STM8S_StdPeriph_Lib/inc -I. -I../../ -mstm8 -Ddouble=float --std-c99 --nolospre --out-fmt-elf   -olcd.c lcd.c
*** buffer overflow detected ***: sdcc terminated
Linux Mint 18.2
SDCC : stm8 3.8.0 #10562 (Linux) (crashing with 3.7, too)
casainho   1 GW
1 GW
Post by casainho » Feb 22 2019 9:42am
shaddi wrote:
Feb 22 2019 9:36am
Code: Select all
Linux Mint 18.2
I think that happens when static variables inside functions are initialized, see the comment on main.c file about this.
Other times happens when variable names are too big.
Developer of the Flexible OpenSource firmware for EBike motor controllers (TSDZ2 and KT) and LCDs (KT-LCD3 and Bafang 850C color LCD).
shaddi   100 mW
Post by shaddi » Feb 22 2019 9:54am
Fyi: Tag v0.18.2 can be compiled without any problem.
gaber   10 W
Post by gaber » Feb 22 2019 12:15pm
michih. wrote:
Feb 22 2019 9:15am
gaber wrote:
Feb 22 2019 5:59am
gaber wrote:
Feb 20 2019 3:37pm
Any thoughts?
Set this to 0
Mfg
Thanks for the suggestion, unfortunately it didn't fix the problem. Any other ideas before I just flash the LCD with zeros and reflash 0.18.0?
gaber   10 W
Post by gaber » Feb 22 2019 2:09pm
gaber wrote:
Feb 22 2019 12:15pm
michih. wrote:
Feb 22 2019 9:15am
gaber wrote:
Feb 22 2019 5:59am
gaber wrote:
Feb 20 2019 3:37pm
Any thoughts?
Set this to 0
Mfg
Fixed it! Just needed to flash zeros to wipe everything out, then reflash and reconfigure the LCD.
Rafe   10 W
Post by Rafe » Feb 22 2019 2:16pm
gaber wrote:
Feb 22 2019 12:15pm
michih. wrote:
Feb 22 2019 9:15am
gaber wrote:
Feb 22 2019 5:59am
gaber wrote:
Feb 20 2019 3:37pm
Any thoughts?
Set this to 0
Mfg
Check that you have not inadvertently selected Max power to 25 watts, this is exactly what happens if it is. It is very easy to do when pressing the up button to also press the enter below at the same time and that takes you into set max power mode, and it usually notches up one setting from the default off setting of zero and that next setting is 25 watts.
gaber   10 W
Post by gaber » Feb 22 2019 7:13pm
Rafe wrote:
Feb 22 2019 2:16pm
gaber wrote:
Feb 22 2019 12:15pm
michih. wrote:
Feb 22 2019 9:15am
gaber wrote:
Feb 22 2019 5:59am
Set this to 0
Mfg
Had also checked that. Whatever it was got reset with the flash.
eyebyesickle   10 kW
Post by eyebyesickle » Feb 22 2019 10:43pm
elem wrote:
Feb 21 2019 12:39pm
Yes, it could be amazing to use this SW12 witch is small, if BT work ...
I m using bryton rider and don t need all informations from LCD3, when the software is OK .
My only need is configure perfectly assist level for my need and save battery usage .
I was going to post a video to show you the progress (have it working with SW102 already) but then I accidentally fried my controller =( =( =( =( NOOOO!
I have not done that in a while - rookie mistake.
I have a batch of SW102 with bluetooth coming, withthe TSDZ2 compatible firmware... if people are seriously interested in working or helping with the project, I will send a few out... I think I can spare maybe 3 Units, 1 of which is reserved for casianho... if you are interested, let me know
eyebyesickle   10 kW
Post by eyebyesickle » Feb 22 2019 10:44pm
AZUR wrote:
Feb 18 2019 10:35am
SW102 display is a good solution, if it works, for a small display and with Bluetooth.
If we want a small display we can have it without an usb port.
It's a display, not a smartphone charger.
Regards
Winner winner, chicken dinner =)
:mrgreen:
casainho   1 GW
1 GW
Post by casainho » Feb 22 2019 11:10pm
Help with math to setup assist levels
I need to setup assist levels on my girlfriend new bicycle and I would like to have a formula that I could use to setup the assist levels to my son bicycle and even mine. If we know how to do it, I can share on documentation so it is easier for everyone.
My girlfriend tested max and min measured values of pedal human power on LCD3:
Max: 180 watts
Min: 40 watts
Also I want to setup min motor assistance power as min of 75 watts and max of 500 watts.
Also I think that every increase of assist level should have +50% of previous value.
Do you guys know how to calculate each assist level multiplier??
tomjasz   10 GW
Post by tomjasz » Feb 23 2019 12:39am
eyebyesickle wrote:
Feb 22 2019 10:44pm
AZUR wrote:
Feb 18 2019 10:35am
Regards
:mrgreen:
Pork dinner in MN?
elem   100 W
Post by elem » Feb 23 2019 2:30am
eyebyesicle : I have a batch of SW102 with bluetooth coming, withthe TSDZ2 compatible firmware... if people are seriously interested in working or helping with the project, I will send a few out... I think I can spare maybe 3 Units, 1 of which is reserved for casianho... if you are interested, let me know
yes i am
Actualy using KT-LCD3, are the SW102 connector compatible with standard higo KT-LCD3 ?
Do you have a link to BT program ( android one ) ?
casainho : Also I want to setup min motor assistance power as min of 75 watts and max of 500 watts.
that about what i m using ( 50 w min et 450 w max ) but i don t know how calculate, was determined by test only .
using v 0.16 actualy, planned to move to 0.18 ( specaily for walk assist as it s about absolutly necessary in MTB ; )
Don t remenber exactualy value used for assist lvl but i can check if needed .
Don t look a at human power because it s crazy ;)
it s about twice the true i thinck, but as it s used to calculate moteur power i let it like that ..
Max: 180 watts
Min: 40 watts
as i know, actualy motor power is half the human power ( may be i m wrong only remenber what i saw on display ) on lvl 1 in my system
soo for min 40 if you need 75 ( watts ) it s only a ratio, but it will not match the upper ( 180 ) human power ...
for 40 EHP ( effective human power ) if you need 75 MP ( motor power ) * must be 1.875
for 180 EHP and 500 MP * will 2.777
soo desired lvl * must be for example 1.8/2/2.2/2.4/2.7 or something like that ...
lvl 1 * 1.8 : min 75MP max 324
lvl2 * 2 : min 80, max 360
lvl3 * 2.2 : min 88, max 396
lvl4 * 2.4 : min 96, max 432
lvl5 * 2.7 : min 108, max 486
RockRider 9.1 TSDZ2 open source firmware .
https://www.strava.com/athletes/20806862
casainho   1 GW
1 GW
Post by casainho » Feb 23 2019 1:11pm
elem wrote:
Feb 23 2019 2:30am
Max: 180 watts
Min: 40 watts
Well, I didn't tested yet but I though on this:
I assume a med value for my girlfriend of 90 (180/2) human power. I am limiting my battery current to 10A and power to 500W (small battery pack), so I start with my max assist level of 500W where I would like that my girlfriend human med power to equal the 500W and each assist level increase the battery/motor power in 50% (x1.5):
Assist level 5: 90 * assist_level_multiplier = 500 --> assist_level_multiplier = 5.6
Assist level 4: 90 * assist_level_multiplier = (500/ (1.5*1)) --> assist_level_multiplier = 3.7
Assist level 3: 90 * assist_level_multiplier = (500/ (1.5*2)) --> assist_level_multiplier = 2.5
Assist level 2: 90 * assist_level_multiplier = (500/ (1.5*3)) --> assist_level_multiplier = 1.6
Assist level 1: 90 * assist_level_multiplier = (500/ (1.5*4)) --> assist_level_multiplier = 1.1
And the values for me, where my max of human power is 250, med of 125:
Assist level 5: 125 * assist_level_multiplier = 500 --> assist_level_multiplier = 4
Assist level 4: 125 * assist_level_multiplier = (500/ (1.5*1)) --> assist_level_multiplier = 2.7
Assist level 3: 125 * assist_level_multiplier = (500/ (1.5*2)) --> assist_level_multiplier = 1.3
Assist level 2: 125 * assist_level_multiplier = (500/ (1.5*3)) --> assist_level_multiplier = 0.9
Assist level 1: 90 * assist_level_multiplier = (500/ (1.5*4)) --> assist_level_multiplier = 0.7
What I can see, and that I feel when looking at my girlfriend LCD while she is riding is that his assist level multipliers are low and his motor never reaches max power of 500 watts (because are my values and I have more force in my legs).
Next I want to play with a similar algorithm to configure power boost, I guess the idea is to measure the max torque an user does on the torque sensor (can be measured while wheel is blocked on the ground and the brakes are active or assist level is 0).
elem   100 W
Post by elem » Feb 24 2019 1:01am
You are using 14S pack on each bike ?
casainho   1 GW
1 GW
Post by casainho » Feb 24 2019 1:54am
elem wrote:
Feb 24 2019 1:01am
14S3P with 3600mAh max 10A each cell.
elem   100 W
Post by elem » Feb 24 2019 2:50am
casainho wrote:
Feb 24 2019 1:54am
elem wrote:
Feb 24 2019 1:01am
are you using 36V or 48V motor ?
I would try to move to a 48V if it s usefull for mtb, it s not priority but it could be a better option in MTB, as i m using 11S for friendly/sister use, and 12S for mine i thinck even whith 14S 48V motor couldn t reach my personnal goal RPM ( about 100 and 110 max )
casainho   1 GW
1 GW
Post by casainho » Feb 24 2019 2:55am
elem wrote:
Feb 24 2019 2:50am
casainho wrote:
Feb 24 2019 1:54am
elem wrote:
Feb 24 2019 1:01am
I am using 52V (hence the 14S3P as I said). I don't usually do many MTB as professional/competition, I go to that events but I stay at the end and for me is mostly like a bicycle ride.
elem   100 W
Post by elem » Feb 24 2019 6:02am
ok, it s different, i would ask, is your motor a 0 type ( 48V ) or a 1 type ( 36V ) ?
as they all match 4000 rpm but 48V motor need 48 V to match it and 36V motor only need 36V to match 4000 rpm .
With 14S battery 36v motor could run at 4000*1.40= 5600 rpm and 48V motor only 4000*14/13= 4300 rpm .
that why i use 12S on a 36 V motor, gain is 20%, soo it match my rpm goal 4800/44=109 rpm max ( at cranck )
casainho   1 GW
1 GW
Post by casainho » Feb 24 2019 11:33am
elem wrote:
Feb 24 2019 6:02am
I never verified max RPM of my TSDZ2 with my battery. My motor is of 48V.
mctubster   100 W
Post by mctubster » Feb 25 2019 4:07am
Rafe wrote:
Feb 02 2019 8:56am
The lag is a different issue with power boost Buba, this is when power boost sometimes does not cut in when pedalling resumes so there is no pedal assist at all for about 3 seconds, and even then when the pedal assist resumes is normal assist not the boost. This is an intermittent fault that I can't find a sequence or logic to.
The resting the foot on pedal and the bike takes off under power boost even though wheel speed must be zero is disabled is another intermittent fault. I mostly remember to keep the wired rear brake on when at the lights in case it happens but like others I've found it to be dangerous, only the other day I was off the bike chatting to a friend with a foot resting on a pedal and the bike decided to try and run her over.
These faults have been present for sometime so I doubt your modifications have anything to do with them.
I also have these two exact issues. Power boost does not work randomly and when power boast does not activate I also get no assist for around 3 seconds too. Not cool when at the lights!
I also have random surges at the lights, bike stopped, resting foot on pedal ... no pedal rotation ... Sometimes I wonder if I have backpedalled slightly to get the best foot position and as I rest my foot back down the motor surges. But then sometimes it will do two or three surges a number of seconds apart. Is there averaging on the rotation (direction not counted) so that small torque + previous rotation = power output ... this is on 17 though I am about to go to 19.
What testing can I do to help diagnose further?
Regards
Steve
casainho   1 GW
1 GW
Post by casainho » Feb 25 2019 6:01am
mctubster wrote:
Feb 25 2019 4:07am
Rafe wrote:
Feb 02 2019 8:56am
Regards
Steve
1. when lag occurs because of some fail on power boost, I quick hit the brakes and power boost starts immediately. This is a workaround.
2. I always use "Motor assistance startup without pedal rotation" = 1 so I do not have that issue. If you acan, give a look at the code to try understand what may be causing that issue.
e3s   100 mW
Post by e3s » Feb 25 2019 3:50pm
which is the best version? 36v or 48v? how many amperes can withstand for short, medium and long time? (1min, 5min, long travel) How much is efficient the 36v version at 48v?
